Welcome,
Guest
. Please
login
or
register
1 Hour
1 Day
1 Week
1 Month
Forever
News:
Home
Help
Login
Register
TheSwamp
Code Red
AutoLISP (Vanilla / Visual)
Topic:
splitconcavepolygon2convexpolygons-triangles
« previous
next »
Print
Pages: [
1
Go Down
Author
Topic: splitconcavepolygon2convexpolygons-triangles (Read 1302 times)
ribarm
Gator
Marko Ribar, architect
WWW
on:
March 23, 2016, 03:05:26 PM »
This is looping infinitely... Comments are welcome and wise opinion...
Code - Auto/Visual Lisp:
[Select]
defun
c:sconc2conv
LM:ConvexHull LM:Clockwise
p insidep nea process lw pl el ch pll ell chl eln plll elll pll3 ell3 en li1 li2 li3 f
;;splitconcavepolygon2convexpolygons-triangles
;; Convex Hull - Lee Mac
;; Implements the Graham Scan Algorithm to return the Convex Hull of a list of points.
defun
LM:ConvexHull
lst
ch p0
cond
length
lst
4
lst
setq
p0
car
lst
foreach
p1
cdr
lst
if
or
cadr
p1
cadr
p0
and
cadr
p1
cadr
p0
car
p1
car
p0
setq
p0 p1
setq
lst
vl-remove
p0 lst
setq
lst
append
list
p0
lst
setq
lst
vl-sort
lst
function
lambda
a b
c d
if
or
equal
setq
c
angle
p0 a
setq
d
angle
p0 b
1e
8
and
or
equal
c
0.0
1e
8
equal
c
2
pi
1e
8
or
equal
d
0.0
1e
8
equal
d
2
pi
1e
8
distance
list
car
p0
cadr
p0
a
distance
list
car
p0
cadr
p0
b
c d
setq
ch
list
caddr
lst
cadr
lst
car
lst
foreach
pt
cdddr
lst
setq
ch
cons
pt ch
while
and
caddr
ch
LM:Clockwise
p
caddr
ch
cadr
ch
pt
setq
ch
cons
pt
cddr
ch
reverse
ch
;; Clockwise-p - Lee Mac
;; Returns T if p1,p2,p3 are clockwise oriented or collinear
defun
LM:Clockwise
p
p1 p2 p3
car
p2
car
p1
cadr
p3
cadr
p1
cadr
p2
cadr
p1
car
p3
car
p1
1e
8
defun
insidep
pt entn
big flag obj1 obj2 obj3 p1 p2 small
vl-load-com
if
and
pt entn
progn
setq
obj1
vlax
ename
vla-object
entn
setq
obj2
car
vlax-invoke
obj1 'Offset
0.001
obj3
car
vlax-invoke
obj1 'Offset
0.001
if
vla-get-area
obj2
vla-get-area
obj3
progn
set
'big obj2
set
'small obj3
progn
set
'big obj3
set
'small obj2
setq
p1
vlax-curve-getClosestPointTo
big pt
p2
small pt
if
distance
pt p1
distance
pt p2
setq
flag T
setq
flag
nil
mapcar
function
lambda
x
progn
vla-delete
x
vlax-release-object
x
list
big small
if
equal
trans
pt entn
0
vlax-curve-getclosestpointto
entn pt
1e
6
setq
flag T
flag
defun
nea
p1 p2
polar
p1
angle
p1 p2
1e
2
defun
process
pll ell
setq
plll
nil
eln
nil
chl t pl pll
while
or
length
plll
3
not
vl-every
lambda
x
vl-position
x chl
plll
setq
p
car
pll
setq
plll
cons
p plll
setq
chl
LM:ConvexHull plll
setq
pll
cdr
pll
command
"_.PLINE"
foreach
p plll
command
"_non"
p
command
"_C"
setq
elll
mapcar
lambda
a b
list
a b
plll
cdr
reverse
cons
car
plll
reverse
plll
foreach
e elll
if
not
or
vl-position
e ell
vl-position
e el
vl-position
e en
vl-position
reverse
e
ell
vl-position
reverse
e
el
vl-position
reverse
e
en
setq
eln
cons
e eln
en
cons
e en
if
eln
if
length
eln
1
progn
