Author Topic: Slides using $I=* , can the view be enlarged?  (Read 5801 times)
Re: Slides using $I=* , can the view be enlarged?
« Reply #15 on: September 21, 2005, 01:40:26 PM »
Sorry, but it does not exhibit that behavior in my environment after changing the item from an image button to a plain old image.
AVCAD
« Reply #16 on: September 22, 2005, 10:51:57 AM »
acad_icon: dialog {
        key = "label";
        initial_focus               = "listbox";
        : row {
            : list_box {
                width               = 40;
                height              = 23;
                fixed_height        = true;
                key                 = "listbox";
                allow_accept        = true;
            : column {
               : row {
                   : image {
                       color                   = 0;
                       width                   = 75;
                       height                  = 20;
                       aspect_ratio            = 0.66;
                       allow_accept            = false;
                       fixed_width             = true;
                       key         = "icon1";
/*                : row {
*                    : icon_image {
*                        key         = "icon5";
*                    : icon_image {
*                        key         = "icon6";
*                    : icon_image {
*                        key         = "icon7";
*                    : icon_image {
*                        key         = "icon8";
*                : row {
*                    : icon_image {
*                        key         = "icon9";
*                    : icon_image {
*                        key         = "icon10";
*                    : icon_image {
*                        key         = "icon11";
*                    : icon_image {
*                        key         = "icon12";
*                : row {
*                    : icon_image {
*                        key         = "icon13";
*                    : icon_image {
*                        key         = "icon14";
*                    : icon_image {
*                        key         = "icon15";
*                    : icon_image {
*                        key         = "icon16";
*                : row {
*                    : icon_image {
*                        key         = "icon17";
*                    : icon_image {
*                        key         = "icon18";
*                   : icon_image {
*                      key         = "icon19";
*                    : icon_image {
*                        key         = "icon20";
*              : row {
*                  : icon_image {
*                      key         = "icon21";
*                  : icon_image {
*                      key         = "icon22";
*                  : icon_image {
*                      key         = "icon23";
*                  : icon_image {
*                      key         = "icon24";
That is what my DCL files looks like for that section.
I the image is not selectable, correct, there for it doesnt become highlighted when clicking the picture.
If you scroll through the LISTBOX using your mouse, not the Next or Previous buttons, but by clicking the name of the image the image does become highlighted. This is what I want stopped, if at all possible.
Thanks, for the help.
« Reply #17 on: September 22, 2005, 12:22:11 PM »
That must be built into AutoCAD ... You would likely have to create your own program .. and even then I am not sure how it work ..
Andrea
« Reply #18 on: September 23, 2005, 03:04:50 PM »
Yes you can....but not in VLISP.
You can use ObjectDCL and play around.
you can see SBLOCK program in CADDEPOT and take a look of the thumbnail
Keep smile...
