Author Topic: Replace nth member of a list  (Read 28038 times)
Re: Replace nth member of a list
« Reply #30 on: December 28, 2006, 02:51:11 PM »
You guys are the greatest. This is a fun thread.
The checks in the mail. (ha!)
You should come and visit more often .. there are lots of other threads very similar to this one.
Oh .. and lest I forget .. the ideas posted here helped me resolve my problem and with a minor tweak to the combined code of CAB and Evgeniy I now have a working model that I can build upon. I appreciate the help guys .. seems like every now and then I just get a brain fart and can't seem to see the forest for all of the trees in the way.
ElpanovEvgeniy
  • Moscow (Russia)
« Reply #31 on: December 28, 2006, 07:04:39 PM »
My mail empty...  :(
terrycadd
« Reply #32 on: December 30, 2006, 12:51:16 AM »
I know this is not a contest, however concerning the speed of functions we can all benefit by the contributions of other programmers. Here are the results of the functions using my included c:TestNths function that determines the speed of the functions relating to the original title of this thread.
Command: TestNths
swapnth: 21543086
replase: 21544061
nth-replace: 21544324
replace: 21544728
replase_2: 21544986
Finished: 21545784
Lowest number for results is the fastest:
swapnth = 975
replase = 263
nth-replace = 404
replace = 258
replase_2 = 798
Command: TestNths
swapnth: 21550007
replase: 21550971
nth-replace: 21551233
replace: 21551635
replase_2: 21551893
Finished: 21552689
swapnth = 964
replase = 262
nth-replace = 402
replace = 258
replase_2 = 796
Command: TestNths
swapnth: 21593135
replase: 21594107
nth-replace: 21594370
replace: 21594772
replase_2: 21595030
Finished: 21595830
swapnth = 972
replase = 263
nth-replace = 402
replace = 258
replase_2 = 800
Command: TestNths
swapnth: 22000948
replase: 22001915
nth-replace: 22002177
replace: 22002579
replase_2: 22002837
Finished: 22003632
swapnth = 967
replase = 262
nth-replace = 402
replace = 258
replase_2 = 795
I ran this test several times and it returned similar results.
The “replace” function by Danielm103 was slightly faster than the “replase” function by Evgeniy.
(defun c:TestNths (/ Cnt# t1 t2 t3 t4 t5 t6)
  (if (not *List@);Create a 1000 item global *List@
    (repeat 10
      (setq Cnt# 48);Start at (ascii "0") (chr 48)
      (repeat 100
        (setq *List@ (append *List@ (list (chr Cnt#))))
        (setq Cnt# (1+ Cnt#))
      );repeat
    );repeat
  );if
  (princ "\nswapnth: ")
  (princ (setq t1 (atoi (substr (rtos (getvar "cdate") 2 8) 10))))(princ)
  (repeat 1000 (swapnth *List@ 998 "NEW"))
  (princ "\nreplase: ")
  (princ (setq t2 (atoi (substr (rtos (getvar "cdate") 2 8) 10))))(princ)
  (repeat 1000 (replase *List@ 998 "NEW"))
  (princ "\nnth-replace: ")
  (princ (setq t3 (atoi (substr (rtos (getvar "cdate") 2 8) 10))))(princ)
  (repeat 1000 (nth-replace 998 "NEW" *List@))
  (princ "\nreplace: ")
  (princ (setq t4 (atoi (substr (rtos (getvar "cdate") 2 8) 10))))(princ)
  (repeat 1000 (replace *List@ 998 "NEW"))
  (princ "\nreplase_2: ")
  (princ (setq t5 (atoi (substr (rtos (getvar "cdate") 2 8) 10))))(princ)
  (repeat 1000 (replase_2 *List@ 998 "NEW"))
  (princ "\nFinished: ")
  (princ (setq t6 (atoi (substr (rtos (getvar "cdate") 2 8) 10))))(princ)
  (princ "\nLowest number for results is the fastest:")
  (princ "\nswapnth = ")    (princ (- t2 t1))
  (princ "\nreplase = ")    (princ (- t3 t2))
  (princ "\nnth-replace = ")(princ (- t4 t3))
  (princ "\nreplace = ")    (princ (- t5 t4))
  (princ "\nreplase_2 = ")  (princ (- t6 t5))
);defun c:TestNths
ElpanovEvgeniy
  • Moscow (Russia)
« Reply #33 on: December 30, 2006, 03:56:15 AM »
I have obtained similar data, without compilation...
Compare speed after compilation!
