CAD Forums > CAD General
Freeze Off Layers Routine
(1/1)
ronjonp:
I Know I've seen this somewhere.....
Lisp that finds all layers that are turned off and freezes them. Anyone here got it?
Thanks,
Ron :D
Keith™:
Well... it leaves them off but it freezes them as well.... Not sure about use with viewports...
--- Code: ---
(defun C:layfrzoff( / lay layname laylist)
(setq lay (tblnext "layer" t))
(while lay
(setq layname (cdr (assoc 2 lay)))
(if (<(cdr (assoc 62 (tblsearch "layer" layname))) 0)
(setq laylist (entget (tblobjname "layer" (cdr (assoc 2 lay)))))
(entmod (subst (cons 70 1) (assoc 70 laylist) laylist))
(setq lay (tblnext "layer"))
--- End code ---
ronjonp:
Thanks Keith...that worked excellent!
Keith™:
You are quite welcome...
Navigation
[0] Message Index
Go to full version
