Author Topic: Get attribute tagstring from block  (Read 6059 times)
GDF
« on: July 08, 2011, 02:08:29 PM »
How do I modify the code below to return the tagstring value "AttVal" of the attributed tag name?
(defun UpdateBlocks  (BlockName AttTag AttVal / ssBlocks ssObjects Block)
  (setq ssBlocks (ssget "x" (list (cons 2 BlockName))))
  (if ssBlocks
    (progn (setq ssObjects
                  (vla-get-ActiveSelectionSet
                    (vla-get-ActiveDocument (vlax-get-acad-object))))
           (vlax-for
                  Block  ssObjects
             (foreach
                    Attribute  (vlax-invoke Block "GetAttributes")
               (if (= (vla-get-TagString Attribute) AttTag)
                 (vla-put-TextString Attribute AttVal))
               (vla-update Attribute)))))
  (princ))
[code/]
Re: Get attribute tagstring from block
« Reply #1 on: July 08, 2011, 03:04:40 PM »
I'm not sure that I completely understand the question - do you want to return the value of the variable 'AttVal'?
If so, just make the variable the last evaluated expression:
(defun UpdateBlocks ( BlockName AttTag AttVal / ss )
  (if (ssget "_X" (list (cons 2 BlockName) (cons 66 1)))
      (vlax-for obj (setq ss (vla-get-ActiveSelectionSet (vla-get-ActiveDocument (vlax-get-acad-object))))
        (foreach att (vlax-invoke obj 'GetAttributes)
          (if (eq (vla-get-TagString att) AttTag)
            (vla-put-TextString att AttVal)
      (vla-delete ss)
      attval
GDF
« Reply #2 on: July 08, 2011, 03:16:16 PM »
Thanks Lee.
I want to read the existing tag value and then edit it...as per code below.
The code below does not print "NEWV1" to a dtext edit box, this exiting value for editing...which is my goal.
I hope this makes it clearer.
(defun C:SARIT  (/ NEWV1 NEWV2)
  (prompt "\n* To Rename Title Block Attribute *")
  (setq NEWV1 (getstring t "\n* Enter New Sheet Title <enter to leave unchanged> :"))
  (if (/= NEWV1 "")(UpdateBlocks "2436TBA" "SHT_TTL" NEWV1))
  (prompt "\n* Updating Sheet Number completed *")
  (setq NEWV2 (substr (getvar "dwgname") 1 (- (strlen (getvar "dwgname")) 4)))
  (setq NEWV2 (vl-string-subst "." "-" NEWV2))
  (UpdateBlocks "2436TBA" "A-01" NEWV2)
  (princ))
[code/]
« Reply #3 on: July 08, 2011, 03:42:56 PM »
Hi Gary,
How about something along these lines:
(defun c:sarit ( / new obj ss )
    (and
      (setq ss  (ssget "_X" '((0 . "INSERT") (2 . "2436TBA") (66 . 1))))
      (setq obj (vlax-ename->vla-object (ssname ss 0)))
      (setq new (LM:EditBox (cond ((LM:GetAttributeValue obj "SHT_TTL")) (""))))
      (LM:SetAttributeValue obj "SHT_TTL" new)
      (LM:SetAttributeValue obj "A-01" (vl-string-translate "-" "." (vl-filename-base (getvar 'DWGNAME))))
(defun LM:EditBox ( string / id )
  (and
    (< 0 (setq id (load_dialog "ACAD")))
    (new_dialog "acad_txtedit" id)
    (set_tile    "text_edit"  string)
    (action_tile "text_edit" "(setq string $value)")
    (if (zerop (start_dialog)) (setq string nil))
  (if (< 0 id) (unload_dialog id))
  string
(defun LM:GetAttributeValue ( block tag ) (setq tag (strcase tag))
  (vl-some
    (function
      (lambda ( attrib )
        (if (eq tag (strcase (vla-get-Tagstring attrib)))
          (vla-get-TextString attrib)
    (vlax-invoke block 'GetAttributes)
(defun LM:SetAttributeValue ( block tag value ) (setq tag (strcase tag))
  (vl-some
    (function
      (lambda ( attrib )
        (if (eq tag (strcase (vla-get-TagString attrib)))
          (progn (vla-put-TextString attrib value) value)
I have taken the attribute functions from here. I assumed you only wanted a single block updated, but it could be easily modified to update a set of blocks.
Lee
GDF
« Reply #4 on: July 08, 2011, 03:54:15 PM »
Lee
I have a beer with your name on it. Saying Thank You just is not good enough. I tried for an hour to hack out a solution. Now you have gotten me spoiled. I will study your solution and learn from it.
Gary
« Reply #5 on: July 08, 2011, 04:31:04 PM »
Good stuff Gary, I like beer  :lol:
You're very welcome, and of course, if you have any questions about any part of the code, I would be happy to provide clarification  :-)
EDIT: Looking back at the code, a faster way to approach it might be to first collect an association list of attribute objects with their tag string, then 'assoc' from this list when updating and reading the attribute values.
kdub_nz
  • Mesozoic keyThumper
  • SuperMod
« Reply #6 on: July 08, 2011, 05:35:23 PM »
That's what I do ... Slurp everything into an accoc list and go from there
Called Kerry in my other life
I live at UTC + 13.00
« Reply #7 on: July 08, 2011, 08:33:26 PM »
Perhaps this is a little more succinct  :-)
(defun c:sarit ( / _get _set lst new ss )
  (defun _get ( tag alist / ass )
    (if (setq ass (cdr (assoc tag alist))) (vla-get-textstring ass))
  (defun _set ( tag value alist / ass )
    (if (setq ass (cdr (assoc tag alist))) (vla-put-textstring ass value))
    (and
      (setq lst
        (mapcar'(lambda ( x ) (cons (vla-get-tagstring x) x))
          (vlax-invoke (vlax-ename->vla-object (ssname ss 0)) 'getattributes)
      (setq new (LM:EditBox (cond ((_get "SHT_TTL" lst)) (""))))
      (_set "SHT_TTL" new lst)
      (_set "A-01" (vl-string-translate "-" "." (vl-filename-base (getvar 'DWGNAME))) lst)
  (and
  string
GDF
« Reply #8 on: July 11, 2011, 11:51:13 AM »
Thanks again Lee
airportman
  • i customize when required
« Reply #9 on: December 18, 2012, 11:16:09 AM »
Lee Mac:
I have tried your code (modified it to suit my block and atts)...I get nothing. I'm not gettting a dialogue / DCL popping up either.
Am I missing something?
Perception is a state of mind  -/ Twitter = @hochanz -/ Intel i7 - 3.07GHz -/ 12GB Ram -/ Nvidia Quadro FX 1800
« Reply #10 on: December 18, 2012, 01:55:38 PM »
Lee Mac:
Which code are you using and how have you modified it?