AutoCad 2004
Checked this code:
;; CAB 11/15/2006
;;  replace nth item in list
(defun swapnth (lst i1 itm / tmp nlst)
  (while (and (> i1 0)
              (< (length (setq nlst (cons (car lst) nlst))) i1))
    (setq lst (cdr lst))
  (setq nlst (cons itm nlst)
        lst (cddr lst))
  (while (or (setq tmp (car lst)) lst)
    (setq nlst (cons tmp nlst)
          lst (cdr lst))
  (reverse nlst)
(defun replase (lst i itm)
  ;;(replase '(0 1 2 3 4 5 6) 3 "A")
  ;; '(0 1 2 "A" 4 5 6)
  (mapcar
    (function
      (lambda (x)
        (if (zerop i)
          (progn (setq i (1- i)) itm)
          (progn (setq i (1- i)) x)
        ) ;_ if
      ) ;_ lambda
    ) ;_ function
    lst
  ) ;_ mapcar
) ;_ defun
(defun replase_1 (lst i itm)
  ;;(replase_1 '(0 1 2 3 4 5 6) 3 "A")
  (if lst
    (if (> i 0)
      (cons (car lst) (replase_1 (cdr lst) (1- i) itm))
      (cons itm (cdr lst))
    ) ;_ if
  ) ;_ if
(defun nth-replace ( pos new-item lst )
  ;; Nth-Replacer
  ;; This procedure will itterate thru an
  ;; entire list to replace the nth item
  ;; of that list.
  ;; (nth-replace 2 3 '(1 2 4 4))
  ;; (1 2 3 4)
  ;; By: John (Se7en) K
  ;;     12.27.06
  (if (null lst)
    nil
    (cons
      (if (eq pos 0) new-item (car lst))
      (nth-replace (1- pos) new-item (cdr lst)))) )
(defun replace (lst i itm)
  (setq i (1+ i))
  (mapcar
    '(lambda (x)
      (if (zerop (setq i (1- i))) itm x)
    lst
(defun replase_2 (lst i itm / c)
  ;;(replase_2 '(0 1 2 3 4 5 6) 3 "A")
  (setq c -1)
  (mapcar
    (function cdr)
    ((lambda (l)
       (subst
         (cons 0 itm)
         (assoc i l)
         l
       ) ;_ subst
     ) ;_ lambda
      (mapcar (function (lambda (x) (cons (setq c (1+ c)) x))) lst)
  ) ;_ mapcar
) ;_ defun
    (repeat 10
      (repeat 100
      );repeat
    );repeat
  );if
  (princ "\nreplase_1: ")
  (repeat 1000 (replase_1 *List@ 998 "NEW"))
  (princ (setq t7 (atoi (substr (rtos (getvar "cdate") 2 8) 10))))(princ)
  (princ "\nreplase_1 = ")  (princ (- t6 t5))
  (princ "\nreplase_2 = ")  (princ (- t7 t6))
);defun c:TestNths
Results after compilation:
Command:
Command: (LOAD "D:/replase.VLX") nil
Command: 'VLIDE
Command:
Command: TestNths
swapnth: 11341072
replase: 11341546
nth-replace: 11341621
replace: 11341769
replase_1: 11341891
replase_2: 11342038
Finished: 11342197
swapnth = 474
replase = 75
nth-replace = 148
replace = 122
replase_1 = 147
replase_2 = 159
Command:
Command: TestNths
swapnth: 11344692
replase: 11345168
nth-replace: 11345246
replace: 11345398
replase_1: 11345538
replase_2: 11345685
Finished: 11345851
swapnth = 476
replase = 78
nth-replace = 152
replace = 140
replase_1 = 147
replase_2 = 166
Command:
Command: TestNths
swapnth: 11350462
replase: 11350933
nth-replace: 11351009
replace: 11351155
replase_1: 11351276
replase_2: 11351423
Finished: 11351581
swapnth = 471
replase = 76
nth-replace = 146
replace = 121
replase_1 = 147
replase_2 = 158
Command:
Command: TestNths
swapnth: 11352441
replase: 11352913
nth-replace: 11352990
replace: 11353141
replase_1: 11353269
replase_2: 11353420
Finished: 11353582
swapnth = 472
replase = 77
nth-replace = 151
replace = 128
replase_1 = 151
replase_2 = 162
Command:
Command: TestNths
swapnth: 11354036
replase: 11354512
nth-replace: 11354588
replace: 11354739
replase_1: 11354871
replase_2: 11355021
Finished: 11355184
swapnth = 476
replase = 76
nth-replace = 151
replace = 132
replase_1 = 150
replase_2 = 163
Command:
Results without compilation:
Command:
Command: (LOAD "D:/replase.LSP") C:TESTNTHS
Command: TestNths
swapnth: 11533020
replase: 11533675
nth-replace: 11533829
replace: 11534141
replase_1: 11534278
replase_2: 11534565
Finished: 11534774
swapnth = 655
replase = 154
nth-replace = 312
replace = 137
replase_1 = 287
replase_2 = 209
Command:
Command: TestNths
swapnth: 11535754
replase: 11540417
nth-replace: 11540575
replace: 11540888
replase_1: 11541032
replase_2: 11541324
Finished: 11541538
swapnth = 4663
replase = 158
nth-replace = 313
replace = 144
replase_1 = 292
replase_2 = 214
Command:
Command: TestNths
swapnth: 11541771
replase: 11542436
nth-replace: 11542590
replace: 11542902
replase_1: 11543051
replase_2: 11543344
Finished: 11543559
swapnth = 665
replase = 154
nth-replace = 312
replace = 149
replase_1 = 293
replase_2 = 215
Command:
Command: TestNths
swapnth: 11543785
replase: 11544473
nth-replace: 11544641
replace: 11544969
replase_1: 11545104
replase_2: 11545421
Finished: 11545646
swapnth = 688
replase = 168
nth-replace = 328
replace = 135
replase_1 = 317
replase_2 = 225
Command:
Command: TestNths
swapnth: 11545831
replase: 11550502
nth-replace: 11550670
replace: 11550990
replase_1: 11551142
replase_2: 11551450
Finished: 11551669
swapnth = 4671
replase = 168
nth-replace = 320
replace = 152
replase_1 = 308
replase_2 = 219
Command:
PS. You use compilation?
