Author Topic: There has to be a better way to deal with subroutines  (Read 1712 times)
Daniel J. Ellis
« on: December 10, 2008, 09:05:04 AM »
This is my current code:
(SETQ fpt (GETPOINT "\nSelect start point: "))
(POINT2D3D (fpt))
(SETQ
fpt cpt
cpt nil
cpt is the output of the POINT2D3D subroutine.
I'm repeating this process for a number of later points, hence wanting to use the subroutine.  Surely there has to be a more efficient way to move the sub's output back to the original variable and empty the sub's variable?
dJE
dJE
Re: There has to be a better way to deal with subroutines
« Reply #1 on: December 10, 2008, 10:02:34 AM »
I'm not quite sure what you are asking  :?
« Reply #2 on: December 10, 2008, 10:08:58 AM »
Try this [Not tested]
;;  returns point list or nil
(defun MyGetPoint (msg / pt)
  (if (SETQ pt (GETPOINT (strcat "\n" msg)))
    (setq pt (POINT2D3D pt))
(while (null (setq fpt (MyGetPoint "Select start point: ")))
  (prompt "Error, must pick a point, Try again.")
or this:
  (while (null (SETQ pt (GETPOINT (strcat "\n" msg))))
  (POINT2D3D pt)
Daniel J. Ellis
« Reply #3 on: December 11, 2008, 03:54:02 AM »
;;      (setq pt (POINT2D3D pt))[/quote]
That looks like it should be the one, ta
dJE
dJE
« Reply #4 on: December 11, 2008, 08:23:03 AM »
Have a look at my paper on this subject.
[ http://www.theswamp.org/index.php?topic=5203.0 ]
