Author Topic: Anybody use lisplink?  (Read 8200 times)
Re: Anybody use lisplink?
« Reply #15 on: January 12, 2007, 07:03:20 AM »
VLIDE in Autocad (95% of my coding is done in the IDE )
I test continuously as I go, and all my library stuff is already loaded ... pretty hard to beat.
UltraEdit when not in Acad
LE
« Reply #16 on: January 12, 2007, 11:05:27 AM »
text editor, vital lisp and now visual lisp... is all I have been using when writing lisp/dcl code
ElpanovEvgeniy
  • Moscow (Russia)
« Reply #17 on: January 12, 2007, 01:49:22 PM »
VLIDE in Autocad = 95%
Pencil, pen, paper = 4%
%SystemRoot%\system32\notepad.exe = 1%
Joe Burke
« Reply #18 on: January 13, 2007, 11:05:01 AM »
I hate vlide.
TextPad with Michael's vlisp.syn (syntax) file works for me.
« Reply #19 on: January 13, 2007, 12:23:04 PM »
Strong word there Joe. Did you have a bad experience with VLIDE to "hate" it.
I use VLIDE 80% & UltraEdit with syntax highlighting 19% and maybe 1% paper & pen.
Just guesstimates on the percentages of course.
dan19936
« Reply #20 on: January 13, 2007, 02:33:30 PM »
I don't like VLIDE's handling of text selection & editing. I use Textpad w/syntax highlighting and have a few macros for indenting. I only use VLIDE for reformatting code & debugging when I'm stuck.
Dan
Joe Burke
« Reply #21 on: January 14, 2007, 12:09:44 PM »
My sense of vlide is it was designed by a programmer, rather than someone experienced with interface issues. A poor interface always turns me off, regardless of what the program can do.
I agree with Dan regarding debugging. I'll use it for that (error trace) when I can't figure out where I've gone wrong via some other method.