« Reply #34 on: December 30, 2006, 04:06:43 AM »
Terry, Michael [ MP ] has published a Benchmark.lsp for comparing performance .
here you go : ...
http://www.theswamp.org/lilly_pond/mp/lisp/benchmark.txt?nossi=1
    ;;  Example:
    ;;      (BenchMark
    ;;              (1+ 1)
    ;;              (+ 1 1)
    ;;              (+ 1 1.0)
    ;;              (+ 1.0 1.0)
    ;;  Output:
    ;;      Elapsed milliseconds / relative speed for 32768 iteration(s):
    ;;          (1+ 1)..........1969 / 1.09 <fastest>
    ;;          (+ 1 1).........2078 / 1.03
    ;;          (+ 1 1.0).......2125 / 1.01
    ;;          (+ 1.0 1.0).....2140 / 1.00 <slowest>
;; .... >>>> etc
The version I use is modified so that the fastest has a 1 factor  and the slowest has a higher factor, related to the time
... so it looks like this :-
Benchmarking [M.P. @ theSwamp 2005] ..................
Elapsed milliseconds for 32768 iteration(s)/ relative Timing :
    (+ 1 1.0).......1735 / 1.0188 <slowest>
    (+ 1.0 1.0).....1735 / 1.0188
    (+ 1 1).........1719 / 1.0094
    (1+ 1)..........1703 / 1 <fastest>
« Reply #35 on: December 30, 2006, 08:31:43 AM »
This is what I got using MP Benchmark
Command: test
Elapsed milliseconds / relative speed for 16384 iteration(s):
    (REPLASE_1 (QUOTE (0 1 2 3 4 5 6)) 3...).....1973 / 1.15 <fastest>
    (SWAPNTH (QUOTE (0 1 2 3 4 5 6)) 3 "A")......2113 / 1.08
    (NTH-REPLACE 3 "a" (QUOTE (0 1 2 3 4...).....2193 / 1.04
    (REPLACE_CAB (QUOTE (0 1 2 3 4 5 6))...).....2193 / 1.04
    (REPLASE (QUOTE (0 1 2 3 4 5 6)) 3 "A")......2214 / 1.03
    (REPLACE_DA "a" 3 (QUOTE (0 1 2 3 4 ...).....2273 / 1.00 <slowest>
Command:
Command: test
    (REPLASE_1 (QUOTE (0 1 2 3 4 5 6)) 3...).....1983 / 1.15 <fastest>
    (SWAPNTH (QUOTE (0 1 2 3 4 5 6)) 3 "A")......2123 / 1.08
    (REPLACE_CAB (QUOTE (0 1 2 3 4 5 6))...).....2203 / 1.04
    (NTH-REPLACE 3 "a" (QUOTE (0 1 2 3 4...).....2204 / 1.04
    (REPLASE (QUOTE (0 1 2 3 4 5 6)) 3 "A")......2223 / 1.03
    (REPLACE_DA "a" 3 (QUOTE (0 1 2 3 4 ...).....2283 / 1.00 <slowest>
Command:
Command: test
    (REPLASE_1 (QUOTE (0 1 2 3 4 5 6)) 3...).....2003 / 1.14 <fastest>
    (REPLACE_CAB (QUOTE (0 1 2 3 4 5 6))...).....2223 / 1.03
    (REPLASE (QUOTE (0 1 2 3 4 5 6)) 3 "A")......2233 / 1.02
(defun c:test ()
  (BenchMark
    '((replace_Da "a" 3 '(0 1 2 3 4 5 6))
      (nth-replace 3 "a" '(0 1 2 3 4 5 6))
      (swapnth '(0 1 2 3 4 5 6) 3 "A")
      (replace_CAB '(0 1 2 3 4 5 6) 3 "A")
;;  Danielm103
;;(replace "a" 3 '(0 1 2 3 4 5 6))
(defun replace_Da (a n lst / e i nl)
 (setq nl '()
       i 0
 (foreach e lst
  (if (= i n)
   (setq nl (cons a nl))
   (setq nl (cons e nl))
  (setq i (1+ i))
 (reverse nl)
;; CAB 11/15/2006
        lst (cddr lst))
          lst (cdr lst))
  (reverse nlst)
;;  Evigeny
  (mapcar
    (function
      (lambda (x)
        (if (zerop i)
    lst
;; variation by CAB
(defun replace_CAB (lst i itm)
  (setq i (1+ i))
  (mapcar '(lambda (x) (if (zerop (setq i (1- i))) itm x)) lst)
;;  Evigeny
  (if lst
    (if (> i 0)
    ) ;_ if
  ) ;_ if
  ;; Nth-Replacer
  ;; of that list.
