Author Topic: Pre-audit audit  (Read 4302 times)
mohnston
  • CAD Programmer
Pre-audit audit
« on: February 15, 2007, 12:08:40 PM »
I am processing a number of drawings.
I know there is a way in .NET to Audit a database once it is open.
However, with a corrupt drawing I can't open it in order to audit it. The code causes AutoCAD to crash with a message like:
INTERNAL ERROR: !dbobji.cpp@6601: eNotOpenForWrite
Makes sense to me, database didn't open because the drawing was bad.
Does anyone know of a quick, low-overhead way to validate a drawing before trying to work with it?
CAD Programming Solutions
mohnston
  • CAD Programmer
Re: Pre-audit audit
« Reply #1 on: June 04, 2008, 06:04:50 PM »
I never did find a solution.
Opendwg (DWGDirectX) now has a recoverfile method but I still don't see a pre-open audit solution.
Any new thoughts?
It's Alive!
  • Retired
  • AKA Daniel
Re: Pre-audit audit
« Reply #2 on: June 05, 2008, 02:06:23 PM »
How about something like
public class Commands
    [CommandMethod("doit")]
    public static void doit()
      string path = "c:\\LP04795.dwg";
      ed.WriteMessage(TestDb(path).ToString());
    public static bool TestDb(string path)
      Database db = new Database();
      bool returnFlag = false;
      try
        db.ReadDwgFile(path, FileShare.ReadWrite, false, string.Empty);
        returnFlag = true;
      catch
        returnFlag = false;
      finally
        db.CloseInput(true);
        db.Dispose();
      return returnFlag;
Glenn R
Re: Pre-audit audit
« Reply #3 on: June 05, 2008, 04:45:38 PM »
Any new thoughts?
Nor will you - cart before horse springs to mind.
Dan's example is probably the best you can hope for, but still requires a read, which any validation would do, including 'audit', so back to square one.
mohnston
  • CAD Programmer
Re: Pre-audit audit
« Reply #4 on: June 05, 2008, 04:59:34 PM »
Any new thoughts?
And yet, AutoCAD has the ability to begin reading, detect a problem, present us an option (Cancel or Ignore), and continue on. In fact if we answer Yes to the "Would you like to cancel the open?" dialog AutoCAD exits gracefully without "opening" the drawing or hitting us with a fatal error.
Daniel, Thanks for the suggestion. Tried it but readdwgfile does not throw an error on my bad file. Documents.Open does.
Opendwg, (OpenDesign Alliance) used to have a "Drawing Sniffer" and a method called dwgSmellsBad.
I want something like:
if (Application.DwgIsCorrupt(myDrawingPath))
    Document myDoc = Application.RecoverDrawing(myDrawingPath);
    // do stuff to it
else
    // report bad drawing to user
Glenn R
Re: Pre-audit audit
« Reply #5 on: June 05, 2008, 05:03:57 PM »
Yeah, but I think the kicker here, is that, AutoCAD is opening the dbase in a 'Document' ie a valid window with graphics in the AutoCAD editor, whereas with ReadDwgFile, you typically pass false to NOT associate it with any document, as you're just reading it into memory.
Glenn R
Re: Pre-audit audit
« Reply #6 on: June 05, 2008, 05:09:57 PM »
Sorry, scratch that last post - I was thinking of the second argument to the AcDbDatabase constructor to associate the dbase with the current document.
Re: Pre-audit audit
« Reply #7 on: June 05, 2008, 05:51:59 PM »
Have you tried the Audit method on the database that is opened by ReadDwgFile?
mohnston
  • CAD Programmer
Re: Pre-audit audit
« Reply #8 on: June 05, 2008, 07:10:27 PM »
I tried to figure out how to do that but got lost.
Problem 1. Audit returns void. I need to get a result to examine. I need an AuditInfo object.
Problem 2. You have to pass the Audit method an AuditInfo object which has no constructor so I can't make one to pass.
Has anyone been able to get information from Audit? Point me in the right direction.
Re: Pre-audit audit
« Reply #9 on: June 05, 2008, 07:20:33 PM »
Ah....  The Arx docs for '06 says it's not implemented yet, so I'm not sure if it is in other releases....
wait I got the docs for '08.. let me check.
Nope, still a no go in '08.  Not sure how to do it then... sorry.
It's Alive!
  • Retired
  • AKA Daniel
Re: Pre-audit audit
« Reply #10 on: June 05, 2008, 08:57:39 PM »
The only thing I can think of is try opening stuff up,
i.e
      try
        AcDb.TransactionManager Tm = db.TransactionManager;
        using (Transaction tr = Tm.StartTransaction())
          BlockTable tb = (BlockTable)tr.GetObject
                       (db.BlockTableId, OpenMode.ForRead, false);
          BlockTableRecord btr = (BlockTableRecord)tr.GetObject
                       (tb[BlockTableRecord.ModelSpace], OpenMode.ForRead, false);
          BlockTableRecord btrp = (BlockTableRecord)tr.GetObject
                       (tb[BlockTableRecord.PaperSpace], OpenMode.ForRead, false);
          tr.GetObject(db.LayoutDictionaryId, OpenMode.ForRead, false);
          tr.GetObject(db.LayerTableId, OpenMode.ForRead, false);
          tr.GetObject(db.NamedObjectsDictionaryId, OpenMode.ForRead, false);
          tr.GetObject(db.ViewportTableId, OpenMode.ForRead, false);
          tr.GetObject(db.ViewTableId, OpenMode.ForRead, false);
        returnFlag = true;
      catch(SystemException ex)
        ed.WriteMessage(ex.Message);
        returnFlag = false;
      finally
        db.Dispose();
      return returnFlag;
