Welcome,
Guest
. Please
login
or
register
1 Hour
1 Day
1 Week
1 Month
Forever
News:
Home
Help
Login
Register
TheSwamp
Code Red
AutoLISP (Vanilla / Visual)
Topic:
Force prompt user to select an entity with SSGE even if there is already selecte
« previous
next »
Print
Pages: [
1
Go Down
Author
Topic: Force prompt user to select an entity with SSGE even if there is already selecte (Read 1130 times)
V@no
Newt
AutoCAD 2023
on:
April 30, 2024, 08:57:07 PM »
I'd like to use SSGET to prompt user to select certain entities (let's say only lines). However if there is already a selection but doesn't pass the filter (a circle selected) SSGET returns nil instead of prompt user to select.
Is there a way force to prompt user without clearing the selection?
Basically, what I'm trying to accomplish is: prompt user so select a single entity (using ":S"). Highlight that entity, prompt user to select second entity but don't allow select first one.
During these prompts I also allow user change options, therefor I'm running SSGET in a loop, however on second "prompt" it automatically returns nil instead of prompting user.
Any ideas how to achieve this?
Thank you.
Code - Auto/Visual Lisp:
[Select]
DEFUN
c:test
loop num filter str ss sss ent1 ent2
SETQ
loop T
num
0
filter
nil
str
"first"
sss
SSADD
WHILE
loop
PRINC
STRCAT
\n
Select "
str
" item: "
SETQ
ss
SSGET
"_:S"
filter
print
ss
IF
AND
ss
SSLENGTH
ss
0
num
0
PROGN
SETQ
ent1
ENTGET
SSNAME
ss
0
filter
LIST
CONS
4
CAR
ent1
num
1+
num
str
"second"
sss
SSADD
SSNAME
ss
0
sss
PROGN
SETQ
loop
nil
IF
ss
SETQ
ent2
SSNAME
ss
0
sss
SSADD
ss sss
SSSETFIRST
nil
sss
PRINC
\n
first item: "
PRINC
ent1
PRINC
\n
second item: "
PRINC
ent2
PRINC
Logged
ribarm
Gator
Marko Ribar, architect
WWW
Re: Force prompt user to select an entity with SSGE even if there is already selecte
Reply #1 on:
May 01, 2024, 09:08:21 AM »
Try this mod... But selection of grips were not preserved when selected the same entity and because of that added (GETSTRING) after (SSSETFIRST)...
[Select]
DEFUN
c:seltst
*error*
loop num str hgl sss ss ent1 ent2
DEFUN
*error*
m
IF
hgl
SETVAR
QUOTE
highlight
hgl
IF
m
PROMPT
m
PRINC
SETQ
loop T
SETQ
num
0
SETQ
str
"first"
SETQ
hgl
GETVAR
QUOTE
highlight
SETVAR
QUOTE
highlight
1
SETQ
sss
SSADD
WHILE
loop
PRINC
STRCAT
\n
Select "
str
" item : "
IF
AND
ent1
SSMEMB
ent1 ss
SSDEL
ent1 ss
WHILE
OR
NOT
ss
AND
ss
SSLENGTH
ss
0
SETQ
ss
SSGET
"_+.:E:S"
COND
AND
ss
SSLENGTH
ss
1
num
0
SETQ
ent1
SSNAME
ss
0
SETQ
num
1+
num
SETQ
str
"second"
SSADD
ent1 sss
T
SETQ
loop
nil
IF
AND
ss
SSLENGTH
ss
1
EQ
ent1
SETQ
ent2
SSNAME
ss
0
PROGN
SETQ
loop T
SSDEL
ent1 ss
IF
OR
NOT
ss
AND
ss
SSLENGTH
ss
0
SETQ
loop T
IF
AND
ent2
NOT
EQ
ent1 ent2
SSADD
ent2 sss
SSSETFIRST
nil
sss
IF
OR
AND
ent1
NOT
ent2
AND
ent1 ent2
EQ
ent1 ent2
PROGN
GETSTRING
\n
ENTER TO CONTINUE..."
SSSETFIRST
PRINC
\n
First item : "
PRINC
ent1
PRINC
\n
Second item : "
PRINC
ent2
*error*
nil
M.R.
Last Edit: May 02, 2024, 02:38:44 AM by ribarm
Logged
Marko Ribar, d.i.a.
(graduated engineer of architecture)
M.R. on Youtube
ribarm
Gator
WWW
Reply #2 on:
May 01, 2024, 09:24:52 AM »
Just to add note...
I tested my mod. in BricsCAD and it behaves good, but in AutoCAD it's very buggy...
Sorry, but I may not find apropriate solution for both environments...
Regards...
Logged
Marko Ribar, d.i.a.
M.R. on Youtube
ribarm
Gator
WWW
Reply #3 on:
May 01, 2024, 10:47:57 AM »
Test it now...
I think that now is good for both and BricsCAD and AutoCAD...
Regards, M.R.
Logged
Marko Ribar, d.i.a.
M.R. on Youtube
Print
Pages: [
1
Go Up
« previous
next »
TheSwamp
Code Red
Topic:
