Author Topic: Find Text in a Closed Drawing  (Read 11495 times)
« Reply #15 on: October 06, 2004, 03:14:12 PM »
Quote from: Jeff_M
Sorry CAB-
I had moved a line to the public area after testing that was supposed to be split up. If you edit the code to this it will work.
No workie :)
  Error
  Subfunction not defined
  REPLACE
objDbx.Open strFile
    For Each objEnt In objDbx.ModelSpace
      If TypeOf objEnt Is AcadMText Then
          Set objMtext = objEnt
          strTemp = objMtext.TextString
          intStr = InStr(1, strTemp, strOld, vbTextCompare)
          If intStr > 0 Then
              objMtext.TextString =   *** Replace  ***  (strTemp, strOld, strNew)
              bolMod = True
          End If
      ElseIf TypeOf objEnt Is AcadText Then
« Reply #16 on: October 06, 2004, 03:19:42 PM »
Quote from: whdjr
CAB,
Here is an ObjectDBX method thru vlisp.  Try it and let me know how it does for you.
Looks interesting, I'll give it a try tonight. ( Work gets in the way )
whdjr
« Reply #17 on: October 06, 2004, 03:42:53 PM »
I forgot to give the instructions on how to use it.  When you run it it starts with a file open box and select a file to search in.  Then it returns to the file open box for another selection.  It continues this until you click cancel, then it continues the rest of the routine.
I can change this to select all dwg's within a folder if you want that functionality.
CHANGE THIS:
(defun c:tfar (/ file files str dbxdoc of lst wil classname)
  (setq file "")
  (while (setq file (getfiled "Select a file to replace text in" file "dwg" 128))
    (setq files (cons file files))
TO THIS:
(defun c:tfar (/ path folder file files str dbxdoc of lst wil classname)
  (if (setq path (getfiled "Select a File" "" "dwg" (+ 4 128)))
    (setq folder (vl-filename-directory path)
 files (vl-directory-files folder "*.dwg" 1)
 files (mapcar '(lambda (x)
   (strcat folder "\\" x)
files
For all files in a folder.
« Reply #18 on: October 06, 2004, 05:38:12 PM »
Quote from: CAB
No workie :)
  Error
  REPLACE
What the hey?!?! Which version was this in (your sig line shows 2000 & 2004)? The REPLACE is a built-in Function to the VBA that shipped with 2002, and I'd imagine it should still work with 2004. If it's the 2000 version, a special function would need to be written (which I did before I found the Replace function and, stupidly, discarded since it obviously wasn't needed.....)  :?
As I said, "A work in progress". Thanks for trying though. Will try to play with it tonight after my wife goes to work (she got bumped to the graveyard shift, yuck).
« Reply #19 on: October 06, 2004, 08:43:27 PM »
jEFF,
yES i WAS USING acad2000 8)  Uggh-caps
« Reply #20 on: October 09, 2004, 02:29:30 PM »
Will got this:
Command: tfar
Enter search phrase?  trusses @ 16" oc
Error: ActiveX Server returned an error: Invalid index; reset after error
whdjr
« Reply #21 on: October 11, 2004, 09:42:29 AM »
CAB,
Are you trying this on A2K or A2004?
I couldn't reproduce the error.  Can you follow this in the VLIDE
and let me know where it hangs up at.
If A2K, then try this:
change:
(if (/= (getvar "ACADVER") "15.0")
    (setq classname "ObjectDBX.AxDbDocument.16")
    (setq classname "ObjectDBX.AxDbDocument")
to:
If A2004 then comment out this
;((not (DBX-Register)) (princ "Unable to load ObjectDBX."))
and change:
((not (setq dbxdoc (vla-GetInterfaceObject
    (vlax-get-acad-object)
    classname
to this:
Let me know what else happens.
« Reply #22 on: October 11, 2004, 11:30:54 AM »
Command: tfar
Command:
Error occurs here
(vlax-safearray->list
    (vlax-variant-value
      (vla-getattributes obj)
Using ACAD 2000, made the changes you suggested.
Do you want the DWG file?
whdjr
« Reply #23 on: October 11, 2004, 12:01:59 PM »
I still can't find an error.
Yes please send or post the drawing and the search phrase.
« Reply #24 on: October 11, 2004, 12:15:54 PM »
whdjr
« Reply #25 on: October 11, 2004, 01:38:36 PM »
CAB,
I looked over your drawing and it keeps crashing when it comes across your block "20GOBLT01".  I can't figure out why except that it says it has attributes, but when the program tries to get them its empty and therefore crashes.  I think I can catch the error with
vl-catch-all-apply and then I'll post the revision.
