Author Topic: CLR equivalents ?  (Read 8830 times)
Spike Wilbury
Re: CLR equivalents ?
« Reply #15 on: September 19, 2008, 12:28:39 AM »
Here is the solution:
ARX function
extern "C" __declspec(dllexport)
resbuf *GbPeSSPoly(AcDbObjectIdArray &ids,
  const TCHAR *LayerName,
  const TCHAR *LayerNameOut,
  double dtol,
  short poltip,
  double areamin,
  short inpol,
  short outpol,
  short dirpolhor)
resbuf* head=NULL;
resbuf* next=NULL;
// layers exists?
AcDbLayerTable *LayerTable=NULL;
acdbHostApplicationServices()->workingDatabase()->getSymbolTable(LayerTable,AcDb::kForRead);
if(!LayerTable->has(LayerName))
LayerName=_T("0"); // default
if(!LayerTable->has(LayerNameOut))
LayerNameOut=_T("0"); // default
LayerTable->close();
ads_name sspol;
if (!ids.isEmpty())
gbpoly(ids,LayerName,LayerNameOut,dtol,poltip,areamin,inpol,outpol,dirpolhor,sspol);
// now verify if the selection set has some generated polylines
long len=0;
if ((acedSSLength(sspol,&len) != RTNORM) || (len==0))
acedSSFree(sspol);
return head;
// fill the output array of object ids
for (long i=0; i<len; i++)
AcDbObjectId objId;
ads_name ename;
acedSSName(sspol,i,ename);
if (acdbGetObjectId(objId,ename) != Acad::eOk) return head;
if(!head)
head=acutNewRb(RTLONG);
next=head;
else
next->rbnext=acutNewRb(RTLONG);
next=next->rbnext;
next->resval.rlong=objId.asOldId();
acedSSFree(sspol);
return head;
acutRelRb(head);
And from C#
[DllImport("GbPolyEngine17.arx", CharSet = CharSet.Unicode, EntryPoint = "GbPeSSPoly")]
static extern IntPtr pGbPeSSPoly(IntPtr ptrids, string layerInternal, string layerExternal,
    double tol, short poltype, double minarea, short inpol, short outpol, short poldir);
public static ObjectIdCollection GbPeSSPoly(ObjectIdCollection ids, string layerInternal, string layerExternal,
    ObjectIdCollection oic = new ObjectIdCollection();
    IntPtr ip = IntPtr.Zero;
    ip = pGbPeSSPoly(ids.UnmanagedObject, layerInternal, layerExternal, tol, poltype, minarea, inpol, outpol, poldir);
    if (ip != IntPtr.Zero)
        try
            ResultBuffer rb = DisposableWrapper.Create(typeof(ResultBuffer), ip, true) as ResultBuffer;
            foreach (TypedValue tv in rb)
                ObjectId id = new ObjectId((int)tv.Value);
                oic.Add(id);
            rb.Dispose();
        catch { return null; }
    return oic;
[CommandMethod("SsPoly")]
static public void GbPolySsPoly()
    Document doc = AcadApp.DocumentManager.MdiActiveDocument;
    Editor ed = doc.Editor;
    Database db = doc.Database;
    PromptSelectionOptions prOpts = new PromptSelectionOptions();
    prOpts.MessageForAdding = "\nSelect curve objects: ";
    TypedValue[] filter = new TypedValue[1];
    Object obj = "LINE,ARC,LWPOLYLINE,POLYLINE,CIRCLE";
    filter[0] = new TypedValue(0, obj);
    SelectionFilter ssFilter = new SelectionFilter(filter);
    PromptSelectionResult res = ed.GetSelection(prOpts, ssFilter);
    if (res.Status != PromptStatus.OK) return;
        string layerInternal = "TESTINT";
        string layerExternal = "TESTEXT";
        double tol = 0.5;
        short poltype = 1;
        double minarea = 20.0;
        short inpol = 1;
        short outpol = 1;
        short poldir = 1;
        ObjectIdCollection inOids = new ObjectIdCollection();
        ObjectIdCollection outIds = new ObjectIdCollection();
        foreach (ObjectId id in res.Value.GetObjectIds())
            inOids.Add(id);
        try
            outIds = GbPeSSPoly(inOids, layerInternal, layerExternal, tol, poltype, minarea, inpol, outpol, poldir);
            if (outIds.Count > 0)
                ed.WriteMessage("\nNumber[{0}]", outIds.Count.ToString());
        catch (System.Exception ex)
            ed.WriteMessage("Error: " + ex.Message);
        tr.Commit();
HTH
It's Alive!
  • Retired
  • AKA Daniel
« Reply #16 on: September 19, 2008, 10:49:24 PM »
Hi Luis,
I had a chance to play around with this a little. Here is an example of how to do AcDbObjectIdArray <--> ObjectIdCollection
void pTest(AcDbObjectIdArray &ids)
  Acad::ErrorStatus es;
  int counter = 0;
  AcDbBlockTableRecord *pTableRecord;
  AcDbDatabase *pDatabase =
    acdbHostApplicationServices()->workingDatabase();
  AcDbBlockTablePointer
    pBlockTable(pDatabase,AcDb::kForRead);
  AcDbBlockTableIterator *pBlockTableIterator;
  pBlockTable->newIterator(pBlockTableIterator);
  for (pBlockTableIterator->start();
       !pBlockTableIterator->done();
        pBlockTableIterator->step())
    es = pBlockTableIterator->getRecord(pTableRecord, AcDb::kForRead,Adesk::kFalse);
    if (es == Acad::eOk &&  pTableRecord->hasAttributeDefinitions() == Adesk::kTrue)
      AcDbObjectIdArray blockReferenceIds;
      pTableRecord->getBlockReferenceIds(blockReferenceIds);
      ids.append(blockReferenceIds);
      pTableRecord->close();
  delete pBlockTableIterator;
public class Commands
        [DllImport("LuisArx.arx",CallingConvention = CallingConvention.Cdecl)]
        static extern IntPtr pTest(IntPtr ptrIds);
        [CommandMethod("doit")]
        static public void test()
            Editor ed = Application.DocumentManager.MdiActiveDocument.Editor;
            try
                ObjectIdCollection ids = new ObjectIdCollection();
                pTest(ids.UnmanagedObject);
                ed.WriteMessage(ids.Count.ToString());
                ed.WriteMessage(ex.Message);
Spike Wilbury
« Reply #17 on: September 20, 2008, 12:07:49 AM »
Hi Daniel,
Don't tell me....  :oops: --- well, what can I say....
I'll be doing the update to my project as your code sample.
Thank you.
Luis.
