Open new drawing w/ no special template.
Created three layers; monuments, points and text.
Inserted my found monument block.
Created a new "Point Style" called 'monuments'.
---- "Marker" is set to block.
---- Under "Display", "Marker" is set to 'monuments' layer, "Label" is on '0' layer.
![](http://www.theswamp.org/screens/mark/screen_shots/c3d_points_display.png)
![](http://www.theswamp.org/screens/mark/screen_shots/c3d_points_point_label.png)
Insert some new points at random places in my dwg.
Created a new "Point Group" called 'found'.
---- changed "Point Style" to 'monuments'
---- left "Point Label Style" on 'Standard'
![](http://www.theswamp.org/screens/mark/screen_shots/c3d_points_group.png)
If I freeze or turn off '0' layer I lose everything, nodes and blocks. Also the center of the block, the solid hatch, doesn't show.
![](http://www.theswamp.org/screens/mark/screen_shots/c3d_points_dwg.png)
