hi, when i use the "darray" commanf after loading your lisp file, why not working..the command history like this one..
Command: darray
(L)inear/(R)ectangular/(P)olar/(A)rc ?: l
No unreferenced visual styles found.
Select objects: 1 found
Select objects:
Number of CopyArray: 5
Attach point...Regenerating model. (WHY THIS ONE NEEDED?)
Base point...
Press (A)ngle/(Q)uantity : Deleting block "_{DarrayBlock}_".
1 block deleted.
no function definition: ACET-SYS-SHIFT-DOWN
i tried it in autocad2004 n 2009.
is the object must be a block or..?
