Microstation forever has been able to open DXFs so if they have an old enough version of microstation that it won't use DWG, you can go that route. Microstation has been able to convert[/i] DWGs for quite a while though, so they should be able to use them. ADT objects might present a problem though, so you might need to explode that kind of stuff before sending.
