Hi Tim,
I tried what you suggested. Manually repath an image without using the save path button.
Yes, a new image replaces the original, but the path property remains unchanged. Save the
file, close and reopen. The original image reappears.
I think this is similar to the fact you can attach an xref which resides in some folder
other than the folder where the active file resides without saving the path. But after
save, close and reopen the xref can't be found.
So it makes sense, to me anyway, that the path property doesn't change unless you use
If you still want to get the temporary path, I don't know how you'd do that.