That's a strange one.  Anyone else got any ideas why a block would show a True flag for attributes, but then wouldn't have any? :?  :?  :?
whdjr
« Reply #26 on: October 11, 2004, 02:51:33 PM »
CAB,
Here is the revised code that works on your file here in my office.  I made a few modifications to show how many pieces of text, mtext, or attdefs you had in a drawing or wether that dwg was already open.
Give this one a spin and let me know. :wink:
(defun *error* (msg)
  (princ "\nError: ")
  (princ msg)
  (if (and dbxdoc (not (vlax-object-released-p dbxdoc)))
    (vlax-release-object dbxdoc)
  (gc)
(defun DLLRegister (dll)
  (startapp "regsvr32.exe" (strcat "/s \"" dll "\""))
(defun ProgID->ClassID (ProgID)
  (vl-registry-read
    (strcat "HKEY_CLASSES_ROOT\\" progid "\\CLSID")
(defun DBX-Register (/)
    ((ProgID->ClassID classname))
    ((and
       (setq server (findfile "AxDb15.dll"))
       (DLLRegister server)
    ((not (setq server (findfile "AxDb15.dll")))
     (alert
       "Error: Cannot locate ObjectDBX Type Library (AxDb15.dll)..."
    (T
     (DLLRegister "ObjectDBX.AxDbDocument")
     (or
       (ProgID->ClassID "ObjectDBX.AxDbDocument")
       (alert
"Error: Failed to register ObjectDBX ActiveX services..."
(defun findphrase (phrase document / txtcount mtxtcount attcount oName)
  (setq txtcount 0
mtxtcount 0
attcount 0
  (vlax-for item (vla-get-modelspace document)
    (setq oName (vla-get-ObjectName item))
    (cond ((eq oName "AcDbText")
  (if (vl-string-search phrase (vla-get-textstring item))
    (setq txtcount (1+ txtcount))
 ((eq oName "AcDbMText")
    (setq mtxtcount (1+ mtxtcount))
 ((and (eq oName "AcDbBlockReference")
(eq (vla-get-hasattributes item) :vlax-true)
  (foreach for-item (get_atts item)
    (if (vl-string-search phrase (vla-get-textstring for-item))
      (setq attcount (1+ attcount))
  (list txtcount mtxtcount attcount)
(defun get_atts (obj / val)
  (if (vl-catch-all-error-p
(vl-catch-all-apply
 '(lambda ()
    (setq val (vlax-safearray->list
(vlax-variant-value
    nil
    val
  (setq file "")
  (cond ((not files) (princ "No files were selected."))
((not (setq str (getstring T "Enter search phrase?  ")))
(princ "\nSearch phrase is missing. ")
    classname
(T
(foreach f (reverse files)
  (setq of  (vl-catch-all-apply
      '(lambda ()
 (vlax-invoke-method dbxdoc 'open f)
lst (if (vl-catch-all-error-p of)
      (list f "File was read only. ")
      (list f (findphrase str dbxdoc))
wil (cons lst wil)
  (gc)
  (textscr)
    (princ
      (strcat "\n"
      (car x)
      (cond ((eq (type (cadr x)) 'LIST)
     (apply 'strcat
    (mapcar '(lambda (y z)
(strcat "\n" (itoa y) z)
    (cadr x)
    '(" text entities matched your phrase."
      " mtext entities matched your phrase."
      " attribute reference entities matched your phrase.\n"
    (T (strcat "\n" (cadr x))
 wil
« Reply #27 on: October 11, 2004, 03:17:03 PM »
Quote from: whdjr
CAB,
Will,
The block is one created by Arch-T. The attribute has a tag 'Go-Bolt' which
displays on the screen and was used to make a slide so the slide has a
visible label in the original drawing but will not be displayed when inserted
as the attribute is empty.
That is my understanding of it anyway.
« Reply #28 on: October 11, 2004, 03:29:45 PM »
Command: tfar
Enter search phrase?  trusses @16" oc
That seemed to work, although case sensitive.
Command: tfar
C:\Program Files\ACAD2000\=Active Projects\Steve Carter\4225 Morrison\4225
Morrison Master 1.DWG
0 text entities matched your phrase.
0 mtext entities matched your phrase.
0 attribute reference entities matched your phrase.
Command:
Command:
Command:
Command: _open
Command: tfar
Enter search phrase?  PRE MFG TRUSSES @ 16" OC
3 text entities matched your phrase.
Command:
Command: PRE PREVIEW
Press ESC or ENTER to exit, or right-click to display shortcut menu.
Command: tfar
Enter search phrase?  TRUSSES @ 16" OC
Command:
Message when file was open:
Command: tfar
File was read only.
whdjr
« Reply #29 on: October 11, 2004, 03:34:26 PM »
Glad that worked for you.