  ;; (1 2 3 4)
  ;;     12.27.06
  (if (null lst)
    nil
    (cons
« Reply #36 on: December 30, 2006, 08:55:13 AM »
Changing the test to this changed the results:
See Terry's code to create *List@
(defun c:test ()
  (BenchMark
    '((replace_Da "NEW" 998 *List@)
      (replace_CAB *List@ 998 "NEW")
Command: test
Elapsed milliseconds / relative speed for 512 iteration(s):
    (REPLACE_CAB *LIST@ 998 "NEW").....1011 / 3.90 <fastest>
    (REPLASE *LIST@ 998 "NEW").........1072 / 3.68
    (REPLASE_1 *LIST@ 998 "NEW").......1833 / 2.15
    (REPLACE_DA "NEW" 998 *LIST@)......1902 / 2.07
    (NTH-REPLACE 998 "NEW" *LIST@).....1952 / 2.02
    (SWAPNTH *LIST@ 998 "NEW").........3946 / 1.00 <slowest>
Command:
Command: test
    (REPLACE_DA "NEW" 998 *LIST@)......1923 / 2.05
    (NTH-REPLACE 998 "NEW" *LIST@).....2083 / 1.89
And changing the test again to this:
(defun c:test ()
  (BenchMark
    '((replace_Da "NEW" 5 *List@)
      (swapnth *List@ 5 "NEW")
      (replase *List@ 5 "NEW")
      (replace_CAB *List@ 5 "NEW")
      (replase_1 *List@ 5 "NEW")
WOW - what do you suppose is going on here.. :)
Command: test
Elapsed milliseconds / relative speed for 8192 iteration(s):
    (REPLASE_1 *LIST@ 5 "NEW")........1011 / 30.91 <fastest>
    (REPLACE_CAB *LIST@ 5 "NEW").....16043 / 1.95
    (REPLASE *LIST@ 5 "NEW").........17195 / 1.82
    (SWAPNTH *LIST@ 5 "NEW").........22052 / 1.42
    (REPLACE_DA "NEW" 5 *LIST@)......30293 / 1.03
    (NTH-REPLACE 5 "NEW" *LIST@).....31245 / 1.00 <slowest>
Command:
Command: test
    (REPLASE_1 *LIST@ 5 "NEW")........1021 / 30.65 <fastest>
    (REPLACE_CAB *LIST@ 5 "NEW").....16123 / 1.94
    (REPLASE *LIST@ 5 "NEW").........17335 / 1.81
    (SWAPNTH *LIST@ 5 "NEW").........22082 / 1.42
    (REPLACE_DA "NEW" 5 *LIST@)......30504 / 1.03
    (NTH-REPLACE 5 "NEW" *LIST@).....31295 / 1.00 <slowest>
<edit, added the second test routine...>
« Last Edit: December 30, 2006, 06:40:12 PM by CAB »
« Reply #37 on: December 30, 2006, 12:02:07 PM »
Evigeny’s replase_1 Rocks!!!
Good job  Evigeny :-D
ElpanovEvgeniy
  • Moscow (Russia)
« Reply #38 on: December 30, 2006, 01:10:14 PM »
>CAB
You used compilation in this testing?
« Last Edit: December 30, 2006, 06:19:07 PM by CAB »
« Reply #39 on: December 30, 2006, 06:18:47 PM »
No, sorry, I was too lazy. :oops:
Oh, I forgot to include the second test routine, see the post above, I added it.
In your recursive routine, it stops when the replacement is made so in that test
it stopped after 6 iterations.
« Last Edit: December 30, 2006, 06:42:29 PM by CAB »
ElpanovEvgeniy
  • Moscow (Russia)
« Reply #40 on: December 31, 2006, 05:08:49 AM »
All works for me correctly...
