Poll
getpoint error calculator help
getpoint
0 (0%)
error calculator
0 (0%)
Total Members Voted: 0
Voting closed: August 21, 2020, 11:11:29 PM
Author Topic: getpoint error calculator help  (Read 2508 times)
leekh
  • Mosquito
« on: July 22, 2020, 11:11:29 PM »
  1. (defun c:t1( / pt1 pt2)
  2.   (princ "\ndist 0.2 chk")
  3.   (setq pt1 (getpoint "\ndown point : "))
  4.   (setq pt2 (getpoint pt1 "\nup point :"))
  5.   (setq aa (- (- (cadr pt2) (cadr pt1)) 0.2))
  6.   (princ (strcat "\n cal-chk : " (vl-princ-to-string aa)))
  7.   (princ)
  8.   )
  9.
  10. (defun c:t2( / pt1 pt2)
  11.   (princ "\ndist 0.2 chk")
  12.   (setq pt1 (getpoint "\ndown point : "))
  13.   (setq pt2 (getpoint pt1 "\nup point :"))
  14.   (setq aa (- (distance pt1 pt2) 0.2))
  15.   (princ (strcat "\n chk : " (vl-princ-to-string aa)))
  16.   (princ)
  17.   )
command: t1
dist 0.2 chk
down point:
up point:
 chk : 2.83107e-15
command:
command: t2
dist 0.2 chk
down point:
up point:
 chk : 2.83107e-15
_$ (- (cadr pt2) (cadr pt1))
0.2
_$ (- (- (cadr pt2) (cadr pt1)) 0.2)
2.83107e-15                              <=error      0.0  ok
_$
_$ (distance pt1 pt2)
0.2
_$ (- (distance pt1 pt2) 0.2)
_$
0.2
_$ (= (distance pt1 pt2) 0.2)         <-=error  T ok
nil
getpoint or distance error help me
EDIT (John): Added code tags
« Last Edit: July 23, 2020, 11:22:18 AM by John Kaul (Se7en) »
leekh
  • Mosquito
Re: getpoint error calculator help
« Reply #1 on: July 23, 2020, 05:04:43 AM »
command offset 0.2 work
-1.13798e-14
error
_$ (- (read (vl-princ-to-string (distance pt1 pt2))) 0.2)
0.0
ok
(- (distance pt1 pt2) 0.2)   I don't know why I am getting the error?
VovKa
  • Ukraine
« Reply #2 on: July 23, 2020, 10:56:03 AM »
(rtos (distance pt1 pt2) 2 16)
leekh
  • Mosquito
« Reply #3 on: July 23, 2020, 09:44:57 PM »
 pt1 pt2 dist = 0.2
 offset 0.2 use
_$ (rtos (distance pt1 pt2) 2 16)
"0.1999999999999993"
why not "0.1999999999999993" is "0.2" ?
Dlanor
« Reply #4 on: July 24, 2020, 04:27:03 AM »
because you are asking for it to be accurate to 16 significant digits. This is a result of the way floating point math works on computers. GOOGLE "Floating-point error mitigation"
The error is your assumtion that anything that is computed by AutoCAD (which is almost everything) has the value you think it does i.e. the distance between two points is 0.2 where it could be 0.200000000000001 or 0.199999999999998. To all intents and purposes this is 0.2 since (equal 0.199999999999998 0.2 1.0e-13) will return T. AutoCAD's smallest unit is the angstrom (1.0e-10) so the error is insignificant as it is a 1/1000000th of an angstrom. The largest IIRC is the parsec 3.0e16 metres where such an error will be significant, but this is only because of the limited number of computational registers when doing the math, and who apart from astronomers or astrophysicist works with parsecs.
roy_043
  • BricsCAD 18
« Reply #6 on: July 24, 2020, 02:28:55 PM »
@Dlanor:
What you are saying is confusing. Internally AC works with drawing units (DU). They can be considered mm, inches, angstrom etc. A tolerance of 1.0e-13 DU would be relatively the same whatever 1 DU represents.
roy_043
  • BricsCAD 18
« Reply #7 on: July 24, 2020, 02:32:33 PM »
@leekh:
Some decimal numbers cannot be exactly translated to the binary floating point format. Some loss of accuracy therefore has to be taken into account.
leekh
  • Mosquito
« Reply #8 on: July 26, 2020, 08:42:18 PM »
Thank you for your explanation Now I can understand
leekh
  • Mosquito
« Reply #10 on: July 26, 2020, 08:46:24 PM »
@leekh:
