Author Topic: trouble with a shape file  (Read 6453 times)
drizzt
« on: August 21, 2006, 04:37:20 PM »
I am trying to insert a shape file into a CAD drawing (LDD2000). I am ignoring data elemts with no coordinate conversion. when I try to import, CAD locks up. My processor is at 99%. I even tried to let it run all night!
Any ideas on this?
drizzt
Re: trouble with a shape file
« Reply #1 on: August 23, 2006, 12:37:34 PM »
Anyone know of a good program to convert a shape file to DXF??
Dinosaur
« Reply #2 on: August 23, 2006, 12:52:03 PM »
I don't know much about importing SHP files and nothing about working with them in 2000, but if you can post the thing, I will try to get it to work.
-edit-
scratch that - now I see the attached file.  I will see what I can do with it. :oops:
« Last Edit: August 23, 2006, 12:55:51 PM by DinØsaur »
Dinosaur
« Reply #3 on: August 23, 2006, 01:23:35 PM »
OK, 2006 was REAL cranky about it but I imported the shape into a drawing file.  Here is the r2000 DWG file - I have a DXF if you need it but it is almost 6mb
drizzt
« Reply #4 on: August 23, 2006, 01:53:52 PM »
Dino,
this is the second time you have saved me!!!! Thanks a million!
I will let you know how it works.. give me a minute.
drizzt
« Reply #5 on: August 23, 2006, 02:00:50 PM »
I get this fatal error when I try to open, tried to do a recovery with no luck.
unhandled c00000fdh Exception at 920927h
Any ideas?
nivuahc
« Reply #6 on: August 23, 2006, 02:04:25 PM »
Not sure if it will help but I did a massive purge and saved it as R2000 for ya
nivuahc
« Reply #7 on: August 23, 2006, 02:06:06 PM »
That massive purge sure didn't get rid of a lot, did it?  :laugh:
Dino: RCZ.dwg (1535.2 KB - downloaded 2 times.)
Mine: RCZ.dwg (1524.76 KB - downloaded 0 times.)
drizzt
« Reply #8 on: August 23, 2006, 02:14:08 PM »
No more fatal error, but the CPU maxes out, but CAD is still running. I will try to let it run for a while and see what happens.
Dinosaur
« Reply #9 on: August 23, 2006, 02:17:23 PM »
I zipped up the DXF for you
drizzt
« Reply #10 on: August 23, 2006, 02:25:05 PM »
The dxf has the fatal error also.
I have a 1.85 ghz processor with 1.5gb ram
Dinosaur
« Reply #11 on: August 23, 2006, 02:29:06 PM »
Just for grins, I tried a purge and got no change at all.  Then I saved the file and it grew larger.
The thing only has 38 polylines in it on one layer - I don't know what is taking up the space.
There must be something wrong in translating to the old formats, 2006 opens it with no problems.
drizzt
« Reply #12 on: August 23, 2006, 02:36:31 PM »
This might be a lot to ask, but can you save maybe half of the polylines in a block for me?
Dinosaur
« Reply #13 on: August 23, 2006, 02:43:36 PM »
Try this first,  I saved it down with DWGGateway
Dinosaur
« Reply #14 on: August 23, 2006, 02:49:55 PM »
If that doesn't work, here are the two major drainages in 2000
