Just as the title,use command textscr in cad system to show the text screen ,the lisp function (textscr) also has the same.but how can .net api to achieve this function ?
'...If you're using prior to AC2010 you'll need to reference acmgdinternal.dll2010 has the Autodesk.AutoCAD.Internal.Utils in the acmgd.dll module
