Author Topic: Command line Netload  (Read 11770 times)
BazzaCAD
« on: July 24, 2006, 11:46:33 PM »
Is there a command line version of netload?
So you can add it to an acad.lsp so it loads for everyone on the network or do you have to use the startup suite and a prefile?
Alexander Rivilis
  • Programmer from Kyiv (Ukraine)
Re: Command line Netload
« Reply #1 on: July 25, 2006, 02:19:51 AM »
(command "_.netload" path_to_dll) ;; path_to_dll is a full path to assembly
« Reply #2 on: July 25, 2006, 04:04:28 AM »
I thought I'd seen something on this ...
"Tony Tanzillo" <tony.tanzillo@U_KNOW_WHERE.com>
wrote in message news:<news:5119482@discussion.autodesk.com>...
A managed assembly (DLL) cannot be executed across
machine boundaries, unless you set special security
permissions (one way is Control Panel-> Administrative
Tools -> .NET Framework Configuration/Wizards).
I haven't tried, but it should be fairly easy to confirm this.
« Last Edit: July 25, 2006, 04:07:51 AM by Kerry Brown »
BazzaCAD
« Reply #3 on: July 25, 2006, 02:52:43 PM »
That was too easy, thx.
Bobby C. Jones
« Reply #4 on: July 25, 2006, 03:45:32 PM »
Hey Bazza :-)
Just curious, are you loading the assembly from a network location?
Bobby C. Jones
BazzaCAD
« Reply #5 on: July 25, 2006, 07:31:29 PM »
Hey Bazza :-)
I was hoping to.
Is that a prob. ?
Bobby C. Jones
« Reply #6 on: July 25, 2006, 08:31:56 PM »
I was hoping to.
Is that a prob. ?
The CLR doesn't like it.  But I haven't explored it enough to know anything about how to get it to work.  That's why I asked.  I wanted to see what hoops you had to jump through to get it working.
Bobby C. Jones
www1970
« Reply #7 on: July 25, 2006, 10:53:17 PM »
path_to_dll  ought this style
(defun S::STARTUP()
(command "netload" "E:\\VBnetArxLib\\Projects\\CommonLib\\CommonLib\\bin\\Debug\\commonlib")
(princ "已加载netload")
"\\" not "\"
BazzaCAD
« Reply #8 on: July 27, 2006, 02:07:25 AM »
I was hoping to.
Is that a prob. ?
So if I copy it there harddrive first, then should it be ok?
« Reply #9 on: July 27, 2006, 03:21:13 AM »
Barry, did you read my post ?
What have YOU tried, and what were the results ?
BazzaCAD
« Reply #10 on: July 27, 2006, 02:49:10 PM »
Sorry Kerry, It's hard to reply to every post. Yes I did read your post.
I haven't tried to load anything off the network yet, I'm just trying to plan ahead. But I do know I don't wont to have to go to each person PC in the office and go through Control Panel-> Administrative
Tools -> .NET Framework Configuration/Wizards.
Seams to me like the .NET .DLL's are more of a pain to deal with the the C++ .ARX's
It has a (ARXLOAD) function, instead of (command "netload") & can be loaded off of the network...
Why is that?
« Reply #11 on: July 27, 2006, 04:38:57 PM »
It isn't just for Autocad. To my understanding the restriction is a security feature with managed assemblies.
..........Seams to me like the .NET .DLL's are more of a pain to deal with the the C++ .ARX's
You don't have to used net DLL's.
« Reply #12 on: July 27, 2006, 06:01:00 PM »
Why can't you just install the dll/s into a program folder on the users machine, I know updating is a bit of a pain but that's the way it is. Perhaps you can write a batch file to distrubute an updated dll after work hours?
Can this be done Kerry? I could use this myself :)
- John Carmack
- J.R.R. Tolkien
« Reply #13 on: July 27, 2006, 06:33:11 PM »
A batch file to run at system Startup on the slave which XCopys files from the server would be the way I'd do it. There may be better ways, but I go with what I know works.
I assume the OP means an intranet network.
« Reply #14 on: July 27, 2006, 06:39:48 PM »
That sounds like a plan!
Off to study the 'forgotten art of the batch file'. Be back soon :)
- John Carmack
- J.R.R. Tolkien