setq
pll3
reverse
member
cadar
eln
reverse
member
caar
eln
append
pl pl
if
length
pll3
1-
length
pl
setq
pll3
reverse
member
caar
eln
reverse
member
cadar
eln
append
pl pl
while
or
not
insidep
nea
car
pll3
cadr
pll3
lw
not
insidep
nea
cadr
pll3
car
pll3
lw
not
insidep
nea
cadr
pll3
caddr
pll3
lw
not
insidep
nea
caddr
pll3
cadr
pll3
lw
not
insidep
nea
car
pll3
caddr
pll3
lw
not
insidep
nea
caddr
pll3
car
pll3
lw
progn
setq
li1
entmakex
list
0
"LINE"
cons
10
car
pll3
cons
11
cadr
pll3
setq
f
length
vlax-invoke
vlax
ename
vla-object
li1
'intersectwith
vlax
ename
vla-object
lw
acextendnone
6
entdel
li1
f
progn
setq
li2
entmakex
list
0
"LINE"
cons
10
cadr
pll3
cons
11
caddr
pll3
setq
f
length
vlax-invoke
vlax
ename
vla-object
li2
'intersectwith
vlax
ename
vla-object
lw
acextendnone
6
entdel
li2
f
progn
setq
li3
entmakex
list
0
"LINE"
cons
10
car
pll3
cons
11
caddr
pll3
setq
f
length
vlax-invoke
vlax
ename
vla-object
li3
'intersectwith
vlax
ename
vla-object
lw
acextendnone
6
entdel
li3
f
setq
pll3
cons
last
pll3
reverse
cdr
reverse
pll3
setq
ell3
mapcar
lambda
a b
list
a b
pll
cdr
reverse
cons
car
pll
reverse
pll
setq
lw
car
entsel
\n
Pick concave polygon LWPOLYLINE..."
while
not
and
lw
cdr
assoc
0
entget
lw
"LWPOLYLINE"
or
cdr
assoc
70
entget
lw
1
cdr
assoc
70
entget
lw
129
vl-every
zerop
mapcar
cdr
vl
remove
if
not
lambda
x
car
x
42
entget
lw
prompt
\n
Missed or wrong entity picked... Pick concave polygon LWPOLYLINE again..."
setq
lw
car
entsel
setq
pl
mapcar
cdr
vl
remove
if
not
lambda
x
car
x
10
entget
lw
setq
el
mapcar
lambda
a b
list
a b
pl
cdr
reverse
cons
car
pl
reverse
pl
setq
ch
LM:ConvexHull pl
if
vl-every
lambda
x
vl-position
x ch
pl
prompt
\n
Picked convex polygon..."
progn
setq
pll pl ell el eln t
while
eln
if
and
pll3 ell3
process pll3 ell3
process pll ell
princ
[Select]
defun
c:poltriang
;;triangulate polygonal LWPOLYLINE
defun
LM:ConvexHull
lst
ch p0
cond
length
lst
4
lst
setq
p0
car
lst
foreach
p1
cdr
lst
if
or
cadr
p1
cadr
p0
and
cadr
p1
cadr
p0
car
p1
car
p0
setq
p0 p1
setq
lst
vl-remove
p0 lst
setq
lst
append
list
p0
lst
setq
lst
vl-sort
lst
function
lambda
a b
c d
if
or
equal
setq
c
angle
p0 a
setq
d
angle
p0 b
1e
8
and
or
equal
c
0.0
1e
8
equal
c
2
pi
1e
8
or
equal
d
0.0
1e
8
equal
d
2
pi
1e
8
distance
list
car
p0
cadr
p0
a
distance
list
car
p0
cadr
p0
b
c d
setq
ch
list
caddr
lst
cadr
lst
car
lst
foreach
pt
cdddr
lst
setq
ch
cons
pt ch
while
and
caddr
ch
LM:Clockwise
p
caddr
ch
cadr
ch
pt
setq
ch
cons
pt
cddr
ch
reverse
ch
defun
LM:Clockwise
p
p1 p2 p3
car
p2
car
p1
cadr
p3
cadr
p1
cadr
p2
cadr
p1
car
p3
car
p1
1e
8
defun
insidep
pt entn
vl-load-com
if
and
pt entn
progn
setq
obj1
vlax
ename
vla-object
entn
setq
obj2
car
vlax-invoke
obj1 'Offset
0.001
obj3
car
vlax-invoke
obj1 'Offset
0.001
if
vla-get-area
obj2
vla-get-area
obj3
progn
set
'big obj2
