That trick with the AutoCAD display sounds very familiar . . .
We have the same trainer.
OK, here's my impressions. First, the bad stuff...
It is now crystal-clear why I was having trouble with Civil-3D. The user interface is tolerable from a design point-of-view - not great, but I've seen worse. There's a few pieces that are particularly obtuse, leaving us wondering "what the hell were they thinking?", but other parts of it show excellent design. Unfortunately, the execution of the design is TERRRIBLE. Civil-3D is filled with inconsistent behavior in dialog boxes, and dialog boxes that serve no valid purpose. The worst are the tiny dialog boxes that can't be resized, even though they are crammed full of little sub-windows with scroll bars in them. Autodesk won't let you resize the dialog boxes - instead, you get this
little tiny area to work in. And then there's all the critical functions that are "hidden" until you "summon" them... Then once summoned, they stay visible and easy-to-find, even when Civil-3D is shut down and restarted. But when you first get Civil-3D out-of-the-box, GOOD LUCK trying to find some of them on your own...
The absolute worst is the documentation. Those things that Autodesk calls "Tutorials" should actually be called "Demos". They do ABSOLUTELY NOTHING to teach anyone how to use the product. No wonder I was lost, trying to use them... Anyone trying to learn Civil-3D from the Autodesk documentation and tutorials, I'm telling you right now you might as well give up. CRITICAL INFO CANNOT BE FOUND THERE.
And that doesn't even touch on how unreliable the software is. We had quite a few corrupted drawings, where EVERYTHING was lost, just in the course of the class. And since all project information now resides inside of DWG files, losing a DWG file is much worse than it was in Land Desktop. The frequency of this occurrance is so great that it severely impacts the value of the product. It is right on the borderline of being SO BAD that the software is unusable. However, it is stable enough that, AS LONG AS THE USER SAVES MULTIPLE COPIES OF THE FILE FREQUENTLY, it can be used.
There's a little dance that's required. Obviously, AutoCAD's Autosave and Recover options cannot be trusted - they fail at least half the time. As such, they rank right up there with some of Autocad's most useless features - not because they are bad ideas, but because the implementation is so poor that they can't be relied upon. And .BAK files don't work, either, because they are always one version behind. So the safest thing is to always keep two copies of your DWG file (e.g. "MyFile.dwg" and "MyFileBAK.dwg", and VERY FREQUENTLY, do a "SAVE AS" to first the backup DWG file, then immediately do another "SAVE AS" to the main DWG file. That way, when the main DWG file gets corrupted (and it WILL get corrupted), you still have the other one to fall back on. You can also try hitting "SAVE" twice, so you know the .BAK file that Autocad creates is up-to-date, but that .BAK file can still get lost if the user is careless. So it's safer to just always SAVE AS two different DWG files.
Then there's all those little things that just prove that Autodesk programmers don't actually USE their own product, e.g. the command line goes away when no drawing is open. And Project Management is basically left to the user - even the pathetic Project Management features that existed in Land Desktop no longer exist. That's a HUGE step backwards. And it basically seems like Surveyors are largely left out to dry - Autodesk really screwed the pooch when it comes to supporting calculating points for field-staking. There is NO way to set Cogo points on feature lines, and have the point get its elevation from the feature line. Little details like this really show that Autodesk is living up to it's nickname of "the 80% solution" - they get you 80% of the way there, then drop the ball...
But then there's the good stuff...
Working with intelligent, 3D entities instead of dumb, 2D linework is an ABSOLUTE JOY! And tasks that were inexplicably obtuse and difficult-to-perform in Land Desktop are now a breeze. Even with all the many, many flaws in the current product, it is obvious that we will be able to save a lot of time with C3D. Unfortunately, we may need to drop down into Land Desktop sometimes in order to perform many of our field calcs, because Autodesk did some REAL BONEHEAD THINGS, but I might be able to fix that with some judicious coding (if I can sort through all the broken and incomplete developer documentation well enough - another place where Autodesk really dropped the ball). And of course, our trainer is really bugged now by this issue (he HATES not having the answer to a problem), and has sworn that if there's any other possible workaround for issue, he'll find it...
I know I already don't want to start up Land Desktop anymore. I'm tired of fighting that old, tired software, that Autodesk has refused to improve since 2000. In comparison, C3D is FUN! Too bad it crashes so much...
