Thank you bert'
You means the 3d operation are very associated with the view, can I calculate the 3d point coordinate and then apply it in the plane view?
could I ask one more question, could the following pic be drawn by autocad?
It is a steel space joint, 7 box beam connect at one point, then complicate intersect line produced, and this entity must be solid so that it could be imported into finite element analysis.
I try to write some rountine, but fail, I think it maybe model by SOLIDWORK or UG or PROE or CATIA. I try to model it in CATIA, but I am not family with it, so also fail.
could you tell me is it possible to draw it by autocad( include rountine)
