Give this a shot...
;;CADALYST 09/03 AutoLISP Solutions
;;; PLINE-3D-2D.LSP - a program to convert
;;; 3D polylines to 2D
;;; Program by Tony Hotchkiss
(defun pline-3d-2d ()
(setq *thisdrawing* (vla-get-activedocument
(vlax-get-acad-object)
) ;_ end of vla-get-activedocument
*modelspace* (vla-get-ModelSpace *thisdrawing*)
) ;_ end of setq
(setq 3d-pl-list
(get-3D-pline)
) ;_ end of setq
(if 3d-pl-list
(setq vert-array-list (make-list 3d-pl-list))
(setq n (- 1))
(repeat (length vert-array-list)
(setq vert-array (nth (setq n (1+ n)) vert-array-list))
(setq lyr (vlax-get-property (nth n 3d-pl-list) 'Layer))
(setq obj (vla-AddPolyline *modelspace* vert-array))
(vlax-put-property obj 'Layer lyr)
) ;_ end of repeat
(foreach obj 3d-pl-list (vla-delete obj))
) ;_ end of progn
) ;_ end of if
) ;_ end of pline-3d-2d
(defun get-3D-pline ()
(setq pl3dobj-list nil
obj nil
3d "AcDb3dPolyline"
) ;_ end of setq
(setq selsets (vla-get-selectionsets *thisdrawing*))
(setq ss1 (vlax-make-variant "ss1"))
(if (= (vla-get-count selsets) 0)
(setq ssobj (vla-add selsets ss1))
) ;_ end of if
(vla-clear ssobj)
(setq Filterdata (vlax-make-variant "POLYLINE"))
(setq no-ent 1)
(while no-ent
(vla-Selectonscreen ssobj)
(if (> (vla-get-count ssobj) 0)
(setq no-ent nil)
(setq i (- 1))
(repeat (vla-get-count ssobj)
(setq
obj (vla-item ssobj
(vlax-make-variant (setq i (1+ i)))
) ;_ end of vla-item
) ;_ end of setq
((= (vlax-get-property obj "ObjectName") 3d)
(setq pl3dobj-list
(append pl3dobj-list (list obj))
) ;_ end of setq
) ;_ end-of cond
) ;_ end of repeat
) ;_ end of progn
(prompt "\nNo entities selected, try again.")
) ;_ end of if
(if (and (= nil no-ent) (= nil pl3dobj-list))
(setq no-ent 1)
(prompt "\nNo 3D-polylines selected.")
(quit)
) ;_ end of progn
) ;_ end of if
) ;_ end of while
(vla-delete (vla-item selsets 0))
pl3dobj-list
) ;_ end of get-3D-pline
(defun get-3D-pline-old ()
(setq no-ent 1)
(setq filter '((-4 . "<AND")
(0 . "POLYLINE")
(70 . 8)
(-4 . "AND>")
) ;_ end of setq
(while no-ent
(setq ss (ssget filter)
k (- 1)
pl3dobj-list nil
obj nil
3d "AcDb3dPolyline"
) ;_ end-of setq
(if ss
(setq no-ent nil)
(repeat (sslength ss)
(setq ent (ssname ss (setq k (1+ k)))
obj (vlax-ename->vla-object ent)
) ;_ end-of setq
(setq pl3dobj-list
) ;_ end of setq
) ;_ end-of cond
) ;_ end-of repeat
) ;_ end-of progn
(prompt "\nNo 3D-polylines selected, try again.")
) ;_ end-of if
) ;_ end-of while
pl3dobj-list
) ;_ end of get-3D-pline-old
(defun make-list (p-list)
(setq i (- 1)
vlist nil
calist nil
) ;_ end of setq
(repeat (length p-list)
(setq obj (nth (setq i (1+ i)) p-list)
coords (vlax-get-property obj "coordinates")
ca (vlax-variant-value coords)
) ;_ end-of setq
(setq calist (append calist (list ca)))
) ;_ end-of repeat
) ;_ end-of make-list
(defun c:pl32 ()
(pline-3d-2d)
) ;_ end of pl32
(prompt "Enter PL32 to start: ")
