Author Topic: Code list  (Read 3902 times)
One Shot
Code list
« on: October 12, 2004, 05:39:01 PM »
A couple of weeks ago I came across a list of codes and their meaning here on The Swamp.  Can someone point me in the right direction? Please!
TR
Code list
« Reply #1 on: October 12, 2004, 08:51:22 PM »
What do you mean by codes? phpbb2 codes?
p.s. Nice to see someone from catty here. You're like 10 minutes from me. :]
Bob Garner
Code list
« Reply #2 on: October 13, 2004, 11:49:29 AM »
Welcome home, One Shot.
Bob G.
One Shot
Code list
« Reply #3 on: October 13, 2004, 12:21:35 PM »
Quote from: Bob Garner
Bob G.
Bob,
Thank you!
Tim,
I just moved up to Catty back in July from Gettysburg / Hanover Area.  My company tranfered me to work in Bernardsville, NJ.  Now to answer your question concern codes.  This list showed all the possible varibles in write lisp routine.
DanB
Code list
« Reply #4 on: October 13, 2004, 12:25:55 PM »
Not real sure this is was you were looking for but it was just posted again under my last topic.
Dan
(defun c:ninjasettings()
   (setvar 'acadlspasdoc 1)
   (setvar 'apbox 1)
   (setvar 'attdia 1)
   (setvar 'attmode 1)
   (setvar 'auditctl 0)
   (setvar 'bindtype 1)
   (setvar 'blipmode 0)
   (setvar 'cecolor "bylayer")
   (setvar 'celtype "bylayer")
   (setvar 'cmddia 1)
   (setvar 'clayer "0")
   (setvar 'coords 2)
   (setvar 'delobj 1)
   (setvar 'dimassoc 1)
   (setvar 'dragmode 2)
   (setvar 'dragp1 50)
   (setvar 'dragp2 50)
   (setvar 'dwgcheck 0)
   (setvar 'edgemode 1)
   (setvar 'elevation 0)
   (setvar 'expert 1)
              (setvar 'explmode 1)
   (setvar 'facetratio 1)
   (setvar 'facetres 10)
   (setvar 'filedia 1)
   (setvar 'filletrad 0)
   (setvar 'fillmode 1)
   (setvar 'fontalt "romans.shx")
   (setvar 'grips 1)
   (setvar 'hideprecision 1)
   (setvar 'highlight 1)
   (setvar 'hpbound 1)
   (setvar 'imagehlt 1)
              (setvar 'isavebak 1)
   (setvar 'isavepercent 0)
   (setvar 'isolines 100)
   (setvar 'logfilemode 0)
   (setvar 'lwdisplay 0)
   (setvar 'maxsort 5000)
   (setvar 'mbuttonpan 1)
   (setvar 'mirrtext 0)
   (setvar 'olequality 3)
   (setvar 'olestartup 1)
              (setvar 'osmode 0)
   (setvar 'pickadd 1)
   (setvar 'pickauto 1)
   (setvar 'pickfirst 1)
   (setvar 'pickstyle 1)
   (setvar 'plinegen 1)
   (setvar 'plinetype 2)
             ;(setvar 'plinewid 0)
   (setvar 'proxyshow 1)
   (setvar 'rasterpreview 0)
              (setvar 'rememberfolders 1)
   (setvar 'rtdisplay 0)
   (setvar 'savetime 5)
   (setvar 'sortents 1)
   (setvar 'textfill 1)
             ;(setvar 'treedepth -3020)
   (setvar 'ucsfollow 0)
   (setvar 'whiparc 0)
   (setvar 'xfadectl 75)
   (setvar 'xloadctl 2)
   (setvar 'zoomfactor 90)
(c:ninjasettings)
(princ "\n  Variables Set.....")
One Shot
Code list
« Reply #5 on: October 13, 2004, 12:27:12 PM »
Quote from: DanB
Dan
   (setvar 'apbox 1)
   (setvar 'attdia 1)
   (setvar 'attmode 1)
   (setvar 'cmddia 1)
   (setvar 'coords 2)
   (setvar 'delobj 1)
   (setvar 'dragp1 50)
   (setvar 'dragp2 50)
   (setvar 'expert 1)
   (setvar 'filedia 1)
   (setvar 'grips 1)
   (setvar 'hpbound 1)
              (setvar 'osmode 0)
   (setvar 'pickadd 1)
   (setvar 'whiparc 0)
(c:ninjasettings)
That was the list that I came across.  But don't remember where I saw this list.
ELOQUINTET
Code list
« Reply #6 on: October 13, 2004, 12:36:49 PM »
i did a search for variables and found it there
Code list
« Reply #7 on: October 13, 2004, 12:40:42 PM »
I remember there being a link posted somewhere that had all of the DXF codes listed and their use. I have not been able to find it, but if you look in the AutoCAD help file, you will find them all.
