Author Topic: AutoLISP Performance Tips: strings  (Read 3854 times)
divtiply
« on: February 04, 2015, 05:11:27 AM »
  1. (defun strcat-slow (/ tm out str)
  2.   (setq out ""
  3.         str "x"
  4.         tm (car (_vl-times)))
  5.   (repeat 100000
  6.     (setq out (strcat out str)))
  7.   (- (car (_vl-times)) tm))
  8.
  1. (defun strcat-fast (/ tm out str)
  2.   (setq out nil
  3.         str "x"
  5.   (repeat 100000
  6.     (setq out (cons str out)))
  7.   (setq out (apply (function strcat) (reverse out)))
  8.   (- (car (_vl-times)) tm))
  9.
strcat-slow takes about 7 seconds on my computer, strcat-fast -- less than 70 ms. It is 100 times (sic!) faster.
The reason is AutoLISP interns strings, thats why not only (= "hello" "hello") but (eq "hello" "hello") is t.
Marc'Antonio Alessi
  • Marco
Re: AutoLISP Performance Tips: strings
« Reply #1 on: February 04, 2015, 09:06:17 AM »
Yes, setq a long string explicitly is time consuming... apply do it internally.
With short string is faster:
(defun strcat-slow (/ tm str)
  (setq out ""
        str "x"
  (repeat 100000
(defun strcat-10 (/ tm str s10 o10)
  (setq out ""
        str "x"
  (repeat 10000
    (setq o10 "")
    (repeat 10
      (setq o10 (strcat o10 str))
    (setq out (strcat out o10))
(defun strcat-100 (/ tm str s10 o10)
  (setq out ""
        str "x"
  (repeat 1000
    (setq o10 "")
    (repeat 100
: (strcat-100)
281
: (strlen out)
100000
: (strcat-10)
1060
: (strlen out)
100000
: (strcat-slow)
7379
: (strlen out)
100000
divtiply
« Reply #2 on: February 04, 2015, 06:51:41 PM »
apply does not concatenates strings!
as I've wrote already - AutoLISP _INTERNS_ strings.
That's mean every time you're setq a string to a symbol AutoLISP searchs internal buffer for this string and if it finds then string is reused.
Marc'Antonio Alessi
  • Marco
« Reply #3 on: February 05, 2015, 02:27:43 AM »
Maybe my English is not very good but I never said that "apply concatenates strings" but "setq a long string..."
gile
  • Marseille, France
« Reply #4 on: February 05, 2015, 04:26:39 AM »
What about using ascii codes (integers) list ?
  1. (defun strcat-faster (/ tm lst out char)
  2.   (setq char (ascii "x")
  3.         tm  (car (_vl-times))
  4.   )
  5.   (repeat 100001
  6.     (setq lst (cons char lst))
  7.   )
  8.   (setq out (vl-list->string (reverse lst)))
  9.   (- (car (_vl-times)) tm)
  10. )
Marc'Antonio Alessi
  • Marco
« Reply #5 on: February 05, 2015, 11:53:08 AM »
  4.   )
  5.   (repeat 100001
  7.   )
  10. )
Yes, seem faster:
(defun strcat-faster (/  lst out char)
     (repeat 100001
(defun strcat-fast (/ out str)
     (setq out nil
           str "x"
     (repeat 100000
; ONLY for example > different output (spaces)
(defun strcat-ALE (/ str lst)
  (setq str "x")
  (repeat 100000 (setq lst (cons str lst)))
  (vl-string-trim  "()" (vl-princ-to-string lst))
Benchmark.lsp | © 2005 Michael Puckett | All Rights Reserved
Elapsed milliseconds / relative speed for 32 iteration(s):
    (STRCAT-FASTER).....1934 / 2.37 <fastest>
    (STRCAT-FASTER).....1935 / 2.37
    (STRCAT-ALE)........2450 / 1.87
    (STRCAT-ALE)........2465 / 1.86
    (STRCAT-FASTER).....2480 / 1.85
    (STRCAT-FAST).......3619 / 1.27
    (STRCAT-FAST).......3963 / 1.16
    (STRCAT-FAST).......4571 / 1
    (STRCAT-ALE)........4586 / 1 <slowest>
    (STRCAT-ALE)........2480 / 1.33 <fastest>
    (STRCAT-ALE)........2574 / 1.28
    (STRCAT-FAST).......2683 / 1.23
    (STRCAT-FAST).......2699 / 1.22
    (STRCAT-FASTER).....2793 / 1.18
    (STRCAT-FASTER).....2855 / 1.15
    (STRCAT-FAST).......3292 / 1
    (STRCAT-FASTER).....3292 / 1 <slowest>
    (STRCAT-FASTER).....1919 / 1.73 <fastest>
    (STRCAT-FASTER).....2044 / 1.63
    (STRCAT-ALE)........2481 / 1.34
    (STRCAT-FAST).......2684 / 1.24
    (STRCAT-FAST).......2699 / 1.23
    (STRCAT-ALE)........2917 / 1.14
    (STRCAT-FAST).......3213 / 1.03
    (STRCAT-ALE)........3323 / 1 <slowest>
Marc'Antonio Alessi
  • Marco
« Reply #6 on: February 05, 2015, 04:26:23 PM »
Just for fun:
(defun strcat-ALE2 (/ str lst)
  (setq str "x")
  (repeat 50000 (setq lst (cons str lst)))
  (strcat
    "x"
    (vl-string-translate
      "x " "xx" (vl-string-trim  "()" (vl-princ-to-string lst))
irneb
« Reply #7 on: February 06, 2015, 12:59:12 AM »
Yes, exactly. Though it's worse than just the internal store of string values to be re-used. It also creates immutable strings, i.e. you don't change a string using strcat, you're creating a new one from the combination.
This is the same way as DotNet does it. And there it's also a point of extreme inefficiency. There the usual way to concatenate faster is to use a StringBuilder, basically a growable array of chars which then as a final step gets converted to a string by simply mapping the interned new string with the char array.
Very similar to the vl-list->string idea, except that using the array it would be even faster since that's just an O(1) operation, while the vl-list->string is an O(N) stepping through each value in the linked list in turn. Now, I'm wondering if using a safe-array in Lisp would be similarly beneficial - that is "if you can convert to-and-from a string <-> safe-array".
