Author Topic: Help! Nothing to see on my Block Authoring Palettes!  (Read 3429 times)
mammajamma
« on: December 06, 2011, 09:38:54 AM »
AutoCAD 2010.
While there are cryptic little icons across the top of my block editor, the Block Authoring Palettes have lost all their stuff. All I see on any of the tabs (Parameters, Actions, etc.) is a message about how to customize tool palettes. I didn't do anything to them that I'm aware of, and they were working previously. Can anyone tell me how to get the content back?
When I go to the Authoring Toolpalette tab in the Customize Toolpalette dialogue, I can see the 4 tabs, but have no idea how to go about repopulating them.
Thanks.
Matt__W
  • I like my water diluted.
Re: Help! Nothing to see on my Block Authoring Palettes!
« Reply #1 on: December 06, 2011, 09:50:14 AM »
You can create a NEW GROUP and drag/drop them from the left onto the right side.
Or check the CUI.  There MUST be something in there for those palettes.
Autodesk Expert Elite
dgorsman
« Reply #2 on: December 06, 2011, 10:42:48 AM »
I've seen this where the Authoring palettes were moved from their installed location.  Check the Authoring palettes path in the CONFIG/OPTIONS dialog and make sure its pointing to the right place.
try {GreatPower;}
   catch (notResponsible)
      {NextTime(PlanAhead);}
   finally
      {MasterBasics;}
mammajamma
« Reply #3 on: December 06, 2011, 04:21:47 PM »
I'm pointing to the right place, and even restored the directory back to a previous point in time (hoping beyond hope that it was prior to the loss). Nada. There are files (ATC) there, which are obviously referencing the tabs.
I can't find anywhere in the CUI, so far, that has anything to do with Authoring Palettes.
I'm not dead in the water, because I can use the icons along with the command line options, but it's lots slower.
Oh, also, changing my workspace and my profile has no impact.
 :realmad:
