Actually Daron, it's quite different from the ADT 3.3 of 2ki I was using.
In 2ki, the internal text editor was a single dialog box with the pull down menus and editing functions on the top bar.
With 2k4, you get two floating dialog boxes. The first, the toolbar, is nothing but a toolbar. It has a few editing options but nothing containing settings for the editor itself. The second dialog box, the text window, has just the text that was selected for editing. It is transparent so you can see what is behind it (like I want to). It is usually displayed with a ruler above but there are no maximum, min buttons available. It is difficult to grab and drag without accidentally placing a tab bar or something else within the ruler. When I have to drag the editor over so I can edit text, I have to drag both items independently of each other, ... it's such a pain.
But I prefer the editor over the notepad or wordpad, for me it's just a bit faster.
I was thinking the default location setting of the editor would be in a lsp file like the ADT.lsp or some other, of the many that are referenced seeing as the editor is floating. But I can't find it or I'm overlooking it.
