Welcome,
Guest
. Please
login
or
register
1 Hour
1 Day
1 Week
1 Month
Forever
News:
Home
Help
Login
Register
TheSwamp
Code Red
.NET
Topic:
TransformBy and blocks
« previous
next »
Print
Pages: [
1
Go Down
Author
Topic: TransformBy and blocks (Read 1724 times)
cannorth
Guest
on:
May 06, 2013, 05:32:11 PM »
Hello,
Is it possible to use the TransformBy function to scale down a block that's loaded in? Could I see a snippet of code as an example?
Thanks,
cannorth
Logged
Mesozoic relic
Seagull
class keyThumper<T>:ILazy<T>
Re: TransformBy and blocks
Reply #1 on:
May 06, 2013, 06:45:14 PM »
Does this help
http://www.theswamp.org/index.php?topic=37686.msg427185#msg427185
What do you mean by
'loaded in'
Logged
Print
Pages: [
1
Go Up
« previous
next »
TheSwamp
Code Red
.NET
Topic:
