Author Topic: moving a drawing to 0,0  (Read 8412 times)
Re: moving a drawing to 0,0
« Reply #15 on: July 27, 2006, 01:30:15 PM »
All blocks in the drawings have been exploded so that they can be changed.
No need for this.  You can change them with code.
lispman21
« Reply #16 on: July 27, 2006, 01:41:08 PM »
Ok whether or not it really matters they have already been exploded so maybe that makes it easier or not.
« Reply #17 on: July 27, 2006, 05:15:25 PM »
Then make sure all the layers are thawed, unlocked, and turned on, and see if this works for you.
(defun c:MoveTo0 ()
(command "_.regenall")
(command "_.move" "_all" "" (getvar "extmin") '(0.0 0.0 0.0))
ps. Make sure you are in model space.
lispman21
« Reply #18 on: July 28, 2006, 07:28:00 AM »
No, I am sorry the previous code did not work.  Infact it didn't move a single thing inthe drawing to (0,0,0).  But worth a shot.
ElpanovEvgeniy
  • Moscow (Russia)
« Reply #19 on: July 28, 2006, 08:16:10 AM »
(defun c:test-1 (/ p1 p0)
  (setq p1 (vlax-3d-point
             (car
               (acet-geom-ss-extents
                 (ssget "_X")
                 t
               ) ;_  acet-geom-ss-extents
             ) ;_  car
           ) ;_  vlax-3d-point
        p0 (vlax-3d-point 0 0)
  ) ;_  setq
  (VLAX-FOR x (vla-get-modelspace
                (vla-get-activedocument
                  (vlax-get-acad-object)
                ) ;_  vla-get-activedocument
              ) ;_  vla-get-modelspace
    (vla-move x p1 p0)
    (vla-update x)
  ) ;_  VLAX-FOR
) ;_  defun
(defun lst-getboundingbox (lst)
  (if (and lst (listp lst))
    ((lambda (x)
       (list
         (apply
           (function mapcar)
           (cons
             (function min)
             (mapcar (function car) x)
           ) ;_  cons
         ) ;_  apply
         (apply
           (function mapcar)
           (cons
             (function max)
             (mapcar (function cadr) x)
           ) ;_  cons
         ) ;_  apply
       ) ;_  list
     ) ;_  lambda
      (vl-remove-if
        (function null)
        (mapcar
          (function
            (lambda (x / minp maxp)
              (if (not
                    (vl-catch-all-error-p
                      (vl-catch-all-apply
                        (function vla-getboundingbox)
                        (list x 'minp 'maxp)
                      ) ;_  vl-catch-all-apply
                    ) ;_  vl-catch-all-error-p
                  ) ;_  not
                (list
                  (vlax-safearray->list minp)
                  (vlax-safearray->list maxp)
                ) ;_  list
              ) ;_  if
            ) ;_  lambda
          ) ;_  function
          lst
        ) ;_  mapcar
      ) ;_  vl-remove-if
  ) ;_  if
) ;_  defun
(defun c:test-2 (/ p1 p0)
  (setq
    p1 (vlax-3d-point
         (car
           (lst-getboundingbox
             (mapcar
               (function vlax-ename->vla-object)
               (vl-remove-if
                 (function listp)
                 (mapcar
                   (function cadr)
                   (ssnamex (ssget "_X"))
                 ) ;_  mapcar
               ) ;_ vl-remove-if
             ) ;_  mapcar
           ) ;_  lst-getboundingbox
         ) ;_  car
       ) ;_  vlax-3d-point
  ) ;_  setq
    (vla-move x p1 p0)
    (vla-update x)
  ) ;_  VLAX-FOR
) ;_  defun
lispman21
« Reply #20 on: July 28, 2006, 08:24:33 AM »
your awesome the programs work great.
« Reply #21 on: July 28, 2006, 08:25:00 AM »
Let me see if I can make some sense of you request. Also looking at this thread, http://forums.augi.com/showthread.php?t=43703
that is you right.
You have many drawings that have in the one exploded block each but they are far from the origin 0,0,0 and you want
to move the exploded block objects back to 0,0,0 so the drawing can be inserted as a block using that 0,0,0.
« Reply #22 on: July 28, 2006, 08:27:15 AM »
Wow, that was quick. While I went to reset the TV for my wife your problem was solved. :-o
« Reply #23 on: July 28, 2006, 08:37:44 AM »
Too true.
Joe Burke
« Reply #24 on: July 28, 2006, 10:50:41 AM »
(defun c:MoveTo0 ()
Hi Tim,
I think your elegant idea applies, but it may need a qsave like this:
(defun c:MoveTo0 ()
  (setvar "cmdecho" 0)
  (print (getvar "extmin"))
  (setvar "cmdecho" 1)
(defun c:MoveTo0v2 ()
  (command "_.qsave")
Example: I open a drawing where the lower left corner of the all the
geometry is at 0,0. I move everything up and to the right. Then I run
MoveTo0. Nothing happens and (print (getvar "extmin")) returns (0.0 0.0 0.0).
Then I run MoveTo0v2. The geomerty moves back to 0,0 and (print (getvar "extmin"))
returns (13.9636 20.5102 0.0).
Draw your own conclusions... :-)
« Reply #25 on: July 28, 2006, 10:56:07 AM »
(defun c:MoveTo0 ()
Hi Tim,
(defun c:MoveTo0 ()
  (command "_.qsave")
Joe,
  Hmmmm... That is weird, but thanks for posting the answer.  I don't think I would have ever tried that.
