I can prompt for a selection set and filter it for a block named "510".
(setq ET "INSERT") (setq PR (cons 0 ET)) (setq BL1 "510")
(setq ss0 (ssget (list PR)))
(setq ss1 (ssget "P" (list (cons 2 BL1))))
And then I can prompt for another selection set and filter it for a block named "515".
(setq ET "INSERT") (setq PR (cons 0 ET)) (setq BL2 "515")
(setq ss2 (ssget "P" (list (cons 2 BL2))))
But I'd like to prompt for a selection set only once, and get both ss1 and ss2 from that single user input.
Is that possible? Can I get ss0 from the user and then create both ss1 and ss2 from it?
