Author Topic: subtracting vertices of group of polylines  (Read 6628 times)
bprabhakar001
« on: August 25, 2006, 11:49:32 PM »
Dear All,
I have a written a program to identify the vertices which are not identical from overlapping each polylines.
But it gives peculate result. I did not have where exactly problem exist.
Would you please some one help me to rectify the problem. And also I requesting you please suggest the method to solve this. Because if the dwg having more data it was taking couple of processing time some time hanging also.
I am very glad to here the corrections.
Thanking U,
Prabhakar.B
<contact information removed>
« Last Edit: August 26, 2006, 12:08:40 AM by DinØsaur »
ElpanovEvgeniy
  • Moscow (Russia)
Re: subtracting vertices of group of polylines
« Reply #1 on: August 26, 2006, 10:46:04 AM »
(defun c:test-lw (/ a1 a2 l)
  (if (and (setq a1 (ssget "_X" '((0 . "POLYLINE,LWPOLYLINE") (8 . "*Trails Routes_*"))))
           (setq a2 (ssget "_X" '((0 . "POLYLINE,LWPOLYLINE") (8 . "*Trails_*"))))
      ) ;_  and
      (setq a1 (mapcar (function cadr) (ssnamex a1))
            a2 (mapcar (function cadr) (ssnamex a2))
      ) ;_  setq
        (foreach x a1
          (foreach x1 a2
              (and (equal (distance (vlax-curve-getclosestpointto x (vlax-curve-getStartPoint x1))
                          ) ;_  distance
                          0.
                          1e-8
                   ) ;_  equal
                   (equal (distance (vlax-curve-getclosestpointto x (vlax-curve-getEndPoint x1))
                          ) ;_  distance
                          0.
                          1e-8
                   ) ;_  equal
              ) ;_  and
                 (setq a2 (vl-remove x1 a2))
                 (foreach x2 (mapcar
                               (function cdr)
                               (vl-remove-if-not (function (lambda (b) (= (car b) 10))) (entget x1))
                             ) ;_  mapcar
                   (if (not (equal (distance (vlax-curve-getclosestpointto x x2) x2)
                                   0.
                                   1e-8
                            ) ;_  equal
                       ) ;_  not
                     (setq l (cons x2 l))
                   ) ;_  if
                 ) ;_  foreach
               ) ;_  progn
            ) ;_  if
          ) ;_  foreach
        ) ;_  foreach
        (foreach x a1
          (foreach x2 l
            (if (equal (distance (vlax-curve-getclosestpointto x x2) x2) 0. 1e-8)
              (setq l (vl-remove x2 l))
            ) ;_  if
          ) ;_  foreach
        ) ;_  foreach
        (foreach x l
          (entmakex
            (list
              '(0 . "CIRCLE")
              '(8 . "ERROR-DIST")
              '(62 . 1)
              (cons 10 x)
              '(40 . 0.0005)
            ) ;_  list
          ) ;_  entmakex
        ) ;_  foreach
      ) ;_  progn
    ) ;_  progn
  ) ;_  if
« Reply #2 on: August 26, 2006, 11:18:34 AM »
Evgeniy you beat me to it. :)
Here is my attempt.