set
'small obj3
progn
set
'big obj3
set
'small obj2
setq
p1
big pt
p2
small pt
if
distance
pt p1
distance
pt p2
setq
flag T
setq
flag
nil
mapcar
function
lambda
x
progn
vla-delete
x
vlax-release-object
x
list
big small
if
equal
trans
pt entn
0
entn pt
1e
6
setq
flag T
flag
defun
nea
p1 p2
polar
p1
angle
p1 p2
1e
2
defun
process
pll ell
setq
plll
nil
eln
nil
chl t pl pll
while
or
length
plll
3
not
vl-every
lambda
x
vl-position
x chl
plll
setq
p
car
pll
setq
plll
cons
p plll
setq
chl
LM:ConvexHull plll
setq
pll
cdr
pll
command
"_.PLINE"
foreach
p plll
command
"_non"
p
command
"_C"
setq
elll
mapcar
lambda
a b
list
a b
plll
cdr
reverse
cons
car
plll
reverse
plll
foreach
e elll
if
not
or
vl-position
e ell
vl-position
e el
vl-position
e en
vl-position
reverse
e
ell
vl-position
reverse
e
el
vl-position
reverse
e
en
setq
eln
cons
e eln
en
cons
e en
if
eln
if
length
eln
1
progn
setq
pll3
reverse
member
cadar
eln
reverse
member
caar
eln
append
pl pl
if
length
pll3
1-
length
pl
setq
pll3
reverse
member
caar
eln
reverse
member
cadar
eln
append
pl pl
while
or
not
insidep
nea
car
pll3
cadr
pll3
lw
not
insidep
nea
cadr
pll3
car
pll3
lw
not
insidep
nea
cadr
pll3
caddr
pll3
lw
not
insidep
nea
caddr
pll3
cadr
pll3
lw
not
insidep
nea
car
pll3
caddr
pll3
lw
not
insidep
nea
caddr
pll3
car
pll3
lw
progn
setq
li1
entmakex
list
0
"LINE"
cons
10
car
pll3
cons
11
cadr
pll3
setq
f
length
vlax-invoke
vlax
ename
vla-object
li1
'intersectwith
vlax
ename
vla-object
lw
acextendnone
6
entdel
li1
f
progn
setq
li2
entmakex
list
0
"LINE"
cons
10
cadr
pll3
cons
11
caddr
pll3
setq
f
length
vlax-invoke
vlax
ename
vla-object
li2
'intersectwith
vlax
ename
vla-object
lw
acextendnone
6
entdel
li2
f
progn
setq
li3
entmakex
list
0
"LINE"
cons
10
car
pll3
cons
11
caddr
pll3
setq
f
length
vlax-invoke
vlax
ename
vla-object
li3
'intersectwith
vlax
ename
vla-object
lw
acextendnone
6
entdel
li3
f
setq
pll3
cons
last
pll3
reverse
cdr
reverse
pll3
setq
ell3
mapcar
lambda
a b
list
a b
pll
cdr
reverse
cons
car
pll
reverse
pll
setq
lw
car
entsel
\n
Pick polygonal LWPOLYLINE..."
while
not
and
lw
cdr
assoc
0
entget
lw
"LWPOLYLINE"
or
cdr
assoc
70
entget
lw
1
cdr
assoc
70
entget
lw
129
vl-every
zerop
mapcar
cdr
vl
remove
if
not
lambda
x
car
x
42
entget
lw
prompt
\n
Missed or wrong entity picked... Pick polygonal LWPOLYLINE again..."
setq
lw
car
entsel
setq
pl
mapcar
cdr
vl
remove
if
not
lambda
x
car
x
10
entget
lw
setq
el
mapcar
lambda
a b
list
a b
pl
cdr
reverse
cons
car
pl
reverse
pl
setq
ch
LM:ConvexHull pl
if
vl-every
lambda
x
vl-position
x ch
pl
foreach
tr
mapcar
lambda
a b
list
car
pl
a b
cdr
pl
cddr
pl
command
"_.PLINE"
foreach
p tr
command
"_non"
p
command
"_C"
progn
setq
pll pl ell el eln t
while
eln
if
and
pll3 ell3
process pll3 ell3
process pll ell
princ
Thanks, M.R.
[EDIT : Updated code and it works...]
