Author Topic: SubEntityID  (Read 10738 times)
Draftek
Re: SubEntityID
« Reply #15 on: July 26, 2006, 08:11:53 AM »
Kerry: One man's bug is another man's request. I'll pm you in a moment..
Mick: I see what your getting at, but wouldn't I still have to create some persistent reactors to keep the grid synced? So, I'm still going to have a custom object to attach or am I missing something (highly probable).
MickD
Re: SubEntityID
« Reply #16 on: July 26, 2006, 05:48:49 PM »
You could use reactors to re-build your model or have an 'update model' button to make the changes. It depends on how often you change your model I guess but a change is a change and should be deliberate.
Say you have your grids and they have a link to the members 'attached' to them some how, to change your model, move the grid/construction lines and hit the 'update model' button and watch it re-model using the stored modelling data for each part.
- John Carmack
- J.R.R. Tolkien