(defun c:ver (/ echo osmode)
  (defun getlwpolylinecoords (ent / idx pt result)
    (setq idx -1)
    (while (setq pt (vlax-curve-getpointatparam ent (setq idx (1+ idx))))
      (setq result (cons pt result))
    (reverse result)
  (defun get_vertex (lyr / ss coor result)
    (if (setq ss (ssget "_X" (list '(0 . "POLYLINE,LWPOLYLINE") (cons 8 lyr))))
      (mapcar '(lambda (x)
                 (if (setq coor (getlwpolylinecoords x))
                   (if result
                     (setq result (append coor result))
                     (setq result coor)
              (mapcar 'cadr
                      (ssnamex ss)
    result
  ;;  Subtract two point list given a max distance
  ;;  CAB 08/26/2006
  (defun return_unique_points (lst1 lst2 max_distance / tmp)
    (setq tmp lst2)
    (mapcar
      '(lambda (x)
         (setq lst2 (vl-remove-if '(lambda (y) (< (distance x y) max_distance)) lst2))
      lst1
    (mapcar
      '(lambda (x)
         (setq lst1 (vl-remove-if '(lambda (y) (< (distance x y) max_distance)) lst1))
      tmp
    (append lst2 lst1)
  (defun mark (lst r)
    (mapcar
      '(lambda (pt)
         (entmake
           (list (cons 0 "CIRCLE")
                 (cons 6 "BYLAYER")
                 (cons 8 "ERROR")
                 (cons 10 pt)
                 (cons 40 r)
                 (cons 62 1) ; RED
                 (cons 210 (list 0.0 0.0 1.0))
      lst
  ;;  Begin Here
  (command "undo" "be")
  (setq echo   (getvar "cmdecho")
        osmode (getvar "osmode")
  (setvar "CMDECHO" 0)
  (setvar "OSMODE" 0)
  (setq rad 0.0004) ; Circle for test
  (setq max_dist 0.0000001) ; **  max distance for error of points
    (and
      (or (setq trail (get_vertex "*TRAIL*"))
          (prompt "\nNo trail features selected\n")
      (or (setq route (get_vertex "*ROUTE*"))
          (prompt "\nNo route features selected\n")
      (prompt "\n * * * Working, Please Wait........\n")
     (if (setq mis_match (return_unique_points trail route max_dist))
       (mark mis_match rad)
  (setvar "CMDECHO" echo)
  (setvar "OSMODE" osmode)
  (command "undo" "end")
(repeat 3 (print))
(princ
  "\n\t\lsp loaded.............Proceed with \"VER\"."
ElpanovEvgeniy
  • Moscow (Russia)
« Reply #3 on: August 26, 2006, 11:31:12 AM »
Here is my attempt.
Excuse! I did not wish to offend.  :-(
I probably have hastened, I needed to wait for all a floor of hour...
« Reply #4 on: August 26, 2006, 12:13:46 PM »
Evgeniy
You did not offend me. I was joking around.
I enjoy all your post and learn from them, thanks for participating, and keep up the good work.
Alan
ElpanovEvgeniy
  • Moscow (Russia)
« Reply #5 on: August 26, 2006, 12:17:05 PM »
Evgeniy
Alan
Alan
I too study, but already for you!  :-)
bprabhakar001
« Reply #6 on: August 28, 2006, 03:27:26 AM »
Thanking you both,
Mr. Cab your program is giving exact results what am I trying.
At the same time Mr.ElpanovEvgeniy program is running with superb fast. But it was giving errors only where trail vertex differing.
It is fails when overlapping route missing/extra vertex in route list.
Thanking you very much. I am trying to get such a speed from ElpanovEvgeniy program and the desired results from Mr. Cab.
I requesting you please guide me.
Thanking you,
Prabhakar.B
ElpanovEvgeniy
  • Moscow (Russia)
« Reply #7 on: August 28, 2006, 04:28:17 AM »
Thanking you both,
Thanking you,
Prabhakar.B
(defun c:test-lw (/ a1 a2 x)
      ) ;_  and
            a2 (mapcar
                 (function
                   (lambda (x / e i l)
                     (setq e (vlax-curve-getEndParam x)
                           i 0
                     ) ;_  setq
                     (while (< i e)
                       (setq l (cons (vlax-curve-getPointAtParam x i) l)
                             i (+ i 0.5)
                       ) ;_  setq
                     ) ;_  while
                     l
                   ) ;_  lambda
                 ) ;_  function
               ) ;_  mapcar
      ) ;_  setq
      (foreach x a1
        (setq a2
               (vl-remove-if
                 (function null)
                 (mapcar
                   (function
                     (lambda (x2)
                       (while
                         (and
                           (car x2)
                           (equal (distance (vlax-curve-getclosestpointto x (car x2))
                                            (car x2)
                                  ) ;_  distance
                                  0.
