[assembly
: CommandClass
(typeof(RectangleDrawJig
.CommandMethods))]
namespace RectangleDrawJig
public class CommandMethods
[CommandMethod("Test", CommandFlags.Modal)]
public void Test()
Database db = doc.Database;
Editor ed = doc.Editor;
PromptPointResult ppr = ed.GetPoint("\nSpecify the first corner: ");
if (ppr.Status != PromptStatus.OK) return;
Matrix3d ucs = ed.CurrentUserCoordinateSystem;
Point3d basePt = ppr.Value;
using(Line line
= new Line
(basePt, basePt
)) using(Polyline pline
= new Polyline
(4)) {
Point2d basePt2d
= new Point2d
(basePt
.X, basePt
.Y); pline.AddVertexAt(0, basePt2d, 0.0, 0.0, 0.0);
pline.AddVertexAt(1, basePt2d, 0.0, 0.0, 0.0);
pline.AddVertexAt(2, basePt2d, 0.0, 0.0, 0.0);
pline.AddVertexAt(3, basePt2d, 0.0, 0.0, 0.0);
pline.Closed = true;
RectangleJig jig
= new RectangleJig
(pline, line, ucs
); PromptResult pr = ed.Drag(jig);
if (pr.Status == PromptStatus.OK)
BlockTableRecord btr =
(BlockTableRecord)tr.GetObject(db.CurrentSpaceId, OpenMode.ForWrite);
pline.TransformBy(ucs);
btr.AppendEntity(pline);
tr.AddNewlyCreatedDBObject(pline, true);
btr.AppendEntity(line);
tr.AddNewlyCreatedDBObject(line, true);
tr.Commit();
class RectangleJig : DrawJig
private Polyline pline;
private Line line;
private Matrix3d ucs2wcs, wcs2ucs;
private Point3d dragPt;
private Point2d basePt;
public RectangleJig(Polyline pline, Line line, Matrix3d ucs)
this.pline = pline;
this.line = line;
this.ucs2wcs = ucs;
this.wcs2ucs = ucs.Inverse();
this.dragPt = line.EndPoint;
this.basePt = pline.GetPoint2dAt(0);
protected override bool WorldDraw(Autodesk.AutoCAD.GraphicsInterface.WorldDraw draw)
Autodesk.AutoCAD.GraphicsInterface.WorldGeometry geo = draw.Geometry;
if (geo != null)
geo.PushModelTransform(ucs2wcs);
geo.Draw(line);
geo.Draw(pline);
geo.PopModelTransform();
return true;
protected override SamplerStatus Sampler(JigPrompts prompts)
PromptPointResult ppr = prompts.AcquirePoint("\nSpecify the opposite corner: ");
if (ppr.Value.IsEqualTo(dragPt))
return SamplerStatus.NoChange;
dragPt = ppr.Value;
Update();
return SamplerStatus.OK;
private void Update()
Point3d pt = dragPt.TransformBy(wcs2ucs);
line.EndPoint = pt;
pline
.SetPointAt(1,
new Point2d
(pt
.X, basePt
.Y)); pline
.SetPointAt(2,
new Point2d
(pt
.X, pt
.Y)); pline
.SetPointAt(3,
new Point2d
(basePt
.X, pt
.Y)); }
