hello people, I'm in need of some help. i am trying to take pulldown menu's that i use at work on CAD 2000i and install them onto a outside contractors PC running CAD 2006. i copied all files for the pulldown menus, (blocks, borders, vba files, lisp files, mns files), to there network drive, set all the paths, loaded the menu. The menu appears after the help tab, does drop down but will not run most of the vba's and lisp's, will insert border and title block, and will do a title block update which is a vba program. But for most of the items on the menu it says (macro can not be found) or it wont place the item you picked when you pick something on the pulldown menu. I'm just starting to understand adding menu's not to sure of 2006. also Now when you start ACAD 2006 it loads up and a window pops up that says can't find COMMANDLINE something !!.... I'm not at the system so i cant remember exactly what it said. any ideas would be greatly appreciated! Remember I'm not very experienced at 2006
![undecided :|](https://www.theswamp.org/Smileys/black/undecided.gif)
