Author Topic: Reload Xrefs Lisp...  (Read 3256 times)
david
« on: October 09, 2006, 04:12:31 PM »
Does anyone have a lisp routine, they don't mind sharing, that will reload all the xrefs in a drawing without having to go through the xref manager and select each one.
Greg B
  • Tell me a Joke!
Re: Reload Xrefs Lisp...
« Reply #1 on: October 09, 2006, 04:21:15 PM »
Huh....standard feature in DataCAD
David Hall
  • Automatic Duh Generator
« Reply #2 on: October 09, 2006, 04:38:42 PM »
-xref;r;all;;
as a macro or
CADaver
« Reply #3 on: October 09, 2006, 10:01:38 PM »
(defun c:xre ()
(prompt "\N Select Element in XREF to RELOAD  ")
(xref-unload "reload")
(defun c:xru ()
(prompt "\N Select Element in XREF to UNLOAD  ")
(xref-unload "unload")
(defun c:xrd ()
(prompt "\N Select Element in XREF to DETACH  ")
(xref-unload "detach")
(defun xref-unload ( xref-action / old setlgth co t2 temp blkname)
(command ".undo" "BEGIN")
   (setvar "cmdecho" 0)
      (setq
        old (ssget)
        setlgth (sslength old)
        co -1
        t2 "t"
  (while (boundp 't2)
       (setq
         co (1+ co)
         temp (entget (ssname old co))
         blkname (cdr (assoc 2 temp))
         t2 (ssname old (1+ co))
         (command "-xref" xref-action blkname)
       )      ;; end progn
   )          ;; end while
(setq co (1+ co))
(command ".undo" "END")
david
« Reply #4 on: October 10, 2006, 11:18:49 AM »
Thanks CADaver... works Great!
CADaver
« Reply #5 on: October 10, 2006, 01:16:40 PM »
you're welcome
