Author Topic: Dragging block with DynDraw  (Read 3176 times)
velasquez
« on: February 03, 2016, 05:48:48 AM »
(defun c:DynDrawTest (/ step blk Obj point)
  (setq step 1e-6)
  (setq blk (car (entsel "\nSelect a block: "))
;;; pt     (dxf 10 (entget blk)) ;_ fim de dxf
;;; LastPt pt
Obj (vlax-ename->vla-object blk)
  ) ;_ fim de setq
  (defun JoyCallBackTest (point /)
    (setvar "nomutt" 1) ;_ suppresses the "regen ..." prompt
      ((= (type point) 'STR)
       (vla-update Obj)
      ((vl-consp point)
       (or prev (setq prev point))
       (if (< step (distance prev point))
   (setq prev point)
   (vla-put-InsertionPoint Obj (vlax-3D-point point))
   (vla-update Obj)
) ;_ fim de progn
       ) ;_ fim de if
    ) ;_ fim de cond
    (setvar "nomutt" 0)
    point
  ) ;_ fim de defun
;;;Define a funcao p/ DynDraw.arx
  (vl-acad-defun 'JoyCallBackTest)
  (setq
    point
     (dyndraw "JoyCallBackTest"
      "\nSpecify insertion point: [Enter Exit]: "
      "" ;_ Keyword string
      (+ 2 128 2048)
      -1
      nil
     ) ;_ fim de dyndraw
  ) ;_ fim de setq
  (if (vl-consp point)
      (vla-update Obj)
    ) ;_ fim de progn
  ) ;_ fim de if
  (vl-acad-undefun 'JoyCallBackTest)
The above code works well with DynDraw 2010 x64.arx in AutoCAD 2010.
But with higher versions the object is not shown during the drag.
Can anyone tell me why?
« Last Edit: February 04, 2016, 12:22:48 PM by velasquez »
velasquez
Re: Dragging block with DynDraw
« Reply #1 on: February 11, 2016, 02:14:51 PM »
Can someone please test the code I posted in a later version to AutoCAD 2010?
Any feedback would be helpful.
DW
« Reply #2 on: February 15, 2016, 06:45:02 PM »
It displays and drags without issues in 2016.  I've noticed some display problems with complex blocks in earlier versions of AutoCAD > 2009 but later versions seem to be ok.
Hugo
« Reply #3 on: February 16, 2016, 01:32:36 AM »
I can in 2016 not test because I can not load the DynDraw.arx.   :oops:
Ich kann das in 2016 nicht Testen da ich die DynDraw.arx nicht laden kann.
velasquez
« Reply #4 on: February 16, 2016, 05:30:32 AM »
Thanks for the answers.
I noticed the biggest problem in AutoCAD 2012.
Alexander Rivilis
  • Programmer from Kyiv (Ukraine)
« Reply #5 on: April 21, 2016, 01:50:22 AM »