Last Edit: June 19, 2019, 12:34:29 AM by ribarm
Logged
Marko Ribar, d.i.a.
(graduated engineer of architecture)
M.R. on Youtube
ribarm
Gator
WWW
Re: splitconcavepolygon2convexpolygons-triangles
Reply #1 on:
March 23, 2016, 06:17:00 PM »
Fixed code... You can test it and inform me if somethings wrong...
Thanks, M.R.
Logged
Marko Ribar, d.i.a.
M.R. on Youtube
ribarm
Gator
WWW
Reply #2 on:
March 24, 2016, 11:27:00 AM »
As addition, here is my version of polygon centroid based on previously posted algorithm...
[Select]
defun
polygoncentroid
lw
p insidep nea triangarea gravitycenttriang process p pl el ch pll ell chl eln plll elll pll3 ell3 en li1 li2 li3 f trl ar mx my
defun
LM:ConvexHull
lst
ch p0
cond
length
lst
4
lst
setq
p0
car
lst
foreach
p1
cdr
lst
if
or
cadr
p1
cadr
p0
and
cadr
p1
cadr
p0
car
p1
car
p0
setq
p0 p1
setq
lst
vl-remove
p0 lst
setq
lst
append
list
p0
lst
setq
lst
vl-sort
lst
function
lambda
a b
c d
if
or
equal
setq
c
angle
p0 a
setq
d
angle
p0 b
1e
8
and
or
equal
c
0.0
1e
8
equal
c
2
pi
1e
8
or
equal
d
0.0
1e
8
equal
d
2
pi
1e
8
distance
list
car
p0
cadr
p0
a
distance
list
car
p0
cadr
p0
b
c d
setq
ch
list
caddr
lst
cadr
lst
car
lst
foreach
pt
cdddr
lst
setq
ch
cons
pt ch
while
and
caddr
ch
LM:Clockwise
p
caddr
ch
cadr
ch
pt
setq
ch
cons
pt
cddr
ch
reverse
ch
defun
LM:Clockwise
p
p1 p2 p3
car
p2
car
p1
cadr
p3
cadr
p1
cadr
p2
cadr
p1
car
p3
car
p1
1e
8
defun
insidep
pt entn
vl-load-com
if
and
pt entn
progn
setq
obj1
vlax
ename
vla-object
entn
setq
obj2
car
vlax-invoke
obj1 'Offset
0.001
obj3
car
vlax-invoke
obj1 'Offset
0.001
if
vla-get-area
obj2
vla-get-area
obj3
progn
set
'big obj2
set
'small obj3
progn
set
'big obj3
set
'small obj2
setq
p1
big pt
p2
small pt
if
distance
pt p1
distance
pt p2
setq
flag T
setq
flag
nil
mapcar
function
lambda
x
progn
vla-delete
x
vlax-release-object
x
list
big small
if
equal
trans
pt entn
0
entn pt
1e
6
setq
flag T
flag
defun
nea
p1 p2
polar
p1
angle
p1 p2
1e
2
defun
triangarea
p1 p2 p3
unit mid v12 v13 v1 v21 v23 v2 c cz r ar
defun
unit
v
mapcar
lambda
x
x
distance
0.0
0.0
0.0
v
v
defun
mid
p1 p2
mapcar
lambda
a b
a b
2.0
p1 p2
setq
v12
unit
mapcar
p2 p1
setq
v13
unit
mapcar
p3 p1
setq
v1
unit
mid v12 v13
setq
v21
mapcar
v12
setq
v23
unit
mapcar
p3 p2
setq
v2
unit
mid v21 v23
setq
c
inters
p1
mapcar
p1 v1
p2
mapcar
p2 v2
nil
setq
cz
trans
c
0
v12
setq
r
distance
mapcar
0.0
0.0
trans
p1
0
v12
cz
setq
ar
r
0.5
distance
p1 p2
distance
p2 p3
distance
p3 p1
ar
defun
gravitycenttriang
p1 p2 p3
mid p12 p23 p31 c
defun
mid
p1 p2
mapcar
lambda
a b
a b
2.0
p1 p2
setq
p12
mid p1 p2
setq
p23
mid p2 p3
setq
p31
mid p3 p1
setq
c
inters
p12 p3 p1 p23
c
defun
process
pll ell
setq
plll
nil
eln
nil
chl t pl pll
while
or
length
plll
3
not
vl-every
lambda
x
vl-position
x chl
plll
setq
p
car
pll
setq
plll
cons
