Keeping it simple.
Say I've made a point. If I select the point and look at the properties palette it will give me its X and Y coordinates.
All I'm trying to do is create a block (or mvb) that when I drag it in from the design center and select the point, the block will graphically display the coordinates.
I had figured there would be a location or position property set within the default property sets (especially for point objects) but I can't find it. If you know where it is or have an idea how I could execute my plan I'd appreciate hearing it.
Thanks,
Ryan