TR
Code list
« Reply #8 on: October 13, 2004, 01:05:00 PM »
Quote from: One Shot
Tim,
Wow...I work in Peapack. Small world.
Code list
« Reply #9 on: October 13, 2004, 01:50:52 PM »
I wrote this (I actually pulled it and quickly assembed it from a much larger app I wrote) about 10 years ago; haven't used it in at least 5. No doubt there are errors, certainly omissions. You are welcome to fix it, post it back and/or use it how you see fit.
(defun GetDxfDesc ( dxf )
        ((eq dxf -0001)  "Entity name")
        ((eq dxf -0002)  "Referenced entity name")
        ((eq dxf -0003)  "Start extended entity data")
        ((eq dxf  0004)  "Conditional operator")
        ((eq dxf  0005)  "Persistant reactor chain")
        ((eq dxf  0000)  "Type")
        ((eq dxf  0001)  "Primary value/Path")
        ((eq dxf  0002)  "Name")
        ((eq dxf  0003)  "Prompt/DIMPOST")
        ((eq dxf  0004)  "DIMAPOST")
        ((eq dxf  0005)  "Handle/DIMBLK")
        ((eq dxf  0006)  "Linetype/DIMBLK1")
        ((eq dxf  0007)  "Style/DIMBLK2")
        ((eq dxf  0008)  "Layer")
        ((eq dxf  0010)  "X of start ...")
        ((eq dxf  0011)  "X of end ...")
        ((eq dxf  0012)  "X of corner ...")
        ((eq dxf  0013)  "X of corner ...")
        ((eq dxf  0014)  "X of def point")
        ((eq dxf  0015)  "X of def point")
        ((eq dxf  0016)  "X of def point")
        ((eq dxf  0020)  "Y of start ...")
        ((eq dxf  0021)  "Y of end ...")
        ((eq dxf  0022)  "Y of corner ...")
        ((eq dxf  0023)  "Y of corner ...")
        ((eq dxf  0024)  "Y of def point")
        ((eq dxf  0025)  "Y of def point")
        ((eq dxf  0026)  "Y of def point")
        ((eq dxf  0030)  "Z of start ...")
        ((eq dxf  0031)  "Z of end ...")
        ((eq dxf  0032)  "Z of corner ...")
        ((eq dxf  0033)  "Z of corner ...")
        ((eq dxf  0034)  "Z of def point")
        ((eq dxf  0035)  "Z of def point")
        ((eq dxf  0036)  "Z of def point")
        ((eq dxf  0038)  "Elevation")
        ((eq dxf  0039)  "Thickness")
        ((eq dxf  0040)  "Radius/ht/size/width/DIMSCALE")
        ((eq dxf  0041)  "X scale/width/DIMASZ")
        ((eq dxf  0042)  "Y scale/bulge/DIMEXO")
        ((eq dxf  0043)  "Z scale/DIMDLI")
        ((eq dxf  0044)  "Column spacing/DIMEXE")
        ((eq dxf  0045)  "Row spacing/DIMRND")
        ((eq dxf  0046)  "DIMDLE")
        ((eq dxf  0047)  "DIMTP")
        ((eq dxf  0048)  "DIMTM")
        ((eq dxf  0048)  "Linetype scale")
        ((eq dxf  0050)  "Rotation/start angle")
        ((eq dxf  0051)  "End/oblique angle")
        ((eq dxf  0052)  "Oblique angle")
        ((eq dxf  0053)  "DIM text angle")
        ((eq dxf  0062)  "Color")
        ((eq dxf  0066)  "Entities follow flag")
        ((eq dxf  0067)  "Paper space flag")
        ((eq dxf  0068)  "Viewport flag")
        ((eq dxf  0069)  "Viewport number")
        ((eq dxf  0070)  "DIM type/misc flags")
        ((eq dxf  0071)  "Generation flag/DIMTOL")
        ((eq dxf  0072)  "Horiz just/misc values/DIMLIM")
        ((eq dxf  0073)  "Vert just/misc values/DIMTIH")
        ((eq dxf  0074)  "Smooth surface type/DIMTOH")
        ((eq dxf  0075)  "Repeat/flag/count/DIMSE1")
        ((eq dxf  0076)  "Repeat/flag/count/DIMSE2")
        ((eq dxf  0077)  "Repeat/flag/count/DIMTAD")
        ((eq dxf  0078)  "Repeat/flag/count/DIMZIN")
        ((eq dxf  0090)  "ADE lock/Num of vertices")
        ((eq dxf  0100)  "Subclass data marker")
        ((eq dxf  0102)  "Control string")
        ((eq dxf  0105)  "DIMVAR symbol table entry object")
        ((eq dxf  0110)  "UCS origin")
        ((eq dxf  0111)  "UCS X-axis")
        ((eq dxf  0112)  "UCS Y-axis")
        ((eq dxf  0140)  "DIMTXT")