p plll
setq
chl
LM:ConvexHull plll
setq
pll
cdr
pll
setq
trl
cons
plll trl
setq
elll
mapcar
lambda
a b
list
a b
plll
cdr
reverse
cons
car
plll
reverse
plll
foreach
e elll
if
not
or
vl-position
e ell
vl-position
e el
vl-position
e en
vl-position
reverse
e
ell
vl-position
reverse
e
el
vl-position
reverse
e
en
setq
eln
cons
e eln
en
cons
e en
if
eln
if
length
eln
1
progn
setq
pll3
reverse
member
cadar
eln
reverse
member
caar
eln
append
pl pl
if
length
pll3
1-
length
pl
setq
pll3
reverse
member
caar
eln
reverse
member
cadar
eln
append
pl pl
while
or
not
insidep
nea
car
pll3
cadr
pll3
lw
not
insidep
nea
cadr
pll3
car
pll3
lw
not
insidep
nea
cadr
pll3
caddr
pll3
lw
not
insidep
nea
caddr
pll3
cadr
pll3
lw
not
insidep
nea
car
pll3
caddr
pll3
lw
not
insidep
nea
caddr
pll3
car
pll3
lw
progn
setq
li1
entmakex
list
0
"LINE"
cons
10
car
pll3
cons
11
cadr
pll3
setq
f
length
vlax-invoke
vlax
ename
vla-object
li1
'intersectwith
vlax
ename
vla-object
lw
acextendnone
6
entdel
li1
f
progn
setq
li2
entmakex
list
0
"LINE"
cons
10
cadr
pll3
cons
11
caddr
pll3
setq
f
length
vlax-invoke
vlax
ename
vla-object
li2
'intersectwith
vlax
ename
vla-object
lw
acextendnone
6
entdel
li2
f
progn
setq
li3
entmakex
list
0
"LINE"
cons
10
car
pll3
cons
11
caddr
pll3
setq
f
length
vlax-invoke
vlax
ename
vla-object
li3
'intersectwith
vlax
ename
vla-object
lw
acextendnone
6
entdel
li3
f
setq
pll3
cons
last
pll3
reverse
cdr
reverse
pll3
setq
ell3
mapcar
lambda
a b
list
a b
pll
cdr
reverse
cons
car
pll
reverse
pll
if
and
lw
cdr
assoc
0
entget
lw
"LWPOLYLINE"
or
cdr
assoc
70
entget
lw
1
cdr
assoc
70
entget
lw
129
vl-every
zerop
mapcar
cdr
vl
remove
if
not
lambda
x
car
x
42
entget
lw
progn
setq
pl
mapcar
cdr
vl
remove
if
not
lambda
x
car
x
10
entget
lw
setq
el
mapcar
lambda
a b
list
a b
pl
cdr
reverse
cons
car
pl
reverse
pl
setq
ch
LM:ConvexHull pl
if
vl-every
lambda
x
vl-position
x ch
pl
progn
setq
p
car
pl
setq
trl
mapcar
lambda
a b
list
p a b
cdr
pl
cddr
pl
progn
setq
pll pl ell el eln t
while
eln
if
and
pll3 ell3
process pll3 ell3
process pll ell
setq
ar
0.0
mx
0.0
my
0.0
foreach
tr trl
setq
ar
ar
triangarea
car
tr
cadr
tr
caddr
tr
setq
mx
mx
triangarea
car
tr
cadr
tr
caddr
tr
car
gravitycenttriang
car
tr
cadr
tr
caddr
tr
setq
my
my
triangarea
car
tr
cadr
tr
caddr
tr
cadr
gravitycenttriang
car
tr
cadr
tr
caddr
tr
list
mx ar
my ar
0.0
prompt
\n
Wrong entity supplied as function argument or nil argument... Please supply polygon LWPOLYLINE as argument next time..."
Test :
[Select]
setq
cent
polygoncentroid
car
entsel
\n
M.R.
P.S. My testing results are identical with AutoDesks (polygon -> region -> centroid), you can now check it...
Last Edit: June 19, 2019, 12:35:04 AM by ribarm
Logged
Marko Ribar, d.i.a.
M.R. on Youtube
Print
Pages: [
1
Go Up
« previous
next »
TheSwamp
Code Red
Topic:
