Author Topic: Align Polyline to Polyline  (Read 2520 times)
chvnprasad
« on: April 03, 2012, 02:56:05 PM »
How to align one polyline to another polyline.both polylines are different number of verices. If i select source polyline and target polyline,source polyline should be align(coincide) with target poly line
« Last Edit: April 03, 2012, 02:59:42 PM by chvnprasad »
irneb
Re: Align Polyline to Polyline
« Reply #1 on: April 03, 2012, 04:24:07 PM »
How should they align? Simply the picked vectors to be co-linear? Or should the one also scale such that the picked vectors are the same length and / or start & end points? Are both always on the same UCS? Should something else than the picked vectors be used for alignment, say vectors closest to each other? What about curved vectors, should these be ignored?
alanjt
  • Standby for witty remark...
« Reply #2 on: April 03, 2012, 10:28:18 PM »
Would this be essential to using Rotate by Reference?
eg.
Command: r
ROTATE
Current positive angle in UCS:  ANGDIR=counterclockwise  ANGBASE=0d
Select objects: Specify opposite corner: 1 found
Select objects:
Specify base point:
Specify rotation angle or [Copy/Reference] <0d>: r
Dropbox
irneb
« Reply #3 on: April 04, 2012, 03:58:50 AM »
Or simply using the Align command? E.g.:
  1.
  2. (defun c:AlignPoly (/ SelPoly p1 p2 en1 en2 p3 p4)
  3.   (defun SelPoly ( msg / p )
  4.     (while (and (setq p (entsel msg)) (not (eq (cdr (assoc 0 (entget (car p)))) "LWPOLYLINE")))
  5.       (princ "That's not a polyline, try again.\n"))
  6.     p)
  7.
  8.   (if (setq p1 (SelPoly "Pick Polyline to rotate/move/scale <Exit>: "))
  9.     (exit))
  10.   (if (setq p2 (SelPoly "Pick target Polyline <Exit>: "))
  11.     (exit))
  12.   (command "._ZOOM" "_Object" en1 en2 "")
  13.         p4 (vlax-curve-getPointAtParam en2 (1+ p2)))
  14.           (setq p2 (vlax-curve-getPointAtParam en2 p2))
  15.           2 1)
  16.   (grdraw p3 p4 2 1)
  17.   (initget "Swap Continue")
  18.   (if (eq (getkword "Is this corect? [Swap/Continue] <Continue>: ") "Swap")
  19.     (progn (redraw) (command "._ALIGN" en1 "" p3 p2 p1 p4 ""))
  20.     (progn (redraw) (command "._ALIGN" en1 "" p1 p2 p3 p4 "")))
  21.   (princ))
ribarm
  • Marko Ribar, architect
« Reply #4 on: April 04, 2012, 04:23:27 AM »
Irneb, I think command ALIGN has some sort of bug when calling from inside routine...
I suggest that you use (arxload "geom3d.arx") and call (align) sub-function shown in this example :
http://www.theswamp.org/index.php?topic=41382.msg464959#msg464959
M.R.
M.R. on Youtube
irneb
« Reply #5 on: April 04, 2012, 04:38:21 AM »
I don't know ... for me on Vanilla 2012 it seems to work fine.
alanjt
« Reply #6 on: April 04, 2012, 09:54:23 AM »
Oh yeah, Align. drrr
Dropbox
