No ![smiley :-)](https://www.theswamp.org/Smileys/black/smiley.gif)
We're not using it at all. I did ask the boss once when I first got here and it sounded like it was more trouble than its worth if a project has allot subs involved. I don't know, but if you're saying its a worth while tool maybe I should do some lunch time studying.
I thought it was relatively simple to get working. That was in 2006, though - don't know how much or if it changed from the 2005 version. (I now use the 2007 version.)
SSM + Fields have saved us tons of time. Our title blocks are preconfigured so that they automatically attach to the correct fields in the Sheet Set, eliminating a ton of typing. Changing the issue date of an entire set of plans is as simple as changing one field in the SSM and hitting PUBLISH. Plus, no more of those silly errors, where one page on a set of plans has the wrong issue date or wrong number of pages, etc. And now, when the boss comes in and says "I need a copy of such and such...", I don't even have to interrupt what I'm doing. Without closing or opening any drawings, I just right-click on the sheet set in the SSM and publish it to the plotter (or publish it to the laser printer reduced to Ledger size using a Page Setup Override, or publish it to PDF, also with a page setup override). (The SSM can have multiple sheet sets open simultaneously, and it doesn't care... This is a big plus for us Land Desktop users, who are used to being stuck in SDI mode...) I can even publish multiple copies of an entire sheet set with a single command - no need to "babysit".
Sheet Sets also make it much easier to navigate through files from another company. On those rare occasions I get an Etransmit of a sheet set from another firm, it is always so much easier to find what I need, especially when the plan set contains 30 or 50 or 100 pages, and almost twice that many DWG files...
Unfortunately, the ability to "browse" a sheet set from the SSM, i.e. open a DWG file by clicking on the sheet in the SSM, was broken in Land Desktop 2007, but it's now possible to publish straight out of Land Desktop (instead of being forced to use Map to PUBLISH), so it's something of a wash.
