Author Topic: Inside/Outside radius  (Read 7730 times)
Maverick®
Re: Inside/Outside radius
« Reply #15 on: May 30, 2006, 02:37:50 PM »
  K,  I don't use Acad.  But can't you just offset?  Are you just drawing a line (2d obviously) for one side of the pipe and offsetting whatever the diameter is?  Couldn't you just offset the radius too?  Or am I missing something?
  In the example I drew a line, and then one perpendicular to it, used curved fillet (again not Acad command but I'm pretty sure you have something similar) and then offset each one.
  I must be confused............ Again.  :-D
M-dub
« Reply #16 on: May 30, 2006, 02:42:04 PM »
Right here with me...
At least your seat didn't get cold when you left.  ;)
Maverick®
« Reply #17 on: May 30, 2006, 02:49:18 PM »
  yeah well the A/C works here.  :-P
John Hancock
« Reply #18 on: May 30, 2006, 02:58:14 PM »
It appears to me I have opened a can of worms.  I just wanted to the inside radi to looked balanced with the outside.
M-dub
« Reply #19 on: May 30, 2006, 03:01:57 PM »
I think the Offset command is your best friend, then John.
Maverick®
« Reply #20 on: May 30, 2006, 03:06:23 PM »
  No can of worms John.  I was just wondering.  No biggie.   :kewl:
