So here is a snippet of the code I'm writing. I've commented out the section where i need a bit of help.
I found the solution to this before and I know it involves exploding and then grouping the array and then subtracting it.
Any and all help would be appreciated. In know it isn't all that difficult but I haven't figured it out.
(command "array" pin_hole1 "" "R" shlf_pin_cnt 2 shlf_pin_spcg (- Box_Depth (* Shlf_Pin_SetB 2) dado_inset back_thick))
Insert code to make array one solid object that can be subtracted from the solide "lside" noted in the last line
Name of solid object (array) = holesL
(command "ucs" "w")
(command "copy" holesL "" "0,0,0" (list (+ (- Box_Width (* Side_thick 2)) Shlf_pin_dep) 0 0))
(setq HolesR (entlast))
(command "subtract" lside "" holesL "")
