Author Topic: {Challenge} Point Sort  (Read 2066 times)
Jeff H
« on: February 12, 2011, 04:09:53 PM »
I do not know if this is a good one but I threw together code real quick and created 2 drawings
1. 20,000 random points with x,y,z (-100 to 100, -100 to 100, 0)
2. 20,000 random points with x,y,z (-100 to 100, -100 to 100, -100 to 100)
Any ideas maybe sort by closest to orgin in QI , then closest to orgin QII, then QIII, then QIV then repeat.
I do not know. I sounded like a good idea until i started typing all this.
2 drawings attached I saved them down to 2004
pkohut
Re: {Challenge} Point Sort
« Reply #1 on: February 12, 2011, 04:40:56 PM »
What are QI to QIV in reference to? Otherwise point sorting is relatively easy.
New tread (not retired) - public repo at https://github.com/pkohut
« Reply #2 on: February 12, 2011, 04:46:44 PM »
I imagine they'd be geomertic quadrants Paul.
0-90, 90-180 etc
Jeff H
« Reply #3 on: February 12, 2011, 04:57:57 PM »
Quadrant 1 , Quadrant 2 , Quadrant 3 .........
Yeah I was trying to come up with a idea like sorting points by largest difference between a Points X & Y value, but it still boils down to essentially they same thing.
I was trying to spark an idea.
gile
  • Marseille, France
« Reply #4 on: February 12, 2011, 05:00:19 PM »
pts.Sort((p1, p2) => p1.DistanceTo(Point3d.Origin).CompareTo(p2.DistanceTo(Point3d.Origin)));