        ((eq dxf  0141)  "DIMCEN")
        ((eq dxf  0142)  "DIMTSZ")
        ((eq dxf  0143)  "DIMALTF")
        ((eq dxf  0144)  "DIMLFAC")
        ((eq dxf  0145)  "DIMTVP")
        ((eq dxf  0146)  "DIMTFAC")
        ((eq dxf  0147)  "DIMGAP")
        ((eq dxf  0148)  "DIMALTRND/PS image origin x")
        ((eq dxf  0149)  "PS image origin y")
        ((eq dxf  0170)  "DIMALT")
        ((eq dxf  0171)  "DIMALTD")
        ((eq dxf  0172)  "DIMTOFL")
        ((eq dxf  0173)  "DIMSAH")
        ((eq dxf  0174)  "DIMTIX")
        ((eq dxf  0175)  "DIMSOXD")
        ((eq dxf  0176)  "DIMDLRD")
        ((eq dxf  0177)  "DIMCLRE")
        ((eq dxf  0178)  "DIMCLRT")
        ((eq dxf  0210)  "X of extrusion point")
        ((eq dxf  0220)  "Y of extrusion point")
        ((eq dxf  0230)  "Z of extrusion point")
        ((eq dxf  0270)  "DIMUNIT")
        ((eq dxf  0271)  "DIMDEC")
        ((eq dxf  0272)  "DIMTDEC")
        ((eq dxf  0273)  "DIMALTU")
        ((eq dxf  0274)  "DIMALTTD")
        ((eq dxf  0275)  "DIMAUNIT")
        ((eq dxf  0280)  "DIMJUST")
        ((eq dxf  0281)  "DIMSD1")
        ((eq dxf  0282)  "DIMSD2")
        ((eq dxf  0283)  "DIMTOLJ")
        ((eq dxf  0284)  "DIMTZIN")
        ((eq dxf  0285)  "DIMALTZ")
        ((eq dxf  0286)  "DIMALTTZ")
        ((eq dxf  0287)  "DIMFIT")
        ((eq dxf  0288)  "DIMUPT")
        ((eq dxf  0290)  "Plotting flag")
        ((eq dxf  0340)  "Handle of ref'd Style object")
        ((eq dxf  0370)  "Lineweight enum value")
        ((eq dxf  0390)  "Hard pointer ID/handle of PlotStyleName object")
        ((eq dxf  0410)  "Layout tab name")
        ;;  extended entity data codes
        ((eq dxf  1000)  "XData String")
        ((eq dxf  1001)  "XData Application name")
        ((eq dxf  1002)  "XData Sentinel string")
        ((eq dxf  1003)  "XData Layer associated w/EED")
        ((eq dxf  1004)  "XData Binary data")
        ((eq dxf  1005)  "XData Handle")
        ((eq dxf  1010)  "XData Three reals")
        ((eq dxf  1011)  "XData Three reals")
        ((eq dxf  1013)  "XData Three reals")
        ((eq dxf  1020)  "XData Three reals")
        ((eq dxf  1021)  "XData Three reals")
        ((eq dxf  1023)  "XData Three reals")
        ((eq dxf  1030)  "XData Three reals")
        ((eq dxf  1031)  "XData Three reals")
        ((eq dxf  1033)  "XData Three reals")
        ((eq dxf  1040)  "XData Real")
        ((eq dxf  1041)  "XData Scaled real")
        ((eq dxf  1070)  "XData 16 bit integer")
        ((eq dxf  1071)  "XData 32 bit integer")
        ;;  catch alls (some duplicated codes),
        ;;  don't have time to fix up right now
        ((<= 1000 dxf 1009)  "XData String")
        ((<= 1010 dxf 1059)  "XData Double precision 3D point")
        ((<= 1010 dxf 1059)  "XData Float")
        ((<= 1060 dxf 1070)  "XData 16 bit integer")
        ((<= 1060 dxf 1079)  "XData 16 bit integer")
        ((<= 1070 dxf 1078)  "XData Integer value, count, flag, mode")
        ((<= 1090 dxf 1099)  "XData 32 bit integer")
        ((<= 1140 dxf 1147)  "XData Double precision scalar float")
        ((<= 1170 dxf 1175)  "XData 16 bit integer")
        ((<= 1280 dxf 1289)  "XData 8 bit integer")
        ((<= 1300 dxf 1309)  "XData Arbitrary string")
        ((<= 1310 dxf 1319)  "XData Arbitrary binary chunk")
        ((<= 1320 dxf 1329)  "XData Arbitrary object handle")
        ((<= 1330 dxf 1339)  "XData Soft pointer handle")
        ((<= 1340 dxf 1349)  "XData Hard pointer handle")
        ((<= 1350 dxf 1359)  "XData Soft owner handle")
        ((<= 1360 dxf 1369)  "XData Hard owner handle")
        (t                   "Data type unknown")
e.g.
(GetDxfDesc 1005)
==> "XData Handle"
Cheers.
