Author Topic: Filter command - Closed Polyline Option?  (Read 3728 times)
quamper
« on: August 18, 2008, 12:10:57 PM »
In quick select you can check for Closed/Non-Closed polylines. Can you check for that with the Filter Command/Dialog?
rkmcswain
Re: Filter command - Closed Polyline Option?
« Reply #1 on: August 18, 2008, 01:12:21 PM »
I don't think so.
You can do it with lisp like this:
;;; select closed polylines
(ssget '((0 . "POLYLINE,LWPOLYLINE")(-4 . "&")(70 . 1)))
quamper
« Reply #2 on: August 18, 2008, 01:47:07 PM »
Is there not a DXF code for Open Polylines? I just looked in the DXF reference and I don't see anything, but I might be missing something obvious.
« Reply #3 on: August 18, 2008, 01:49:27 PM »
DXF 70 8-)
Polyline flag (bit-coded); default is 0:
1 = Closed; 128 = Plinegen
quamper
« Reply #4 on: August 18, 2008, 02:32:54 PM »
Hmm  :-( .. ok I'm still not getting it for some reason.
I draw 2 new polylines in an empty drawing. 1 of which is closed and the other is not.
(ssget "x" '((0 . "LWPOLYLINE")))
That selects both polylines in the drawing no problem what so ever.
however nothing else (including samples already posted) I've tried will select just one or the other. Everything will either select both or nothing
Spike Wilbury
« Reply #5 on: August 18, 2008, 02:42:00 PM »
Did you tried with:
;; close
(ssget '((0 . "POLYLINE,LWPOLYLINE")(-4 . "=")(70 . 1)))
;; open
(ssget '((0 . "POLYLINE,LWPOLYLINE")(-4 . "=")(70 . 0)))
quamper
« Reply #6 on: August 18, 2008, 02:45:27 PM »
Did you tried with:
;; close
;; open
ARG! That's what I was trying  :cry:, but I had overlooked the fact that .. somehow the closed one changed to an open one, hence it not working right.
Sorry. That's exactly what I was looking for. Thanks for being patient  :angel:
« Reply #7 on: August 18, 2008, 02:46:58 PM »
That will not work when PLINEGEN is True.....you must test for the Bitwise 1 (as R.K. suggested):
;;get all lwplines
(setq ss (ssget "x" '((0 . "LWPOLYLINE"))))
;;get only closed lwplines
(setq ssclosed (ssget "x" '((0 . "LWPOLYLINE")(-4 . "&")(70 . 1))))
;; get only open lwplines
(setq ssopen (ssget "x" '((0 . "LWPOLYLINE")(-4 . "<NOT")(-4 . "&")(70 . 1)(-4 . "NOT>"))))
rkmcswain
« Reply #8 on: August 18, 2008, 05:25:40 PM »
Quote from: Quamper
You must have missed this one   :wink:
quamper
« Reply #9 on: August 19, 2008, 08:40:15 AM »
Quote from: Quamper
Well I was having problems with that for the same reason.
While the following that you posted works for closed polylines
changing the 70 . 1 to 70 . 0 doesn't work for open polylines.
But really that would have gotten me on the right track if I hadn't screwed up my sample I was working with  :-o
