Author Topic: Select BYPolygon  (Read 1846 times)
csgoh
Select BYPolygon
« on: June 24, 2005, 10:23:42 PM »
What does it mean by the enum in the mode "AcSelect enum; input only" for the method selectbypolygon as listed in the Help files?
Using an integer 2 for mode seems to be ok but not other numbers?
Thank you.
SelectByPolygon Mode, PointsList, FilterType, FilterData
Object
SelectionSet
The object or objects this method applies to.
Mode
AcSelect enum; input-only
acSelectionSetFence
acSelectionSetWindowPolygon
acSelectionSetCrossingPolygon
PointsList
Variant (array of doubles); input-only
An array of 3D WCS coordinates specifying the selection fence.
FilterType
Integer; input-only; optional
A DXF group code specifying the type of filter to use.
FilterData
Variant; input-only; optional
The value to filter on.
csgoh
Select BYPolygon
« Reply #1 on: June 25, 2005, 12:43:34 AM »
The 2 is for acSelectionSetFence. Using the ObjectBrowser in the VBAIDE you can find that to call acSelectionSetWindowPolygon you would need to either supply that konstant OR the Integer 6.