Probably, I have not understood your question :(
ElpanovEvgeniy
  • Moscow (Russia)
« Reply #41 on: December 31, 2006, 05:21:16 AM »
I have made it.  :)
Very interesting results have turned out!  :-)
It is the program of testing:
(defun c:test (/ *LIST@ CNT# I)
  (if (not *List@)
    (repeat 10
      (setq Cnt# 48)
      (repeat 100
      ) ;repeat
    ) ;repeat
  ) ;_  if
  (setq i 99)
  (repeat 10
    (princ (strcat "\n\nI = " (itoa i) "\n"))
    (BenchMark
      '((replace_Da "A" i *List@)
        (nth-replace i "A" *List@)
        (swapnth *List@ i "A")
        (replase *List@ i "A")
        (replace_CAB *List@ i "A")
        (replase_1 *List@ i "A")
        (replase_2 *List@ i "A")
    ) ;_  BenchMark
    (setq i (+ i 100))
  ) ;_  repeat
) ;_  defun
It is a code, for testing:
;;  test.lsp
  ;;  Danielm103
  (setq nl '()
        i  0
  ) ;_  setq
  (foreach e lst
    (if (= i n)
    ) ;_  if
    (setq i (1+ i))
  ) ;_  foreach
  (reverse nl)
) ;_  defun
;; CAB 11/15/2006
         ) ;_  and
  ) ;_  while
        lst  (cddr lst)
  ) ;_  setq
          lst  (cdr lst)
    ) ;_  setq
  ) ;_  while
  (reverse nlst)
) ;_  defun
  ;; ElpanovEvgeniy
  (mapcar
    (function
      (lambda (x)
        (if (zerop i)
        ) ;_  if
      ) ;_  lambda
    ) ;_  function
    lst
  ) ;_  mapcar
) ;_  defun
;; variation by CAB
  (setq i (1+ i))
               itm
               x
             ) ;_  if
           ) ;_  lambda
          lst
  ) ;_  mapcar
) ;_  defun
  ;; ElpanovEvgeniy
  (if lst
    (if (> i 0)
    ) ;_ if
  ) ;_ if
) ;_  defun
(defun nth-replace (pos new-item lst)
  ;; By: John (Se7en) K 12.27.06
  (if (null lst)
    nil
    (cons
      (if (eq pos 0)
        new-item
        (car lst)
      ) ;_  if
    ) ;_  cons
  ) ;_  if
) ;_  defun
  ;; ElpanovEvgeniy
  (setq c -1)
  (mapcar
    (function cdr)
    ((lambda (l)
       (subst
         (cons 0 itm)
         (assoc i l)
         l
       ) ;_ subst
     ) ;_ lambda
  ) ;_ mapcar
These are results without compilation:
Command:
Command: (LOAD "E:/test.LSP") C:TEST
Command: test
I = 99
Elapsed milliseconds / relative speed for 4096 iteration(s):
    (REPLASE_1 *LIST@ I "A")........1437 / 9.99 <fastest>
    (REPLACE_CAB *LIST@ I "A")......6625 / 2.17
    (REPLASE *LIST@ I "A")..........7187 / 2.00
    (REPLASE_2 *LIST@ I "A").......10265 / 1.40
    (SWAPNTH *LIST@ I "A").........10313 / 1.39
    (NTH-REPLACE I "A" *LIST@).....13812 / 1.04
    (REPLACE_DA "A" I *LIST@)......14359 / 1.00 <slowest>
I = 199
Elapsed milliseconds / relative speed for 2048 iteration(s):
    (REPLASE_1 *LIST@ I "A").......1328 / 5.33 <fastest>
    (REPLACE_CAB *LIST@ I "A").....3234 / 2.19
    (REPLASE *LIST@ I "A").........3656 / 1.94
    (REPLASE_2 *LIST@ I "A").......5141 / 1.38
    (SWAPNTH *LIST@ I "A").........5766 / 1.23
    (NTH-REPLACE I "A" *LIST@).....6906 / 1.02
    (REPLACE_DA "A" I *LIST@)......7078 / 1.00 <slowest>
I = 299
Elapsed milliseconds / relative speed for 1024 iteration(s):
    (REPLASE_1 *LIST@ I "A").......1016 / 3.41 <fastest>
    (REPLACE_CAB *LIST@ I "A").....1672 / 2.07
    (REPLASE *LIST@ I "A").........1828 / 1.90
    (REPLASE_2 *LIST@ I "A").......2531 / 1.37
    (SWAPNTH *LIST@ I "A").........3156 / 1.10
