Author Topic: command line - middle left Justify  (Read 2044 times)
craigr
« on: July 26, 2006, 03:58:27 PM »
Is there a way to make a text, (both SL & ML text), Middle Left Justification - from the command line?
-properties isn't available & the 'match properties' paintbrush won't match that property.
craigr
David Hall
  • Automatic Duh Generator
Re: command line - middle left Justify
« Reply #1 on: July 26, 2006, 04:03:06 PM »
new or existing text?
craigr
« Reply #2 on: July 26, 2006, 04:03:50 PM »
Existing Text.
craigr
CADaver
« Reply #3 on: July 26, 2006, 04:05:57 PM »
tjust
dxf code 71, I think
« Last Edit: July 26, 2006, 04:09:46 PM by CADaver »
David Hall
« Reply #4 on: July 26, 2006, 04:08:21 PM »
tjust, is that lisp? or acad standard?
craigr
« Reply #5 on: July 26, 2006, 04:09:49 PM »
-tcase
Thanks for replying, but apparently that command is not recognized in LT2005.
LT can be SOOO frustrating sometimes. I would LOVE to have the full version, but it's not my penny. - (In this case MANY pennys)
craigr
David Hall
« Reply #6 on: July 26, 2006, 04:11:02 PM »
yea, but does your boss realize how much he is spending for you to fix things the long way?  Add up what you make an hour fixing that stuff and you might be able to justify it
CADaver
« Reply #7 on: July 26, 2006, 04:13:44 PM »
-tcase
craigr
oooohhh LT, sorry dude that's an express tool lisp function for R2002
On a side note, we saved very many pennies by going with the full version over LT.  The savings realized by the ability to customize outweigh the initial investment by many times over.
Lin-Z
« Reply #8 on: July 26, 2006, 04:27:48 PM »
Don't have access to the software right now but the Properties palette? see if it gives you feedback on justification.
Dave R
« Reply #9 on: July 26, 2006, 04:42:07 PM »
This may work in LT:
Command: _justifytext
Select objects:
Enter a justification option [Left/Align/Fit/Center/Middle/Right/TL/TC/TR/ML/MC/MR/BL/BC/BR] <Left>:
Dommy2Hotty
« Reply #10 on: July 31, 2006, 05:18:15 PM »
For a button:
^C^C^Cselect;\justifytext;p;;ml;
