Author Topic: trim & erase exterior entities..  (Read 21558 times)
Joe Burke
Re: trim & erase exterior entities..
« Reply #15 on: June 08, 2006, 10:32:38 AM »
I picked up this getpolypoints function here somewhere....with that said, this would select all objects within a selected polyline.
(defun c:xxx (/ pl ss)
  (Defun GetPolyPoints (POLY / entPoly lstReturn)
    (SetQ entPoly (EntGet POLY))
    (SetQ lstReturn (List (Cdr (Assoc 10 entPoly))))
    (While
      (Assoc 10
     (SetQ entPoly (Cdr (Member (Assoc 10 entPoly) entPoly)))
       (SetQ lstReturn (Cons (Cdr (Assoc 10 entPoly)) lstReturn))
    (Reverse lstReturn)
  (setq pl (getpolypoints (car (entsel)))
ss (ssget "_WP" pl)
  (sssetfirst nil ss)
The following may be of interest when a pline is used to create a selection set. It traces arcs in plines. It also includes checking for duplicate adjacent points, which causes things like (ssget "wp" ptlst) to fail.
;; JB  4/1/2006
;; Arguments: obj - a heavy or lightweight pline ename or vla-object.
;;            deg - the approximate number of degrees between points
;;                  along an arc. Suggested value: 10.
;; Returns: WCS point list if successful.
;; Notes: The number of points returned when tracing an arc is proportional
;;        to the included angle.
;;        Duplicate adjacent points are removed.
;;        The last closing point is included given a closed pline.
(defun TracePline (obj deg / typ param endparam pt blg
                             ptlst delta inc arcparam)
    (or
      (= (type obj) 'VLA-OBJECT)
      (setq obj (vlax-ename->vla-object obj))
    (setq typ (vlax-get obj 'ObjectName))
    (or (= typ "AcDb2dPolyline") (= typ "AcDbPolyline"))
    (setq param 0
          endparam (vlax-curve-getEndParam obj)
    (while (<= param endparam)
      (setq pt (vlax-curve-getPointAtParam obj param))
      ;Avoid duplicate points between start and end.
      (if (not (equal pt (car ptlst) 1e-12))
        (setq ptlst (cons pt ptlst))
      ;A closed pline returns an error (invalid index)
      ;when asking for the bulge of the end param.
          (/= param endparam)
          (setq blg (abs (vlax-invoke obj 'GetBulge param)))
          (/= 0 blg)
          (setq delta (* 4 (atan blg)) ;included angle
                inc (/ 1.0 (1+ (fix (/ delta (* pi (/ deg 180.0))))))
                arcparam (+ param inc)
          (while (< arcparam (1+ param))
            (setq pt (vlax-curve-getPointAtParam obj arcparam)
                  arcparam (+ inc arcparam)
      (setq param (1+ param))
  ) ;and
      (apply 'and ptlst)
      (> (length ptlst) 1)
    (reverse ptlst)
) ;end
« Reply #16 on: June 08, 2006, 11:57:32 AM »
Thanks Joe. :-)
« Reply #17 on: June 08, 2006, 12:46:34 PM »
Is this pretty much the same as Joe's routine?
http://www.theswamp.org/index.php?topic=8878.msg114385#msg114385
« Reply #18 on: June 08, 2006, 01:56:00 PM »
No, That routine creates a pline from a pt list while Joe's routine creates a point list from a pline.
