Author Topic: how do i keep this loaded.  (Read 5071 times)
hudster
« on: March 26, 2004, 07:58:49 AM »
I have a lisp which lets me draw circuit lines.
I've changed the code to allow me to input the drawing scale so that it sizes the circuit lines according to the drawing scale.
but each time i run the routine it asks me to input the scale, is there a way in which i can make it default to the last scale used, rather than having to input each time.
(initget (+ 1 2 4))
     (setq #d (getint "\nDrawing Scale: "))
   (setq #dist (* #D 5.75 )
« Reply #1 on: March 26, 2004, 08:14:14 AM »
You could make the variable global and test for it's existence in the program.
(if (not #d)
    (initget (+ 1 2 4))
    (setq #dist (* #D 5.75))
  ;else
hudster
« Reply #2 on: March 26, 2004, 10:54:00 AM »
Cheers mate.
you are a star.  Works great.
DEVITG
« Reply #3 on: March 26, 2004, 05:21:15 PM »
It works great, but , could be possible to use userrx to store the last scale used , does not matter if the lisp is unloaded or not???
hudster
« Reply #4 on: March 26, 2004, 05:49:56 PM »
I'm already using userr1 to store the scale for insertion of a few blocks.
would i be able to change this to show userr1 = #d?
This would be a lot better, as it would exclude the possibility of a typo.
« Reply #5 on: March 26, 2004, 05:52:29 PM »
If you are going to store a bunch of var's, wht not store them in a file then read them in when you start the program.
hudster
« Reply #6 on: March 27, 2004, 04:32:02 AM »
the userr1 variable was set up by someone else in my company, and it's already stored in a file so that it is loaded with each drawing.
if it enter (getvar userr1), it returns the drawing scale.
So can i take it by that, I can use it in the lisp routine?
« Reply #7 on: March 27, 2004, 07:33:45 AM »
sure.
daron
« Reply #8 on: March 27, 2004, 10:51:03 PM »
Don't forget there are 4 other userr# variables. Just use one of them.
hendie
« Reply #9 on: March 29, 2004, 02:44:49 AM »
there's also SETCFG & GETCFG which can be useful
« Reply #10 on: March 29, 2004, 08:10:34 AM »
You can also use SETENV and GETENV
SMadsen
« Reply #11 on: March 29, 2004, 01:35:25 PM »
XData? LData? Dictionaries? Registry?
Don't forget a USERIx can hold up to 4 decimals ..
*ok, so I like to overdo it .. so what?!*
« Reply #12 on: March 29, 2004, 04:00:21 PM »
To fill a global variable full of values I like to use an association list.
(defun var-store (var value)
  (cond ((and value) (cons var value))))
(defun test (lst)
    ((>= (length lst) 2)
     ;; if there are atleast two left in the list
     (setq a (cons (var-store (car lst) (cadr lst)) a))
     ;; construct a list
     (test (cdr (cdr lst)))))
  a
  ;; Return the list
Use it like this:
(reverse (test '(test1 1 test2 2 test3 3 test4 4)))
-> ((TEST1 . 1) (TEST2 . 2) (TEST3 . 3) (TEST4 . 4))
But if you cant create the variables at run-time or ask the user I sudgest a file, regristry, or x/l data. I would try to stay away form the Users variables.
