Sure. Just keep in mind that I didn't actually edit these in the "correct" way. I started changing them before I figured out how all the links to the RepGenSettings.xml were working, and I broke some of them. Some of this stuff is now hard-coded the way I want it, rather than using the RepGenSettings.xml file the way it should.
If you have a text editor that will let you compare text files and highlight the differences, you can compare these files with the Autodesk-provided files to see what I changed.
I also did some more tweaks, e.g. bearings all get formatted using degree-min-sec symbols instead of hyphens.
