Author Topic: Dynamic Block of Doors ?  (Read 4259 times)
knosaj
« on: January 15, 2011, 03:14:45 PM »
this is probably basic to you guys out there, but im just getting into this.
ive heard there is a dynamic block that i can place a block of a door, then with simple clicks (not ro, mi) i can change direction, flip it, or possibly what would be really cool, if i could change the size. all with the same block.
is it possible?
thanks in advance!  - i am in awe of the stuff you guys are making cad do, its all still a foreign language to me though.
Re: Dynamic Block of Doors ?
« Reply #1 on: January 16, 2011, 10:23:16 AM »
first make your door block
then in block editor add the Flip Action
and or Stretch action, If you want to ONLY stretch door in 3" increments set that as the linear values...
Welcome to The Swamp!
You will find that most here will help you do almost anything.
However you will have to start the task, as few of us will do it for you.
This way we help you learn, so that you may help others.
« Last Edit: January 16, 2011, 10:26:46 AM by Higgs Boson's Mate »
knosaj
« Reply #2 on: January 17, 2011, 12:52:18 AM »
thanks! -Ill see if i can get it to work.
sugarCAD
« Reply #3 on: January 27, 2011, 04:43:25 PM »
There is already a dynamic door block on the tool palettes, on the architectural tab. Open it in the block editor and see how that was done.