    (NTH-REPLACE I "A" *LIST@).....3391 / 1.02
    (REPLACE_DA "A" I *LIST@)......3469 / 1.00 <slowest>
I = 399
    (REPLASE_1 *LIST@ I "A").......1297 / 2.70 <fastest>
    (REPLACE_CAB *LIST@ I "A").....1672 / 2.09
    (REPLASE *LIST@ I "A").........1781 / 1.97
    (REPLASE_2 *LIST@ I "A").......2594 / 1.35
    (NTH-REPLACE I "A" *LIST@).....3484 / 1.00
    (REPLACE_DA "A" I *LIST@)......3500 / 1.00
    (SWAPNTH *LIST@ I "A").........3500 / 1.00 <slowest>
I = 499
    (REPLACE_CAB *LIST@ I "A").....1578 / 2.53 <fastest>
    (REPLASE_1 *LIST@ I "A").......1657 / 2.40
    (REPLASE *LIST@ I "A").........1813 / 2.20
    (REPLASE_2 *LIST@ I "A").......2610 / 1.53
    (NTH-REPLACE I "A" *LIST@).....3422 / 1.16
    (REPLACE_DA "A" I *LIST@)......3547 / 1.12
    (SWAPNTH *LIST@ I "A").........3985 / 1.00 <slowest>
I = 599
    (REPLACE_CAB *LIST@ I "A").....1671 / 2.58 <fastest>
    (REPLASE *LIST@ I "A").........1829 / 2.36
    (REPLASE_1 *LIST@ I "A").......1969 / 2.19
    (REPLASE_2 *LIST@ I "A").......2532 / 1.70
    (REPLACE_DA "A" I *LIST@)......3468 / 1.24
    (NTH-REPLACE I "A" *LIST@).....3516 / 1.23
    (SWAPNTH *LIST@ I "A").........4313 / 1.00 <slowest>
I = 699
    (REPLACE_CAB *LIST@ I "A").....1641 / 3.06 <fastest>
    (REPLASE *LIST@ I "A").........1828 / 2.74
    (REPLASE_1 *LIST@ I "A").......2281 / 2.20
    (REPLASE_2 *LIST@ I "A").......2563 / 1.96
    (NTH-REPLACE I "A" *LIST@).....3390 / 1.48
    (REPLACE_DA "A" I *LIST@)......3594 / 1.40
    (SWAPNTH *LIST@ I "A").........5016 / 1.00 <slowest>
I = 799
    (REPLACE_CAB *LIST@ I "A").....1593 / 3.58 <fastest>
    (REPLASE *LIST@ I "A").........1829 / 3.12
    (REPLASE_2 *LIST@ I "A").......2609 / 2.19
    (REPLASE_1 *LIST@ I "A").......2625 / 2.17
    (NTH-REPLACE I "A" *LIST@).....3375 / 1.69
    (REPLACE_DA "A" I *LIST@)......3609 / 1.58
    (SWAPNTH *LIST@ I "A").........5703 / 1.00 <slowest>
I = 899
    (REPLACE_CAB *LIST@ I "A").....1562 / 4.08 <fastest>
    (REPLASE *LIST@ I "A").........1828 / 3.49
    (REPLASE_2 *LIST@ I "A").......2610 / 2.44
    (REPLASE_1 *LIST@ I "A").......2938 / 2.17
    (REPLACE_DA "A" I *LIST@)......3328 / 1.92
    (NTH-REPLACE I "A" *LIST@).....3453 / 1.85
    (SWAPNTH *LIST@ I "A").........6375 / 1.00 <slowest>
I = 999
    (REPLACE_CAB *LIST@ I "A").....1421 / 5.00 <fastest>
    (REPLASE *LIST@ I "A").........1813 / 3.92
    (REPLASE_2 *LIST@ I "A").......2547 / 2.79
    (REPLASE_1 *LIST@ I "A").......3313 / 2.15
    (REPLACE_DA "A" I *LIST@)......3454 / 2.06
    (NTH-REPLACE I "A" *LIST@).....3516 / 2.02
    (SWAPNTH *LIST@ I "A").........7110 / 1.00 <slowest>
1099
Command:
These are results after compilation:
Command:
Command: (LOAD "E:/test.VLX") nil
Command: test
I = 99
    (REPLASE_1 *LIST@ I "A")........1719 / 8.83 <fastest>
    (REPLASE *LIST@ I "A")..........7094 / 2.14
    (SWAPNTH *LIST@ I "A")..........8985 / 1.69
    (REPLACE_DA "A" I *LIST@).......9375 / 1.62
    (REPLACE_CAB *LIST@ I "A").....10156 / 1.49
    (NTH-REPLACE I "A" *LIST@).....13047 / 1.16
    (REPLASE_2 *LIST@ I "A").......15172 / 1.00 <slowest>
I = 199
    (REPLASE_1 *LIST@ I "A").......1500 / 5.11 <fastest>
    (REPLASE *LIST@ I "A").........3547 / 2.16
    (REPLACE_DA "A" I *LIST@)......4688 / 1.64
    (REPLACE_CAB *LIST@ I "A").....5110 / 1.50