                                  1e-8
                           ) ;_  equal
                         ) ;_  and
                          (setq x2 (cdr x2))
                       ) ;_  while
                       (vl-remove-if (function null) x2)
                     ) ;_  lambda
                   ) ;_  function
                   a2
                 ) ;_  mapcar
               ) ;_  vl-remove-if
        ) ;_  setq
      ) ;_  foreach
      (setq a2 (apply (function append) a2))
      (foreach x a1
        (foreach x2 a2
            (setq a2 (vl-remove x2 a2))
          ) ;_  if
        ) ;_  foreach
      ) ;_  foreach
      (foreach x a2
        (entmakex
          (list
            '(0 . "CIRCLE")
            '(8 . "ERROR-DIST")
            '(62 . 1)
            (cons 10 x)
            '(40 . 0.0005)
          ) ;_  list
        ) ;_  entmakex
      ) ;_  foreach
    ) ;_  progn
  ) ;_  if
Hangman
« Reply #8 on: August 30, 2006, 12:06:00 PM »
Wow !!!  You guys are good !!!    :kewl:
Hangman  8)
bprabhakar001
Re: subtracting vertices of group of polylines(error detecting)
« Reply #9 on: September 04, 2006, 07:36:17 AM »
Dear All,
I am afraid am unable to find the some of the attached referenced dwg.
I requesting you please kindly resolve that.
Thanking you,
Prabhakar.B
ElpanovEvgeniy
  • Moscow (Russia)
« Reply #10 on: September 05, 2006, 07:06:06 AM »
Dear All,
Thanking you,
Prabhakar.B
Only as an example...
(defun c:test-lw (/ A1 A2 P X)
    (foreach x (del-pt1
                 (mapcar
                   (function cdr)
                   (vl-remove-if-not
                     (function
                       (lambda (b)
                         (= (car b) 10)
                       ) ;_  lambda
                     ) ;_  function
                     (apply
                       (function append)
                       (mapcar
                         (function entget)
                       ) ;_  mapcar
                     ) ;_  apply
                   ) ;_  vl-remove-if-not
                 ) ;_  mapcar
                 (mapcar
                   (function cdr)
                   (vl-remove-if-not
                     (function
                       (lambda (b)
                         (= (car b) 10)
                       ) ;_  lambda
                     ) ;_  function
                     (apply
                       (function append)
                       (mapcar
                         (function entget)
                       ) ;_  mapcar
                     ) ;_  apply
                 ) ;_  mapcar
               ) ;_  del-pt1
      (entmakex
        (list
          '(0 . "CIRCLE")
          '(8 . "ERROR-DIST")
          '(62 . 1)
          (cons 10 x)
          '(40 . 0.0005)
        ) ;_  list
      ) ;_  entmakex
    ) ;_  foreach
  ) ;_  if
) ;_  defun
(defun del-pt1 (lst1 lst2)
  (if (and lst1 lst2)
    (if (vl-member-if
          (function
            (lambda (a)
              (equal (distance (car lst2) a) 0. 1e-8)
            ) ;_  lambda
          ) ;_  function
          lst1
        ) ;_  vl-member-if
      (del-pt1
        (vl-remove-if
          (function
            (lambda (a)
            ) ;_  lambda
          ) ;_  function
          lst1
        ) ;_  vl-remove-if
        (vl-remove-if
          (function
            (lambda (a)
            ) ;_  lambda
          ) ;_  function
          (cdr lst2)
        ) ;_  vl-remove-if
      ) ;_  del-pt1
      (cons
        (car lst2)
        (del-pt1
          (vl-remove-if
            (function
              (lambda (a)
              ) ;_  lambda
            ) ;_  function
            lst1
          ) ;_  vl-remove-if
          (vl-remove-if
            (function
              (lambda (a)
              ) ;_  lambda
            ) ;_  function
            (cdr lst2)
          ) ;_  vl-remove-if
        ) ;_  del-pt1
      ) ;_  cons
    ) ;_  if
    (if (or lst1 lst2)(append lst1 lst2))
  ) ;_  if
) ;_  defun
bprabhakar001
« Reply #11 on: September 05, 2006, 08:58:58 AM »
Great, I appreciate your efforts. I don’t' know how can I useful for u my friend.
Thanking you very much you and to this Org.
I will upload all the source code what am I having since 6 years. Any one could help to commenting or functions separation is welcome.
Best Regards,
Prabhakar.B
ElpanovEvgeniy
  • Moscow (Russia)
« Reply #12 on: September 05, 2006, 09:12:47 AM »
Best Regards,
Prabhakar.B
I today have spent only 10 minutes for your problem...   :-o
