I was gonna just share the following procedures as just stuff i had laying arround but would anybody be intrested in sharing their or helping collect general procedures like these?
A while ago i spent some time and started working on "standard" procedures i could use in a ".dll" of sorts. I noticd i had this file in my lisp dir and i wanted to share these with all of you.
Most are pretty general (well actualy, they came from a file called "general.l" so...
) and some are pretty dumb, but i like to share cause you never know if someone can use these.
Enjoy...
;;; variable-p
;;; Test to see if item is a variable or not.
;;; Returns - bool
(defun variable-p (a) (not (null a)))
;;; same-variable
;;; Test to see if two variables are equal.
;;; Returns - bool
(defun same-variable (a b) (and (variable-p a) (variable-p b) (eq a b)))
;;; number-p
;;; Tests to see if the given is a number.
;;; returns - bool
(defun number-p (a) (eq (type a) 'INT))
;;; make-product
;;; Takes two numbers and forms a multiplication process
;;; Returns - process
(defun make-product (a b) (list '* a b))
;;; pair?
;;; Test to see if an object is infact a pair or entities.
;;; Ex:
;;; (pair? '(1 2))
;;; > T
(defun pair? (x) (and (car x) (cadr x)))
;;; sum-p
;;; test to see if given process is summation
;;; returns - bool
(defun sum-p (x) (and (pair? x) (eq (car x) '+)))
;;; product-p
;;; test to see if given process is multplication
;;; returns - bool
(defun product-p (x) (and (pair? x) (eq (car x) '*)))
;;; block-p
;;; test to see of given is a block
;;; Returns - bool
(defun block-p (x)
(and (caddr (nentselp (cadr x)))))
;;; ### The following is a process demonstration ###
;;; will take a list (1 2 3 4 5 6 7 8 9) and tell you if each item
;;; in the list is greater then the number you want.
;;; -e.g. (High-Low '(1 2 3 4) 2)
;;; -> (L H H H)
(defun High-Low (lst num)
(setq newlist (cons (if (>= (car lst) num) 'H 'L) newlist))
(if (> (length (cdr lst)) 0)
;; itterate thru again if the remanter of the list is greater then 0
(High-Low (cdr lst) num))
(reverse newlist)
;;; var-store
;;; Store a variable in a dotted list format. Name and value
(defun var-store (var value)
(cond ((and value) (cons var value))
((cons var (getvar var)))))
;;; List Position ;
;;; This procedure will search a list for a given item and retrun the ;
;;; first position in the list where the item occures. ;
;;; Author: John Kaul (Se7en) ;
(defun listpos (lst item)
(if (member item lst) (- (length lst) (length (member item lst)))))
;;; ### The following are a few examples attempting to take a
;;; step towards "safer" general process' ###
(defun getpoin7 (/ x)
(while (not (setq x (getpoint)))
(princ "\nYou missed, try again.")) x)
(defun entse7 (/ x)
(while (not (setq x (car (entsel))))
(defun StartPT (ent) (cdr (assoc 10 (entget ent))))
(defun EndPT (ent) (cdr (assoc 11 (entget ent))))
(defun GetLyr (ent)
(cdr (assoc 8 (entget ent))))
(defun GetRotDeg (ent)
(* 180.0 (/ (cdr (assoc 50 (entget ent))) pi)))
(defun GetRotRad (ent)
(cdr (assoc 50 (entget ent))))
(defun GetTxt (ent) (cdr (assoc 1 (entget ent))))
(defun GetEntColor (ent)
(cond (ent (cdr (assoc 62 (entget (car ent)))))))