    (SWAPNTH *LIST@ I "A").........5187 / 1.48
    (NTH-REPLACE I "A" *LIST@).....6500 / 1.18
    (REPLASE_2 *LIST@ I "A").......7672 / 1.00 <slowest>
I = 299
    (REPLASE_1 *LIST@ I "A").......1046 / 3.65 <fastest>
    (REPLASE *LIST@ I "A").........1766 / 2.16
    (REPLACE_DA "A" I *LIST@)......2375 / 1.61
    (REPLACE_CAB *LIST@ I "A").....2516 / 1.52
    (SWAPNTH *LIST@ I "A").........3062 / 1.25
    (NTH-REPLACE I "A" *LIST@).....3250 / 1.17
    (REPLASE_2 *LIST@ I "A").......3813 / 1.00 <slowest>
I = 399
    (REPLASE_1 *LIST@ I "A").......1360 / 2.80 <fastest>
    (REPLASE *LIST@ I "A").........1781 / 2.14
    (REPLACE_DA "A" I *LIST@)......2360 / 1.62
    (REPLACE_CAB *LIST@ I "A").....2547 / 1.50
    (SWAPNTH *LIST@ I "A").........3672 / 1.04
I = 499
    (REPLASE_1 *LIST@ I "A").......1688 / 2.60 <fastest>
    (REPLASE *LIST@ I "A").........1782 / 2.46
    (REPLACE_DA "A" I *LIST@)......2328 / 1.89
    (REPLACE_CAB *LIST@ I "A").....2547 / 1.72
    (NTH-REPLACE I "A" *LIST@).....3265 / 1.34
    (REPLASE_2 *LIST@ I "A").......3828 / 1.15
    (SWAPNTH *LIST@ I "A").........4390 / 1.00 <slowest>
I = 599
    (REPLASE *LIST@ I "A").........1765 / 2.97 <fastest>
    (REPLASE_1 *LIST@ I "A").......2000 / 2.62
    (REPLACE_DA "A" I *LIST@)......2344 / 2.23
    (REPLACE_CAB *LIST@ I "A").....2563 / 2.04
    (NTH-REPLACE I "A" *LIST@).....3265 / 1.60
    (REPLASE_2 *LIST@ I "A").......3828 / 1.37
    (SWAPNTH *LIST@ I "A").........5234 / 1.00 <slowest>
I = 699
    (REPLASE *LIST@ I "A").........1766 / 3.53 <fastest>
    (REPLASE_1 *LIST@ I "A").......2297 / 2.71
    (REPLACE_DA "A" I *LIST@)......2344 / 2.66
    (REPLACE_CAB *LIST@ I "A").....2547 / 2.45
    (NTH-REPLACE I "A" *LIST@).....3266 / 1.91
    (REPLASE_2 *LIST@ I "A").......3828 / 1.63
    (SWAPNTH *LIST@ I "A").........6235 / 1.00 <slowest>
I = 799
    (REPLASE *LIST@ I "A").........1781 / 4.13 <fastest>
    (REPLACE_DA "A" I *LIST@)......2344 / 3.14
    (REPLACE_CAB *LIST@ I "A").....2563 / 2.87
    (REPLASE_1 *LIST@ I "A").......2625 / 2.80
    (NTH-REPLACE I "A" *LIST@).....3250 / 2.26
    (REPLASE_2 *LIST@ I "A").......3859 / 1.91
    (SWAPNTH *LIST@ I "A").........7359 / 1.00 <slowest>
I = 899
    (REPLASE *LIST@ I "A").........1766 / 4.88 <fastest>
    (REPLACE_DA "A" I *LIST@)......2344 / 3.67
    (REPLACE_CAB *LIST@ I "A").....2547 / 3.38
    (REPLASE_1 *LIST@ I "A").......2922 / 2.95
    (NTH-REPLACE I "A" *LIST@).....3265 / 2.64
    (REPLASE_2 *LIST@ I "A").......3844 / 2.24
    (SWAPNTH *LIST@ I "A").........8610 / 1.00 <slowest>
I = 999
    (REPLASE *LIST@ I "A").........1781 / 5.61 <fastest>
    (REPLACE_DA "A" I *LIST@)......2343 / 4.26
    (REPLACE_CAB *LIST@ I "A").....2578 / 3.87
    (REPLASE_1 *LIST@ I "A").......3235 / 3.09
    (NTH-REPLACE I "A" *LIST@).....3250 / 3.07
    (REPLASE_2 *LIST@ I "A").......3860 / 2.59
    (SWAPNTH *LIST@ I "A").........9984 / 1.00 <slowest>
1099
Command:
« Reply #42 on: December 31, 2006, 08:09:33 AM »
Thanks Evgeniy,
You can now see how the position of the index in the list affects the time required.
Also the compiling surprised me as I thought it would be a uniform change in the speed & not the order.
Funny how some methods fair better when compiled.