More importantly his routine creates extra points when an arc i encountered in a pine that allow the boundary to more closely trace the actual arc.
caddog
« Reply #19 on: June 25, 2006, 01:25:00 AM »
;;;函数: c:SWP
;;;编制日期:2006.4.1
;;;编制者  :何俊
;;;函数说明:本函数选择用户指定多边形内的实体(注意多边形要在当前视口内)。
(DEFUN c:sw (/ ENAME #MYLIST SS1)
  (princ "\n 选择用户指定多边形内的实体(注意多边形要在当前视口内)。")
  (SETQ ename (CAR (ENTSEL "\n请选择一个多边形:")))
  (SETQ #mylist (getpllist ename))
  (SETQ ss1 (SSGET "_WP" #mylist))
  (SSSETFIRST NIL ss1)
  (SETQ ss1 ss1)
) ;_ 结束defun
;;;函数: c:CWP
;;;编制日期:2006.4.1
;;;编制者  :何俊
;;;函数说明:本函数选择用户指定多边形内以及与多边形相交的实体
;;;         (注意多边形要在当前视口内)。
(DEFUN c:cw (/ ENAME #MYLIST SS1)
  (princ "\n 选择用户指定多边形内以及与多边形相交的实体(注意多边形要在当前视口内)")
  (SETQ ss1 (SSGET "_CP" #mylist))
  (SETQ ss1 ss1)
) ;_ 结束defun
;;;函数: c:es
;;;编制日期:2006.4.
;;;编制者  :何俊
;;;函数说明:本函数选择用户指定多边形外的实体(注意多边形要在当前视口内)。
(DEFUN c:es (/ ename #mylist ss1)
  (princ "\n 选择用户指定多边形外的实体(注意多边形要在当前视口内)。")
  (COMMAND "select" "all" "r")
  (COMMAND ss1)
  (COMMAND "")
  (SETQ ss1 (SSGET "_p"))
  (SETQ ss1 ss1)
) ;_ 结束defun
;;;函数: c:Cs
;;;编制日期:2006.4.
;;;编制者  :何俊
;;;函数说明:本函数选择用户指定多边形外且不与多边形相交实体
;;;         (注意多边形要在当前视口内)。
(DEFUN c:Cs (/ ename #mylist ss1)
  (princ "\n 选择用户指定多边形外且不与多边形相交实体(注意多边形要在当前视口内)")
  (SETQ ss1 (SSGET "_cP" #mylist))
  (COMMAND ss1)
  (COMMAND "")
  (SETQ ss1 ss1)
) ;_ 结束defun
caddog
« Reply #20 on: June 25, 2006, 01:26:43 AM »
DEFUN getPlList (#entity)
  (SETQ obj (ENTGET #entity))
  (SETQ lw_t8 (CDR (ASSOC 8 obj)))
  (SETQ obj_1 nil)
  (WHILE (/= (ASSOC 10 obj) nil)
    (IF   (AND (= (CAAR obj) 10)
        (NOT (EQUAL (CDAR obj) (LAST obj_1) 0.001))
      (SETQ obj_1 (APPEND obj_1 (LIST (CDAR obj))))
    (SETQ obj (CDR obj))
  (SETQ obj obj_1)
  (IF (EQUAL (CAR obj) (LAST obj) 0.0001)
    (SETQ obj (REVERSE (CDR (REVERSE obj))))
  (SETQ #temp obj)
« Reply #21 on: March 24, 2011, 05:14:44 PM »
    (While
      (Assoc 10
    (Reverse lstReturn)
ss (ssget "_WP" pl)
  (sssetfirst nil ss)
;; JB  4/1/2006
    (or
    (setq param 0
          (/= param endparam)
          (/= 0 blg)
  ) ;and
      (apply 'and ptlst)
    (reverse ptlst)
) ;end
Thanks for this Joe ... saved me a bunch of time today.  :-)
SOFITO_SOFT
« Reply #22 on: March 25, 2011, 02:54:12 PM »
Hello everyone
I'd do this with the "BREAKALL.lsp" published here.
For then most difficult : It has a subfunction that break all elements of  pickset1 (all) with the element of pickset2 ( only the green poly ).
After a "ERASE" using a "FENCE" over a parallel outside ( very near) the green polyline ... and you have solved the problem of entities crossing the green poly
For other entities, there are several other algorithms outside / inside  in published programs ..
Greetings..... :-)
