Author Topic: Randomize help.  (Read 2997 times)
sdp777
Randomize help.
« on: July 03, 2006, 10:50:03 PM »
I have been doing a couple of site plans here recently and realized the boringness of the same block repeated over and over.  So I thought about generating a random rotation and scale and apply to all the blocks of the same name selected in the drawing.
My randomize function really blows however.  If anyone has a better method, Im game.
Randomize All Blocks
Version 1.0
Written by:  Steven Papke
Written on:  1/26/06
This routine asks the user to select a block.
With the block name extracted, the user then
inputs a number as a percentage to randomize
and the routine will randomize scale and rotation
of all blocks of the same name.  This is ideal
for use in site plans.
(defun *error* (msg)
  (princ "\n")
  (setvar "cmdecho" 1)
  (setvar "menuecho" 1)
  (setvar "osmode" 15359)
  (setvar "polarmode" 2)
  (setvar "dynmode" 3)
  (setvar "autosnap" 63)
  (setvar "attreq" 1)
  (menucmd "s=s")
  (princ "error: ")
  (princ msg)
(defun randomize ()
;  (setq rn (+ 1(* randm (getvar "tdusrtimer"))))
  (if (not seed)
    (setq seed (getvar "DATE"))
  (setq modulus    65536
        multiplier 25173
        increment  13849
        seed  (rem (+ (* multiplier seed) increment) modulus)
        random     (/ seed modulus)
(defun modifyblk ()
(randomize)
(setq rotang (+ 15(* randm random)))
(setq sclfctr (/ random randm))
        (print rn)
(print rotang)
(print sclfctr)
(command "ROTATE" (ssname ss count) "" sinspt rotang) ; Rotate blocks
(command "SCALE" (ssname ss count) "" sinspt sclfctr) ; Scale blocks
(defun c:rnd ()
  (setq osm (getvar "osmode"))
  (setq orm (getvar "orthomode"))
  (setq plm (getvar "polarmode"))
  (setvar "cmdecho" 0)
  (setvar "orthomode" 0)
  (setvar "attdia" 0)
  (setvar "attreq" 0)
  (prompt "\nSelect source block: ") ; Select Source Block
  (setq rndmbkpic (entsel))
  (setq rndmbkpicmod (car rndmbkpic))
  (setq rndmbknam (cdr (assoc 2 (entget rndmbkpicmod)))) ; Find out blockname
  (initget 1)
  (setq randm (getreal "\nAmount of Randomization (1 little-10 alot): ")) ; Set Randomization Factor
  (setq count 0)
  (prompt "\nSelect block(s) to randomize: ")
  (setq ss (ssget)) ; Select Objects
  (if ss ; If blocks are selected...
      (setq count 0) ; Count set to 0
      (setq chgblk 0) ; Changed Blocks set to 0
      (setq ssl (sslength ss))
(princ "\nIsolating Block ")
(princ rndmbknam)
(princ " from selection set.")
(princ "\n")
      (while (< count ssl) ; Loop
(setq blk (entget (ssname ss count))) ; Get Selected Block in set
        (setq sinspt (cdr (assoc 10 blk))) ; Get Insertion Point of Selected Block
        (setq sblk (cdr (assoc 2 blk))) ; Read Selected Block Name
(if (= rndmbknam sblk) ; Check if Block Name matches
(if (/= (substr (cdr (assoc 2 blk)) 1 8) "*")
  (modifyblk)
(setq chgblk (+ 1 chgblk))
      (setq count (+ 1 count))
  (princ ssl) ; Print Statistics
  (princ " objects found.")
  (princ "\n")
  (princ chgblk)
  (princ " blocks randomized.")
  (setvar "orthomode" orm)
  (setvar "osmode" osm)
  (setvar "attreq" 1)
  (setvar "polarmode" plm)
(princ "\nrnd")
sdp777
Re: Randomize help.
« Reply #1 on: July 03, 2006, 10:56:08 PM »
Heres a 2004 dwg to tinker with.
LE
Re: Randomize help.
« Reply #2 on: July 03, 2006, 11:08:33 PM »
Re: Randomize help.
« Reply #3 on: July 04, 2006, 09:34:56 AM »
sdp777
Re: Randomize help.
« Reply #4 on: July 04, 2006, 09:38:10 AM »
Hmm.  I realize I inidicated the randomize function was problematic and thats my fault.  I was able to generate a random number without issue with the code above, and the a test of some of the defuns in that thread you referenced.  Perhaps I more clearly suggest, I need help on what happens in the modifyblk defun.  My alogrithms were a crap shoot.  Essentially, I would like the alogrithms to generate a scale factor to always remain somewhat small and the rotation angle to have larger variations.
I also want to limit the answer randm to integers from 1 to 10.  Is there a way to conditionalize the answer better than below? Any assistance there would be helpful.
 (if (or (< ans "1") (> ans "10"))
(randomize)
(princ "\nSorry '")
(princ ans)
(princ "' is not a valid entry...")
(princ "\nPlease try again!")
(rnd)
Re: Randomize help.
« Reply #5 on: July 04, 2006, 09:57:55 AM »
Perhaps
(fix (* 10 (randomize)))