ElpanovEvgeniy
  • Moscow (Russia)
« Reply #43 on: December 31, 2006, 09:09:17 AM »
Thanks Evgeniy,
I wish to give you a small gift by new year...  :-)  :-)  :-)
  ;; variation by CAB
  (setq i (1+ i))
               itm
               x
             ) ;_  if
           ) ;_  lambda
          lst
  ) ;_  mapcar
) ;_  defun
(defun replace_CAB_optim (lst i itm)
  ;; variation by CAB
  (setq i (1+ i))
  (mapcar
    (function
      (lambda (x)
          itm
          x
        ) ;_  if
      ) ;_  lambda
    ) ;_  function
    lst
  ) ;_  mapcar
) ;_  defun
  (if (not *List@)
    (repeat 10
      (setq Cnt# 48)
      (repeat 100
      ) ;repeat
    ) ;repeat
  ) ;_  if
  (setq i 99)
  (repeat 10
    (BenchMark
      '((replace_CAB *List@ i "A")
        (replace_CAB_optim *List@ i "A")
    ) ;_  BenchMark
    (setq i (+ i 100))
  ) ;_  repeat
) ;_  defun
not compiled
Command: (LOAD "E:/test_1.LSP") C:TEST
Command: test
I = 99
    (REPLACE_CAB *LIST@ I "A")...........1453 / 1.03 <fastest>
    (REPLACE_CAB_OPTIM *LIST@ I "A").....1500 / 1.00 <slowest>
I = 199
    (REPLACE_CAB *LIST@ I "A")...........1407 / 1.07 <fastest>
I = 299
    (REPLACE_CAB *LIST@ I "A")...........1422 / 1.02 <fastest>
    (REPLACE_CAB_OPTIM *LIST@ I "A").....1454 / 1.00 <slowest>
I = 399
    (REPLACE_CAB *LIST@ I "A")...........1406 / 1.04 <fastest>
    (REPLACE_CAB_OPTIM *LIST@ I "A").....1469 / 1.00 <slowest>
I = 499
    (REPLACE_CAB *LIST@ I "A")...........1422 / 1.03 <fastest>
I = 599
I = 699
    (REPLACE_CAB *LIST@ I "A")...........1407 / 1.06 <fastest>
    (REPLACE_CAB_OPTIM *LIST@ I "A").....1485 / 1.00 <slowest>
I = 799
    (REPLACE_CAB *LIST@ I "A")...........1406 / 1.06 <fastest>
    (REPLACE_CAB_OPTIM *LIST@ I "A").....1484 / 1.00 <slowest>
I = 899
    (REPLACE_CAB *LIST@ I "A")...........1422 / 1.04 <fastest>
I = 999
    (REPLACE_CAB_OPTIM *LIST@ I "A").....1453 / 1.00 <slowest>
1099
Command:
after compiled
Command:
Command: (LOAD "E:/test_1.VLX") nil
Command: test
I = 99
    (REPLACE_CAB_OPTIM *LIST@ I "A").....1719 / 1.47 <fastest>
    (REPLACE_CAB *LIST@ I "A")...........2531 / 1.00 <slowest>
I = 199
    (REPLACE_CAB_OPTIM *LIST@ I "A").....1734 / 1.48 <fastest>
    (REPLACE_CAB *LIST@ I "A")...........2563 / 1.00 <slowest>
I = 299
    (REPLACE_CAB_OPTIM *LIST@ I "A").....1672 / 1.51 <fastest>
I = 399
    (REPLACE_CAB_OPTIM *LIST@ I "A").....1671 / 1.48 <fastest>
    (REPLACE_CAB *LIST@ I "A")...........2469 / 1.00 <slowest>
I = 499
    (REPLACE_CAB_OPTIM *LIST@ I "A").....1671 / 1.52 <fastest>
    (REPLACE_CAB *LIST@ I "A")...........2532 / 1.00 <slowest>
I = 599
    (REPLACE_CAB_OPTIM *LIST@ I "A").....1687 / 1.46 <fastest>
I = 699
    (REPLACE_CAB_OPTIM *LIST@ I "A").....1672 / 1.52 <fastest>
    (REPLACE_CAB *LIST@ I "A")...........2546 / 1.00 <slowest>
I = 799
    (REPLACE_CAB_OPTIM *LIST@ I "A").....1703 / 1.45 <fastest>
I = 899
    (REPLACE_CAB_OPTIM *LIST@ I "A").....1688 / 1.49 <fastest>
    (REPLACE_CAB *LIST@ I "A")...........2516 / 1.00 <slowest>
I = 999
    (REPLACE_CAB_OPTIM *LIST@ I "A").....1671 / 1.50 <fastest>
    (REPLACE_CAB *LIST@ I "A")...........2500 / 1.00 <slowest>
1099
Command:
I congratulate on coming new year!
Let new year will bring a lot of pleasure and happiness!
Happy New Year!
« Reply #44 on: December 31, 2006, 01:21:25 PM »
Thank you Sir. :)
And may you experience the same.
So, FUNCTION pays speed dividends. 8-)
